Ssl
The webserver now pushes all traffic to a HTTPS / SSL encrypted version.
There should be no tangible impact, other than improved security and more favourable google-ness.
Do please let me know if you spot anything odd(er than usual around here ;) )
Any one having problems logging in, I'm finding I have to go to a thread, select reply then the login pane opens. Any suggestions. TDR
Same here - I logged out and wouldn't have found the way back without that hint - phew...!
I'm 'remembered' now - I hope.
The login box just doesn't come up, unless you follow the line above from TDR.
Bos, login pane is not appearing when you select login. I have used the same method I used earlier. Having then selected the remember me option I logged out and in again successfully. Will try logging in again later this morning. TDR
Can you try log out and back in again, if that doesn't work can you add a screenshot of what's happening?
Hi Stephen. FYI, it is working fine with the 'IRM old style' theme because the login UID + PWD are part of the page header and work ok. On the two newer styles 'Irish Railway Modeller Fluid' and 'Irish Railway Modeller Fixed' the 'login' link does nothing. Hope this helps. Noel
PS: Recommend to other users do not log out, or if you do switch to 'IRM old style' at the bottom of the page and then login using the user name and password boxes on the page header.
PS2: Possibly an issue with the cookie URLs on the newer themes (i.e. http: v https: in the cookie or login url page anchor paths).
New Style URL for 'login' [noparse]https://irishrailwaymodeller.com/#login-box[/noparse]
PS: The mobile theme also is working for login.
Edited by Noel
As a work-around if you tell your browser to 'accept' the insecure bits of the page, or accept to drop protection for now, it should all work fine, until i find the offending files :)
Login thing doesn't work for me either.
Same for me, to log in I have go into advance search. The login box does not come up automatically .
  • 2 years later...
Thanks Broithe,
It's now also possible to create accounts with Twitter logins (in addition to Microsoft and Facebook) and you'll be able to sync Status updates on Facebook and Twitter to your status here if you wish
