New Layout Plans
Things run alright on it
When I got it it turned out to be the wrong radius so it's slightly modified, I am going to add some precautions just to be sure :)
  • Replies 163
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Hi guys
I did some ballasting during the week
It's a bit heavy in places but that's not impossible to fix:)
In other news I've begun to scratch build an 071 with plasticard and am converting one of my mk 4 conversions to a cafe/bar mk 3
A4E9C1A2-87AD-4453-A2DF-764B44C05E5C-3129-0000053589E480E2.jpg?t=1346691675
A9290FFA-5E78-49EC-8F6F-1EE10C610BED-3129-0000053581D5FF91.jpg?t=1346691666
E32249BA-86C9-4943-B222-418DD15929BE-3129-0000053575AAADEB.jpg?t=1346691664
249D8D31-5365-485A-9E5A-419B940B05AA-3129-000005354C193ED8.jpg?t=1346691658
I've also started on the mould for the concrete
I think you need to redo this bit as I can't see to many trains passing over this section there's to much of a sharp angle on it you may need the bigger diamond crossing.
[ATTACH=CONFIG]2437[/ATTACH]
The trains go over it fine
I only have a problem with one engine and that's it
That's amazing I don't know how they cross over that anyway this is what you need http://www.ehattons.com/7740/Peco_Model_Railway_Products_SL_94_Long_crossing_insulfrog/StockDetail.aspx
They cross over it because I have put a small piece of track on the fishplate and that fixes the problem for all of my stock except my Hornby Dean goods ,which has a very big wheel and only sometimes derails, and I will add some more safety features just to be sure
When you say all of your stock apart from the Dean goods goes over the diamond crossing,does that include all freight stock and coaches? It could well be the angle of the photo,but it looks too sharp to me to accommodate a rake of wagons without a derailment.If all of your stock cross over it without a problem,then happy days!
Yep I think everything passes over it it also a bit down to the speed and the way I push the wagons/coaches/locos along as the points aren't yet powered and the crossing is between two of them
Guest hidden-agenda
Short term gain long term pain, you should think about relaying that area as its going to cause a head ache in the future plus it does,nt look good at all.
The other guys have given you really good advice and I will agree with them that in the long run that is going to cause problems. You may think it is OK now but it won't be when temperatures change and things begin to move. For your own sake and any other future problems change it now and save a lot of hassle in the future. Anthony's given you a good link to something that will solve the problem and it is well worth doing. Other than that it's looking lovely and you are making great progress.
Rich,
Taking your advice lads I have gotten rid of the crossing and have probably improved easy running
Where the old crossing was
020E9F0B-85AB-4334-BF85-CC4E6A2B621B-6650-0000082841F8F906.jpg?t=1347214802
To the top right is a loco siding for station pilot
3D892538-7470-41BA-9F6D-F950F93279EE-6650-000008284C0AAA9E.jpg?t=1347214812
0F6040BE-EDB2-491D-9E5C-4E5259C84A21-6650-000008285A567AE4.jpg?t=1347214818
C34AE87E-060B-4C60-9534-4A35E47853D7-6650-0000082854C488ED.jpg?t=1347214800
What do you mean? :L If you're talking to me!
'Tis your status <--- under your name - you turn into a Guru at 500, it seems - it means that can only post when you're wearing nothing more than a loincloth..
  • 4 weeks later...
Hi guys I recently was given this engine
527BEC34-5756-4A3F-8963-819FC46B50B1-2554-00000408282DEC75.jpg?t=1349524774
and I have absolutely no idea what it is ,only it has a flying snail on it
A3C3BB24-07DF-444D-9D9A-4BCDDB823315-2554-0000040844E3C674.jpg?t=1349524933
I layout news nothing new has happened in the last month
I've only done a few little things as opposed to my plan to be doing the point motors now
The only news is that I've decided to g back from using Roco coulpers to using Kadee's and that I've made the track on the long curve where the station will be more parrallel with each other and tidied up the ballasting
It came in a Hornby set with a few wagons, Mr. Bracken will be able to give you more info. It was loosely based on a British GWR prototype I believe and has been churned out in all different liveries.
