murrayec
Everything posted by murrayec
  1. This GNR T2 tank loco visited the shop for some upgrades- breaks, pick-ups, and wheel weights. Body off and a bit of a survey being carried out. With drawings done the parts were cut out in .5mm brass- wheel weights, break hangers n bars. All cleaned up with the Tufnol break shoes ready to go on. Main pick-ups upgraded with .4mm NS wipers and break stuff being soldered on. Nice little set of cast brass break shoes soldered on the bogie truck. .4mm NS wiper pick-ups installed under the bogie truck. Almost there. Chassis up and running. Body back on and its off to the owner and paint shop. Eoin
  2. There is a great article in the Gauge O Guild Gazette this month on the MRSI 'Locos For Ardmore' where the above model builder and others are credited for the amazing array of Irish type locos on this layout, amazing stuff...... Eoin
  3. If you use stick on LED strip lighting you wont have to worry about light coming up through the roof, the LEDs are facing downwards. You could also mount the strips on a wide piece of card and then fix that to the roof?.... Eoin
  4. Excellent, we'll file that for future reference...... Eoin
  5. I reckon Broithe's approach is correct, it looks like yours have the screws removed! are they second hand? as some clever chap may have glued them without the screws. Here is an image I found on e-bay which clearly shows screws;- Eoin
  6. Nice space there Jason, this is going to be fun to watch develop. My only suggestion on the shed, and you have probably considered this- is to install roof gutters and down pipes. This will stop water dripping from the corrugated sheeted roof onto the wall, generally it hits the wall low down and causes dampness to the lower planks and the floor edge if no guttering is installed. Also the added extension of the gutters weather the wall better from the rain. Eoin
  7. This is the list of scanned drawings the IRRS have available at the moment;- Eoin
  8. Thanks all for likes and coments John CNC'ing parts is OK for one or two off items, but etching would be far quicker for batch runs like your kits Yes, I must send a link to Alan Doherty and NIL and have a chat The second bogie with its detail soldered on and cleaned up while in the sprue. Now the frames are ready to take the third laminate which is sweat soldered on the back Soldered on and cleaned up, the soldering was done with the detail face up and the 3rd laminate frame clamped under, this prevents gravity making the detail parts fall off when the heat gets going- just one problem, one of the axle box bolts boiled up in the solder and popped out and stuck to the face of the box. That had to be fixed! Preparing the 2.4mm copper tube to make the spring housings top and bottom of the spring, in this photo the pipe was filed down to size .8mm for the top housing and then sliced up .7mm deep on the lathe with a slitting saw. All the parts for the spring system;- spring are made from M2 brass screws, spring housings from the above tube, shock mounting and torsion bar mountings folded and soldered from the .25mm brass sheet, and little brass keeper plates for under the axle boxes. Soldering this lot is going to be fun...... You may be interested to know why I used brass for this?- when I made the Class A bogie side patterns out of plastic I had untold problems with the plastic deforming with the glues used- plastic weld being the worst! This led to problems making the moulds and then the WM casts came out slightly warped, nothing that a few drops onto the workbench couldn't sort but not great. Also as the patterns were plastic they wanted to float in the moulding chemicals while liquid, nothing worse than coming back to the mould several hours later thinking your done, to find the pattern came free and floated up to the surface while the chemicals set. Eoin
  9. A very common logo in the car & motorcycle world https://www.google.com/search?q=wings+wheel+logo&client=firefox-b&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwicrN_9s7reAhUB_KQKHVGcBw0QsAR6BAgGEAE&biw=1280&bih=891 There is a thread on here discussing the origins of the flying snail logo, where we came to the conclusion that the Persians came up with the winged logo for their God- Aru Mazda (could have spelt that wrong) and since then all have adopted it in some fashion.... Eoin
  10. until
  11. Date for the November Train & Model Fair;-
  12. That was the other thing about the BR sides- they only came in 8'6'' from Dart Castings, and I built the bogies in 8'6'', so now I'll have to change them also- they are on order.... Eoin
  13. While working on the bogie sides last week I was getting very irritated working with the BR Commonwealth sides! Fortunately while talking to my friendly railway historian and collector of all handy stuff for the modeller, he announced a laminate drawing had come across his desk, including a sketch of the bogie sides- excellent. So I 'bit the bogie', so to speak, and decided to change tack and develop up CIE Commonwealth sides, a scan was duly and gratefully received, imported into Autocad, traced, adjusted and prepared to CNC out two sets of parts to make patterns to make moulds from;- .5mm brass for the main frame bits. .23mm brass for the smaller items and the brackets for the suspension torsion bar. Those little bits came free from the tabs in the sheet- all were found! All the bits, I'm going to use M2 machine screws to make the suspension springs with a bit of 2.4mm copper pipe to mount them in and various sizes of brass pipe for the shock. The shock and torsion bar will be installed after the sides are cast- mmmh! I hope? After de-burring the .5mm sheet I set about soldering in .35mm PB wire to create bolt heads on the axle boxes, this was done on the back of the sheet held down on two strips of .23mm brass so the wire would protrude out the front. Nice little bolt heads after cleaning up the front. I then set about soldering the main structure together, there are 3 laminates in this construction and I left the middle one attached to the sprue to hold it better and then bits were clamped in the jig and sweat soldered on- top done first. Gave up at this point this evening while the going was good...... Eoin
  14. It's a Brendan Kelly built model, a bit of a trade for work to be done on one of his Gauge 1 models It's motored up and does run but needs a bit of tweaking & finishing I love it Eoin
  15. Hi Guys I had a thoroughly enjoyable weekend, great to meet all I chatted with, and a big thanks to all that commented on the DARTs and the J10 and even a few orders taken. Thanks to the chaps of the MRSI for the hard work..... My hoard from the show;- I also picked up a few digital Loco drawing books from the IRRS boys for reference in up and coming projects Deposit in on my IRM Silver Class A Roll on next year! but need to save up again......... Eoin
  16. Hi ken Say to etch the sheet you have CNC'ed above would take about 1 hour in .5mm brass, but up to 10 separate sheets (dependant on size of etching tank, my tank is small and takes 4 sheets) can be processed at a time, and these sheets could have 4 kits on them! A bit of the process on a bogie system here;- Eoin
  17. Hi Anthony Yes your correct, you don't want to electrical short those, use a bolt and washers suitable that fit between and does not touch them- or using a plastic bolt is even better..... Eoin
  18. Lovely stuff Ken I reckon etching would be far more economical on time for mass production, there is more prep work in making the etching tooling & UV exposure but once done one could clatter out etches in quantity in the same time a CNC machine would cut one. CNC cutting for one off and small quantity...... Eoin
  19. Hi Leslie A source for brass would be good to know and would be appreciated I'm using shim brass from Healy Metals, it's hard and needs annealing to work it for curves but it's the cheapest way to buy sub 1mm brass. I have also got it from Eileens but again its hard and not flat- it comes off a roll and when annealing it wobbles all over the place, I gave that up.... Thanks Eoin
  20. Hi Glover Your getting on fine, just one thing I see in the photo- does the snap button work with the way you have stuck it under the rocker? the male bit should be fixed to the bolster pointing downwards and the female to the top of the rocker facing up..... Eoin Hi fl Yes all the stuff I make is available, pm me Eoin
  21. Hi Glover If you need more info on doing them let me know and I can post some helpful tips? Eoin
  22. Hi John It's from the Midland Railway Centre DT12 & RFA12, www.midrailcentre.com it's a few bob but after looking at making my own I felt it was worth the investment and save me time! If thinking of a purchase I recommend going for the extra set of clamps, it comes with 4 but with the 4mm rolling bar it's not enough! the bar was flexing and getting pushed back so I had to add two extra clamps to hold it. Eoin
  23. The roofs and parts were CNC cut for both coaches in .25mm brass sheet;- Roofs, coach partitions, some roof spars to aid fixing the sides and roof, roof steps, door foot steps, and bogie out riggers for the bogie sides. Rolling the roof on mouse mats and using a strip of ply to apply pressure in the centre of the bar- lots of annealing here! First curve done. Jigging up for the turn down curve, my drawing template was used again to position the brass!! And done, annealing the brass for each side really helps. Partitions and bogie riggers cleaned up and ready..... Till next time Eoin
  24. The sides were removed and cleaned up;- Part of the sprue was retained at the break compartment doors, this was reinforced with a dab of solder. The side tumble-home was worked out from my template drawing and the sides jigged up for folding One side done, looks good! Both sides done, even better! Break compartment doors required the reveals to take the shape of the sides, out with the piercing saw. Reveals folded, not shown her but the door head was folded out also. And soldered in.
  25. The chassis parts were cleaned up and marked out for the bolsters, door location, and then soldered up;- I added in cross braces to the truss and the boxes had to be trimmed down to fit between the floor and the truss, I also reinforced the slots left in the chassis from folding down the truss by soldering in scrap brass. These are the body fixing brackets with soldered M2 nuts, they will be soldered to the coach ends.
