BSGSV
Everything posted by BSGSV
  1. Cabin view blocked by water tank sounds like Boyle!
  2. Lovely job this. Re signalling, the layout is similar to Loughrea or Ballinrobe minus one siding. The 1890 practice for those had a working distant (a practice later abandoned), home and starter (the latter on the platform before the fouling point with the loop crossover) and one lever operating the crossover near the tunnel to the loop, the facing point lock and a point detector on the turnout from the loop. A five-lever frame (four working one spare) would easily fit into the type of Railway Signal Co. (the usual MGWR contractors) cabin used at Ballinrobe. Such a cabin might be only 10' wide and 7' long, the dimensions of the 1918 cabin at Loughrea, would be spot on apart from the concrete blocks. Such a building might fit between the water tank and tunnel?
  3. The remaining insulator is damaged, which is perhaps why it remains. The spindles are galvanised, so still fairly rust-free, as is the clamp for the stay wire, although the stay wire itself does not look so good.
  4. That looks like an old-fashioned junction signal. Instead of a bracket, the arms are stacked on the one post. Normally the convention is arms top-to-bottom reads to lines/tracks left-to-right. But, as you say, only one lamp.
  5. Spot on. Moate is a Railway Signal Company (RSCo) design cabin, of a type widely used on the MGWR (and elsewhere in Ireland). The design differs from the McKenzine & Holland (McK&H) cabin (of the Ratio kit) in operating floor windows, gable vents, gable bargeboards and locking room windows, aside from lever frame type. The original operating floor windows of Moate are shown in this photograph https://www.geograph.org.uk/photo/4305633 "The Signal Box" book (https://www.amazon.com/Signal-Box-Pictorial-History-Designs/dp/0860932249) covers the UK signalling contractors designs, as well as basic terminology, technology and legislation affecting design. If they got contracts, the contractors generally used their then standard designs (or a variant) in Ireland. Unfortunately, the Irish companies own designs are not covered. As Mayner says, the MGWR approach to Civil War damage was to either wholly replace the cabin (Mayner has illustrated Ballywillan, the end windows are replacements) which featured internal stairs, rear lever frames, concrete blocks construction to floor and, most often, RSCo. lever frames. It also appears that a similar design operating floor was used to replace the top of older cabins where the brick base and frame were re-usable. These tended to have external stairs. Multyfarnham is an example.
  6. The square window reflection at Spa suggests one of the first three G's on the train.
  7. Looks like a dead C class behind 186 at Ennis.
  8. The coach next to the one the photographer is in, looks to me like a 1356-71 series CIE built, timber framed coach.
  9. IRM have been very good in supporting the ITG in this way, and the ITG is very grateful to all the staff in IRM for their kindness. The model is selling well, so thank you to all the buyers too, for backing this special edition with their money. Ken Manto, ITG Chairman.
  10. The date looks wrong. The loco looks quite new - no snail casting on the side, sandboxes still fitted, no snatchers, both wipers in place and clean roof.
  11. Now don't be upsetting a man who's clearly been enjoying himself. The distant appears to be for trains leaving the terminus, so it must be a gate distant, like the one just off the platform at Rosslare Strand heading for Waterford. Gate distants worked off the gate heels would be off in both directions. Gatekeeper just a bit slow closing the gates after the arriving train.
  12. I think the electrical incompatibility between the NIR and IE stock may have been related as much to different connectors as load. As you say, similar outcome to the Cravens and Mk.2AC. 1991. Is it really that long ago?
  13. I agree. The shed should also be next door if it was Bally, and the main line should be in the background.
  14. Birdhill did have a turntable, not at the station. Appears to be up at the divergence of the two single lines, between them.
  15. I'd guess Roscrea, but not sure. Other local sites don't seem to tally map wise.
  16. I don't think there is a difference. I think it's just that the snatcher is covering the open droplight.
  17. That's them. 40 first, 36 seconds.
  18. Nice one gents. I think that's the first photo I've seen of those 10 suburban compos before they got converted to brake standards.
  19. It's one of the ones Mr. Bulleid got built at Inchicore, additional to the 60 from AEC, 2660-2665. They appeared in 1957, but were all converted to powered intermediates from as early as 1961. 2660 was one of the railcars on the last day of service.
  20. Well, neither Garfield nor myself are old enough to have been there at the time, so we are relying on sources. In fairness to JHB, he would have been a little young too I think, for such detailed record taking! Barry Carse's book also mentions the two greens, and he also, like JHB, would have a keen observer in a father who would have been about at the time. Barry also mentions that A46 was the only one to migrate from dark to light green - a statement I have seen elsewhere, and hardly something to make special mention of if there were not more than one dark green loco that could be repainted light green in the first place. C231 and C234 are both stated to have been delivered in (dark) green, rather than silver. I would suspect the IRN article was based on notes taken at the time in 1958-62 or so, and I would have thought that howlers would have been weeded out by the editorial team, if they didn't write it themselves in the first place. Anyway, a good excuse for re-reading! I guess the upside is that if you want multiple dark green A's running about on your layout, nobody can really tell you categorically you're wrong! Mind, this is just the colour discussion. What about detail differences like which ones in green still had sandboxes? One for another day, I think.
  21. I offer the following from Irish Railfans' News, August 1969. "The A class diesel loco was introduced to this country in 1955. The first arrivals entered service in a silver livery but there have been many changes since. The following article deals with this specialised but interesting aspect of locomotive development. The silver livery of the first As was offset by green numerals at each end and about half-way along each side, by a green CIÉ “snail” emblem on each side, and by the red buffer beams. As the years passed the livery became more and more dishevelled until by 1958 all (except A16 and A19 which were repainted in 1957) were grubby, to say the least. A change was made then: in May 1958 A46 appeared in a livery of dark green with a light green waistband and numerals. The buffer beams remained red. About the same time A36 appeared in a lighter green without the waistband but with numerals and buffer beams similar to A46. In time A locos 10, 11, 15, 24, 25, 34, 45, 51, 54, 57, 59 and 60 came out of the shops in the “A46 livery”; this was during 1958-59. Early in 1960 the overall light green livery, as on A36, began appearing on a wide scale. Late in that year A46 itself succumbed and came out sans waistband in the lighter green. The preference for the lighter green livery continued until mid-1961 although it should be noted that no other loco made the transition from the dark green to the light green livery. Thus in 1961 the A class locos bore two green liveries while the original silver livery (in a really poor state) was still to be found. There was a dramatic change in September 1961, when A6 appeared in a livery of black, golden brown and white. The white consisted of a band around the loco, a little below roof height, which dipped to a point at either end over the ridge between the cab windows. Below this was a wide layer of black which likewise came down in a point, this time below the cab windows and immediately below the point of the white band. The rest of the bodywork was brown, and the buffer beams were the familiar red. The numbers were in white on each end only. This livery spread gradually during 1962-3, though after the first few locos the black band was made narrower. To confuse the picture, however, A16 appeared early in 1962 resplendent in the original silver livery! Though the “black and tan” livery (as it was very quickly dubbed) was applied to A locos: 1-3, 5-8, 12, 14, 15, 17, 20, 22-24, 27, 31, 36, 37, 39, 40, 47, 48, 50, 52, 56 and 58, there were still some locos running at this time in the old silver colours. The latter were by now exceedingly worn and some numbers were barely visible. Then early in 1964 A30 appeared completely black in colour, the only relief being a white band above cab window level at each end; this rose to a point in the centre, between the windows. There were white numerals at each end and midway along the sides; the buffer beams were orange. This did not last long - only 2 other locos were so treated, A49 and A55 - but was replaced by a slightly-modified version in which the buffer beams reverted to red, and the centrallyplaced side numerals were replaced by two separate smaller numbers on the sides: one at each end, just above the bogie and behind the cab door. The modified black and white livery remained unchallenged until mid-1968 and almost all the class were painted in it. There were exceptions, of course: As 1, 15, 22, 37 and 52 remained black and tan, the damaged A54 was still dark green, while A16, following its efforts in the filming of “Darling Lili”, was in a rather extraordinary livery which was mainly black with a stretch of black and tan at either end. By this time also, A58R and A59R had appeared in black and tan. In June 1968 A52 appeared in a variant on the all black livery. It had a yellow patch covering each end from just below the cab windows down to the buffer beam, the yellow area being the full width of the loco. The numbers at each end were in black. The livery was not adopted for A15, which was since repainted in black and white, without the yellow ends. The current position is thus: As 22, 37, 58R, 59R: black and tan; As 4, 12, 13, 20, 24,31, 34, 50, 52, 55: black and white with yellow ends. All others are black and white. Just what livery (if any!) will appear next is anybody’s guess. Even without a new version there has been a varied enough series so far".
  22. In the early 90's, until the arrival of the (new) 201 Class and the first railcars, IR were badly strapped for motive power. Failures were common and the locos would be sent back out with a sticking plaster on, as there was nothing else. An A on the Rosslare road was an alternative to the frequent appearance of a single Bo-Bo.
  23. I really enjoyed it, and many thanks to Leslie for his work in preparing and presenting it. I loved the photos of fair day at Baltinglass.
  24. The CR ones don't appear to have clerestories, but the GSWR ones did have, didn't they?
