Basic brass locomotive etchs
Yes.
Predicted usage and potential of the Achill, Clifden and Killala lines was way, way more optimistic than even the busiest times each of them ever was.
Investigation of the history of all three shows that the neighbouring MGWR was highly unenthusiastic about them from the earliest suggestions, as the MGWR was well aware they would never break even, let alone turn a profit.
And unfortunately they were right!
In terms of a layout, sticking strictly to the prototype, virtually all stations in all lines would be hard to fit in most people’s attics. In terms of Achill, Newport without viaduct and long western-side cattle sidings, would be as doable as any, while a slimmed-down Achill is doable. Drop one or two of the sidings even, and it becomes a compact enough terminus.
Mulrany could make a compact enough station too - the hotel building is far enough away to ignore, though there’s less operational interest in it, especially since in later days trains crossed at Newport, not Mulrany.
Then theres the planned, but never built, one-platform halt and fish siding at Tonragee - think of a red-brick Dunsandle.
After the line closed, one of these locos ran on the Ballina branch for a while. Another put in a guest appearance at Loughrea, and two were moved to Athlone. During this time, the Athlone-Portarlington branch train was occasionally hauled by one.
Edited by jhb171achill
  • Informative 2
One thing about 3D printing is that you would need to make sure you can fit a 21mm gauge chassis under it. The other thing would also be to try and consider what  Bachman / Hornby chassis you can use under the print and just how accurate you want to be.
Something else to think about would be of course to print a scale 3D print chassis block and take the bits from an above donor chassis.
  • Agree 1
Yes.
Investigation of the history of all three shows that the neighbouring MGWR was highly unenthusiastic about them from the earliest suggestions, as the MGWR was well aware they would never break even, let alone turn a profit....
As has been said elsewhere on this Forum, it seems to be a very Irish thing to support all these things....so long as someone else is paying for it!
The viaduct at Newport is what would make any model of the place - without it, a Newport layout might well become nondescript.
Edited by Horsetan
I think it was Michael McGowan author of the Hard Road to the Klondike a returning emigrant commented that the Donegal natives who built the Burtonport Extension slipped up badly by completing the line quickly and not 'making the job last'.
The building of lines to remote parts of the West gave a short economic boost during their construction, but no long term economic benefit to the districts they served, as soon as they were able a large part of the population had to emigrate in order to survive and send back money to support the people that remained behind.
Edited by Mayner
Indeed; it was said that the only benefit they brought to some places was that they made it easier to get to an emigrant port.........
I wonder what 4.4.0 chassis might suit? Any thoughts / ideas?
Richard Ellis once produced a 3D printed GNR JT 2-4-2T complete with 3D printed chassis on the Shapeways platform, it was intended that the builder source their wheels, gearbox and motor from a supplier like Markits or Alan Gibson than attempt to take the bits from a proprietary RTR chassis.
Having assembled several 21mm gauge locos I think 3D printing or injection molded plastic would be a non-runner for a 21mm gauge loco body due to the nature of the material it would be extremely difficult to achieve adequate running clearances for 21mm wheel sets within the splashers and valences.  Suppliers like Brassmasters supply replacement etched splashers for modellers intending to re-gauge Bachmann LMS 4F and 3F 0-6-0s from OO to EM or S4.
I assembled a number of SSM J15s 0-6-0s and GNR 4-4-0s to 21mm gauge with EM profile wheels and found splasher/crankpin clearances quite tight, it would probably be necessary to reduce the gauge to 20.2mm if you use the wider RP25 110 wheels used in the majority of current rtr chassis.
A 3D printed Irish steam outline loco and chassis should be doable in OO the main challenge would be finding a printer (person or machine) capable of printing to a similar tolerance to plastic injection moulding or die casting.
  • Agree 1
Right, folks, we’ve info.
Allen can do an etch for an Achill D16 for around £70 / €85.
It would take only a few weeks once adequate drawings were sourced. I will investigate this.
Once I’ve done that, we can talk about money and definite orders.
Perhaps if people email or PM me to say they’re definitely in?
If this works, a MGWR six-wheeler could be next?
(jhb171@gmail.com)
Roger @alphagraphix may be of some help: he certainly got as far as designing enough of a D16 to do a few 7mm scale etches, which @David Holman used to produce his lovely Wolf Dog. I imagine it will need to be an etched chassis - rather than RTR adaption. Having rods and chassis designed and etched together would help reliable running..
Edited by Galteemore
  • Agree 1
Currently looking at rtr possibilities for the A and C mgwr 4-4-0s and there's the significant issue of there basically being nothing with 6'3 drivers or smaller anyway, so it'll need to be an alternative.
Edited by GSR 800
  • 1 month later...
Just an update on this; minimum six needed to proceed. Only 4 absolute definites, so unless more appear I don't think I'd be going ahead with this.
Guess the D16 didn't appeal quite enough?
Suppose so. Should further interest arise at any stage I will do an "ask-around" again, and if enough commit I would go back to Worsley. Pity, but we can't have everything, and theyt were few in number and very limited in where they went.
They were rather niche. Would also have presented some significant modelling problems. Small 4-4-0s can be problematic to motorise and balance - even in 7mm you may not get away with a conventional motor gearbox combo. The GN J-class, for instance, requires a rather expensive 3-stage set of gears from ABC  as pictured. Belpaire boilers make life a little easier but a round-topped firebox rather limits your wiggle room.
Yep, my Achill Movie cost me £125 for an ABC/Canon gearbox and motor in 7mm scale. Haven't really thought about it, but maybe tender drive, via a shaft to the loco drivers might be an option in 4mms scale?
 Very pretty loco in MGWR green, though less sure about later rebuild and grey livery.
In my experience with the G2 2-4-0 and D17 4-4-0 a greater preference among 4mm Irish outline customers for complete kits as opposed to a set of etched parts.  Although I would have preferred to supply both locos as sets of etched parts, the majority of customers expected the locos to be supplied as complete kits and not prepared to buy a set of etched parts only.
Based on sales of G2 & D17 kits its likely that there is demand for 10-12 complete kits of the D16 Class at a price point that will cover manufacturing but not design cost.
Interestingly I produced 3 different versions of the G2 the late MGWR & GSR/CIE round topped boiler versions sold in broadly similar numbers, while demand for the Belpair Boiler version was significantly lower.
Motorising and balancing a D16 on the principals used by Alan in his BCDR 2-4-0 and my G2 & D17 kits using a High Level Gearbox and a weighted tender should not be a significant issue.
Edited by Mayner
  • Agree 1
Thanks John. I’m just finishing off my first ever 4-4-0 and have already found that I need to boost the front spring to lift the frames off the bogie. I’ve built a weighted tender as per Sharman. Will be interesting to see how it all plays out….
In case it is of interest, the firm I use for etchings is 4DModelshop: https://modelshop.co.uk/Static/WorkShop/Photo-Etching
For a conventional kit-maker producing tens or hundreds of copies of something, they would be too expensive I'm sure.
But they are prepared to do quantities as small as 1, and I find the quality to be very good. Delivery is usually about a week from placing the order, and Iain (their etcher) will check the artwork and offer feedback or make corrections if he can foresee any problems. So, as with any product, there's a balance of cost with quality/speed/minimum order.
As an example, my E401 class etch is an A4 size sheet of 0.25mm nickel silver. (Other sizes, thicknesses and materials are available - see the web link above)
The costs came out like this:
  • Artwork setup £20.60 +VAT
  • Filmwork: £57.70 +VAT
  • Etch: £49.10 +VAT
  • Delivery: £8.08 +VAT
  • Total: £162.58 inc VAT
However, more than half the cost is the setup. If I wanted more copies of the etch done then the cost per etch would be the £49.10 + VAT + delivery, which comes out just under £70 total per etch assuming they are posted one by one.
So, you might consider that approach for small quantities of your D16? You would need to have or draw the artwork though, which is a time-consuming process but can be quite enjoyable.
Mol
  • Informative 2
Interesting idea David. I suspect the challenge would be making the shaft connection between loco and tender flexible enough to allow the combination to track properly. With my current project, the BCDR 2-4-0, I've placed the DCC chip in the tender so as to allow more room for weight in the loco. This requires 4 wires between loco and tender (2 x pickups, 2 x motor). In my first attempt, the wires were too stiff and interfered with the tracking of the tender - front wheels were clear of the rails on occasion. Finer wire solved the problem.
The old method employed by Hornby - motor in the tender driving the tender wheels with a passive loco simply along for the ride - might be easier to do.
Having said that though, in my experience, putting hornblocks on the front carriers and the front drivers and a compensation beam between them - effectively treating the 2-4-0 as an 0-6-0 - seems to address any issues of balance pretty effectively. A bit harder to do with a 4-4-0 where a bogie is involved but not impossible.
2 hours ago, Tullygrainey said:
...The old method employed by Hornby - motor in the tender driving the tender wheels with a passive loco simply along for the ride - might be easier to do.
The Continental HO makers still do this, particularly for German-outline tender engines. It looks bizarre to see a tender being able to move by itself!
