BosKonay Posted July 26, 2013 Posted July 26, 2013 http://irishrailwaymodeller.com/showthread.php/2195-Brace-yourselves!-CIE-Dapol-Coaches Quote
108 Posted July 27, 2013 Posted July 27, 2013 Hi. I picked mine up today. The coach is a non corridor lav compo. The colours match up well to the Murphys coaches. Another body version to add to the rake. Quote
Flying Scotsman 4472 Posted July 27, 2013 Posted July 27, 2013 Marks said they would do a 70s cie version if their was enough interest and the green ones sell. I seen photos somewhere of suburban black/tan coaches like the Dapol Quote
Glenderg Posted July 27, 2013 Posted July 27, 2013 (edited) Marks said they would do a 70s cie version if their was enough interest and the green ones sell. I seen photos somewhere of suburban black/tan coaches like the Dapol  I know it's black and white, but you can clearly make out the black and tan livery. Prototype for everything eh !? I'd certainly be interested in them.   Richie.  Edited July 27, 2013 by Glenderg Additional Link Quote
BosKonay Posted July 27, 2013 Author Posted July 27, 2013 Black and Tan would certainly be interesting!! Quote
Warbonnet Posted July 27, 2013 Posted July 27, 2013 Would be more interested in Black n Tan than Flying Snail TBH. Quote
108 Posted July 28, 2013 Posted July 28, 2013 Black and Tan would be great. Third and brake third for suburban use Quote
jhb171achill Posted July 28, 2013 Posted July 28, 2013 There was one set of these old veterans (in black'n'tan) used for summer excursions as late as 1974, after which I think they were withdrawn. One of them was ex-GSWR 1287, currently in use as staff room / operating manager's office at Downpatrick. This last set was based in Dublin. The black and white photo is of these. The colour photo was taken on the 1964 all-Ireland joint LCGB / SLS / IRRS steam tour. The coach shown is a former GSWR dining car; the rest of this train was composed of laminates. Â Until the mid 60s, wooden coaches were occasionally to be seen in main line trains. While no passenger carrying six-wheelers were ever repainted into black and tan, at least two ex-GSW six wheel passenger brake vans were; one even had gangways fitted. This coach, GSWR 69, is now also at Downpatrick undergoing a gradual rebuild into a more traditional pattern, but reincarnated as a brake first. Â The dining car shown in the second pic was still at work in the late 60s. Â On a model layout, accuracy would be represented best by a single wooden coach in a set of laminates / Bredins (though probably not Cravens); or if it was based in the greater Dublin area, or that of a fictitious large city (!), maybe a rake on excursion work. If it's mid 60s, there could be one still in green..... Â I'll stop dreaming now; the cat has to be fed! Quote
jhb171achill Posted July 28, 2013 Posted July 28, 2013 Excellent shot. On left, a GSW composite of 1910-15 era. On right, a non corridor GSW suburban brake 3rd, similar era. Quote
heirflick Posted July 28, 2013 Posted July 28, 2013 (edited) ] Â :drool:thats a fantastic pic! Edited July 28, 2013 by heirflick Quote
BosKonay Posted July 28, 2013 Author Posted July 28, 2013 What a photo! What an era for Connolly ! Quote
colmflanagan Posted July 29, 2013 Posted July 29, 2013 I travelled from the city centre to Blackrock regualry in 1969 -70 and one set had a compartment brake 3rd at each end of a rake of four Park Royals, all in b&t, usually pulled by an "A" class in black. Full of splendid sounf smoke and fury but not a lot of performance. The legroom in the compartment coaches was very tight, and the ride pretty poor also by that time. Â Colm Quote
WRENNEIRE Posted July 30, 2013 Posted July 30, 2013 Some pics to compare the coaches MM/Bachmann ones on the left, Marks on the right Strangly enough both coaches pictured here have the same running number 2096 Roof detail, Marks on the bottom   Both coaches are the same length and height   Corridor and non corridor (Marks)   Opposite sides   Close up of Marks   And opposite side   Bachmann one picked up in 01 at £19.99 punts, generally go for around the €50 mark So at €29.99 this is great value One small crib, plastic wheels, but it should be easy enough to replace them with steel ones.  Quote
jhb171achill Posted July 30, 2013 Posted July 30, 2013 One of each in a rake would look good. By the time CIE came into existence, a train of all the one type of coach, as nowadays, was as rare as hen's teeth. Just one of each type above, with a Bredin, a Park Royal, an old six wheeler and a tin van would be about right for most layout uses of that era! Quote
colmflanagan Posted July 30, 2013 Posted July 30, 2013 Is it just me, or is the bottom stripe on the Marks Model one wider than on the Murphy Models? The photos I've seen of this early era CIE livery suggest that the bottom stripe was actually narowwer than the top one. But maybe there were variations. On a running note, have Dapol fixed the terrible "wobble" which these ex Airfix (showing my age now!) coaches nearly all had? I did find a cure but the much more solid running qualities of the Mainline/Bachmann coaches led me to favour them. Â Colm Quote
jhb171achill Posted July 31, 2013 Posted July 31, 2013 It's not just you, Colm! The lower band on the real thing was indeed narrower, while that on both thosed models is way too wide. These light green bands were edged in gold, as was the snail and the numerals. On the post-1955 lighter green, the narrower waistband, numerals and snail were unlined.This later version had no light green band above the windows. Quote
cg-antrim Posted August 14, 2013 Posted August 14, 2013 I see the Mark's Models website says that "THIS MODEL IS NOT AN ACCURATE REPRODUCTION, BUT IS SIMILAR TO COACHES OF THIS PERIOD" (http://www.marksmodels.com/?pid=17293). That being the case, which is the best coach to use ? I'm really most interested in the late 1940s but am a bit perplexed. Thanks, everyone. Quote
heirflick Posted August 15, 2013 Posted August 15, 2013 (edited) cant wait to see the black and tan liveried version!! Edited August 15, 2013 by heirflick Quote
Weshty Posted August 15, 2013 Posted August 15, 2013 cant wait to see the black ant tan liveried version!! Â Amen to that brother! Quote
minister_for_hardship Posted August 15, 2013 Posted August 15, 2013 Got mine the other day, but it's going back. One of the 'snails' seems not to have been applied very well, little gaps in it. Quote
minister_for_hardship Posted August 15, 2013 Posted August 15, 2013 I see the Mark's Models website says that "THIS MODEL IS NOT AN ACCURATE REPRODUCTION, BUT IS SIMILAR TO COACHES OF THIS PERIOD" (http://www.marksmodels.com/?pid=17293). That being the case, which is the best coach to use ? I'm really most interested in the late 1940s but am a bit perplexed. Thanks, everyone. Â No RTR coaching stock model will give you precisely what ran on CIE back then. Â You'll have to start building kits or bashing an existing model to the best of your ability if you want that level of accuracy. Quote
