Everything posted by Noel
Hi Guys has anybody experienced any issues recently with Humbrol matt varnish rattle can spray? I've used it for years with no problems but last two cans are consistently going milky in a way I've not seen before. Usual precautions have been taken such as the cans are stored somewhere warm not cold, applied in a dry warm atmosphere (eg not in a cold damp shed during winter), the target surface is well cured usually 48hrs after painting, and I apply in thinly in multiple coats. I could just be unlucky with two cans from a bad batch. I also tried applying it direct onto unpainted plastic surfaces with the same results (ie going milky). I often do this if weathering plastic chassis as weathering paint doesn't take well direct to plastic, but a coat of matt varnish and both railmatch paints and weathering powders take to it better.
- 1 reply
- 1
This Hornby shortie is going to be a challenge to respray, because the glazing is part of the coach body and not removable or easily maskable. Luckily thought the BR swallow livery has back panel surrounding the windows like CIE ST livery, so that might help if I mask over the entire black panel and respray the rest of the coach. Got the donors for a song on eBay so they owe me nothing. if it goes horribly wrong I might just paint it all over some sort of imaginary PW crew coach livery (ie canteen + rest area) to run with PW trains. Whatever colour it ends up it certainly won't be any shade of yellow. Possibly grey lined, or green'n'grey.
Next few mk3 resprays on the bench. See below. How to dismantle a Lima mk3 coach. How to dismantle a Lima mk3 coach (for respray)
I'd hazard a wild guess a wagon that uses the same chassis, 20-22ft container flats v double beet wagons, molasses, etc. Look how much milage they extracted from the 42ft chassis. Would love if they were doing mk3 or CAF mk4 sets. MM could to a rerun of Green'n'Silver 201s to go with the CAFs (ie 222 and 229 long sold out).
2 axle HLV, 2 axle TPO, Bogie Parcel Van, Bogie TPO, CIE GSV (BR Mk1 BSK), 2 x CIE Dutch GSV, IE/IR Rebuilt Dutch GSV, RPSI Dutch GSV = 11 vans inc 9 GSV's mostly kits or kit bashed (Forgot ro add the RTR SF BR Mk1 GSV to the formation). Had fund working on some of these recently on the work bench. Now its back to sinful modern era mk3 resprays.
- 1 reply
- 7
Enjoy. It looks like a fun challenge honing a new skill. Like migrating from coding AppleSoft basic to UCSD Pascal back in 1982 on the original Apple IIe. The decoder test harness looks like a neat tool.
Not sure about the technical details, but the LokSound V4.0 decoders support drive hold. All of the projects WheelTappers did for my 141/181 fleet have it as well as 201 and 071, even their A class and 121 class projects. Drive hold is great for simulating heavy trains starting off with trashing and notching, as swell as trains coasting from distant to home signals and prototypical braking distances. F5 is the most used function on my locos along with F6 for braking. Highly recommend Neil of Wheeltappers DCC sounds for all and any Irish diesel loco sounds. A class act and attention to detail. Got a superb steam project from him also for J15 (00 works). Highly recommend WheelTappers as the best and most comprehensive supplier for Irish DCC sounds. http://www.wheeltappersdccsounds.co.uk/
Just about finished rebuilt IE/IR Dutch GSV (exCIE) kit suitable to run with my Bachmann/MM IE/IR mk2a coaches. I seem to be collecting GSVs and EGVs Like brake vans, I just like them, they ran with every train and had purpose in the moment of people and/or goods.
Very tasty job. Looks well and rather unique. Like the Irish signage detail.
Holy Cow. I have ten of those in the attic. I did actually burn the boxes about 40 years ago cause they were taking up too much space (ie clutter). How on earth can a lima 5h1t heap of that era and that standard of 1970s be worth more than an A class or a 121 loco? The couplings seem the size of a horse shoe and the wheels could cut pizza. Desparate heaps, but back in 1977 I thought they were the bees knees and the cats whiskers. Here are 3 of them in the branch station taken about 1978 And two more with a repainted hornby running between baseboards
Anthony Smyth has spectacularly weathered his spoils over on FB group. Absolutely incredible job, makes them look so real. Love the way he got the interiors done and the loads Holy Moly Greatly improves the look of already excellent wagons.
Yes it caused an earth quake when in the early 19902 Air Lingus witched from Boeing 4 engined 747s to twin engined Air Bus A330 for the Atlantic route, one of the first carriers to switch to ETOPS. Before that carriers did not operate twin engine aircraft trans oceanic, Boeing fought hard to retain the account knowing other carriers might fall like dominos to ETOPS if it proved successful for Aer Lingus which it did, and ETOPS turned the tide away from 4 engined aircraft. At the time some Pilot unions were opposed to ETOPS citing safety concerns, but in truth their real concern was the effect ETOPS might have on company revenue if business travellers got fed up of diversions when an engine had any abnormal readings (ie vibrations, etc), whereas on the 747 if an engine went tech mid way across the Atlantic the flight continued onto the original destination on 3 engines, often flying the return leg home to their maintenance base on three engines using four just for TO out of KJFK then shutting it down. None of that allowable on a twin. But the modern generation of high byass turbofan engines proved so reliable that statistically modern wide body aircraft needed less diversions that their former 4 engined counterparts and cost a lot less to operate and maintain. Hence 777, 787, A330 fly all the longest trans oceanic routes safely on two engines. As a pal of mine in Aer Lingus once commented with 4 engines there are twice as many things that can go wrong compared to a modern twin wide body. Now the 747 is finished as has already happened to the A340 and even now the A380s are being retired and cut up. 787 and A350 have stolen the show. The decision by Aer Lingus to switch from Boeing to Airbus sent shock waves through the industry, and was a very brave decision at the time considering ETOPS had not been proven statistically economic at the time, and the big issues was Aer Lingus were a major boing repair and maintenance outfit for smaller air lines in EMEA, and Aer Lingus earned substantial revenue from same which subsidised their open Ops. Airbus is now bigger than Boeing despite the A380 failure, or more correctly predictions that hub2hub would grow due to crowded skies and lack of slot times, Boeing guessed correctly that more pax wanted to fly direct point2point without changing flights at intermediate hubs. Ryan Air saved Boeing after 9/11 with the biggest 737 order in history. 737 Max has cause serious financial problems since MCAS. That's the great thing about a loco going tech, it just stops on the rails, whereas an aircraft is going a little quicker.
Yes that was iconic. There's a good youtube of it too. You have to wonder if politics ever had any influence in semi-state purchasing decisions. Swinging between favour to old colonial business relationships to favouring competition from opposition (eg like the early 1920s when German Electric companies were favoured for supply of our early national grid infrastructure, Siemens Suckhert, etc). You can imagine the Lemass era building economic trading bridges with the UK hence MV got an opportunity to bid. There may have been a return favour with agri-exports to GB or something (quid pro quo). Ireland moved away from steam 15 years before GB did, so diesel-electric was new tech in that part of the world, whereas USA had decades of experience with their vast distances and heavy trains where reliability would have been essential. Interesting the first batch of locos were mere switchers that were capable enough to operate mainline services to the west of ireland. One of my earliest travel memories was travelling behind a grey 121 to Galway from Westland row.
Best wishes Patrick for continued recovery. Always enjoy your layout posts and a big fan of your layout.
Noticed last evening RMweb site completely crashed. Came up briefly this morning but crawling as if its under a DDS. Offline again. That was the good thing about old copper phones, you could depend on them 100% even during a power cut.
RPSI Dutch GSV 462 just about complete, next step is some very mild weathering. Glad to have a heating van to keep my rake of Bachmann RPSI mk2a coaches warm.
Fabulous. You've the patience of a saint to tile such a huge roof, but it shows.
Super sequence, love the prototypical driving. The 3173 BCK looks great, love the see through grills. Are they part of a detailing kit you sourced? Did you respray a few cravens to match the RPSI set. A rake of six looks well. Noticed some of the coaches didn't have the MM/RPSI wobble. Trackwork looks epic. Class all round.
- 468 replies
- 2
- ballyercall
- layout
(and 1 more)
Tagged with:
Exactly you take it out of the box cause you wanna play with it and drive it. And then recycle the box for scenic work or structural scenic support.
Hornby has always smacked of 'el-cheapo' poor engineering poor chassis, toy town model bodies. Bachmann came in with Branchline in the late 80s and early 90s and showed that better quality was possible while Hornby clung to 'Try-Ang' standards rather than going up a gear to German and Swiss modelling standards. Still the brand name evokes a strong nostalgia pull from they days when every small boy got a toy train set for a Christmas or a Birthday. The sad reality is nowadays kids don't play with physical toys requiring tactile feed nor assembly skills, it has to be a dancing LCD screen that entertains them rather then them using their imagination to build and operate imaginary worlds (eg Lego, Mecanno, Wooden blocks, train sets, scalextric, airfoil). Modern toys have driven the engineer and creative imaginative skills out of children. I remember the first time I visited a friends German model railway layout in the late 1980s, digital by then, lights, precision flywheel balanced intricate chassis, electric uncouplers, and I remember the realisation the UK stuff was junk in the dark ages, long left behind, entrenched only in nostalgia, from another century. One of the things about IRM/AS I admire is their rejection of past standards that were once deemed acceptable and instead saying why not, why not build to a level of precision and hyper detail the market has not seen in this part of the world, refusing to accept that it is not possible. Well their products state other wise. Raising the bar to uncomfortable levels for complacent incumbents. The hard trick is to be profitable while aiming high.
They were resin kits from SF and IFM
Fake boilers and water storage tanks.
Thanks. I don't know how it all works but my pal who was an engineer in CIE at the time was mighty impressed with the whole setup on the then new darts mit alles ze nue German tecknowledgie He did his best to explain it to me, and the main points I remember was wow the trains weighs itself in real time as pax get on and off, so calculates max speed based on braking distance, weather, temp, wet rails, bends, distance to next signal, etc, and displayed the max permitted speed on the instrumentation using a bug with the train automatically braking just enough to stay on or under the limit. He said they could almost send these things out without drivers, but the public might not want to get on a train with no driver visible.
Yes typically EVs will manage upto 150,000km before their brake pads need replacing. I had a tour of Dart system in 1984 and one of the things the engineer made a big thing about was the regen braking as well as each coach weighing itself so that max speeds and braking distances automatically calculated in real time. I remember being pretty impressed with the German technology employed.
Ah so like regen braking in EVs? Pity the derelict out of service 201s at inchicore could not get reengined with hybrid systems, then the regen could go back into the battery rather than resistors, reduce the amount of diesel pollution and especially filthy NoX that locos emit.
