Foolish drivers
  • 3 months later...
  • 2 months later...
Re. bridges; there's a simple solution. Build those extremely rigid steel bars across the road either side of them. Thus: driver wrecks his vehicle on contact, but railway unscathed*.
With automatic half barriers, replace with those retractable bollards, which up-end anyone trying to dodge them. All will take money and time, but if done, offers a permanent solution.
(* ...unless it's the Nenagh branch, in which case IE will rub their hands in glee at another excuse to close it for six months "just in case"....)
  • Funny 1
http://www.irishrail.ie/news/bridgestrikes-enterpriseireland
Yep - big stout steel frame either side of a bridge at the level of the bridge would do it. I like your idea for the retractable bollards for LCs, only this would be very very expensive & time consuming to do
Kiltartan crossing destroyed by a van.
It boggles the mind how the driver did not see the triangle of three flashing red lights on both sides of the road. The cyclist had the advantage of hearing if a train was coming which would have been unlikely within mere seconds of the barrier coming down. I understand there is a fail safe system that alerts trains if the barriers are damaged or not down properly. Must cause a great time inconvenience to passengers while the scene is cleared for the train to continue on its journey of at all.
  • 1 month later...
I was going to post these pictures of a West Coast Main Line bridge that I took having a wander about after the Haywood Exhibition, with a comment along the lines of "It's only likely to be hit by the odd mountain bike - or, maybe, a pushchair in the drier weather". Although, it does look substantial enough to survive either of those.
On 26/10/2017 at 2:09 PM, Broithe said:
Mmm, the UK has a bridge-strike spike in the last week of October - it will be interesting to see what happens next week.
Well, there you go - one straight away.
  • 4 weeks later...
  • 1 month later...
4 hours ago, Broithe said:
Yet another...
It baffles me....all drivers of hgv's are required to know their load height, plan the route accordingly  and they can see the signs with the bridge height - some even flash a warning that they are to high so where is the problem?  scratching head smiley
Quite often, it looks like they've "only just caught the bridge" - I wonder if people rely on the stated bridge height clearance being a little pessimistic.
You could be on the ball there!winking thumbs up smiley
  • 3 weeks later...
  • 4 months later...
Bridge strikes all over the place lately - even Ballybrophy - there's only a couple of very small underbridges that I can think of in the vicinity, but I suppose you could also hit the parapet of an overbridge...
  • 2 months later...
Unfortunately seeing something like this doesn't surprise nowadays. Some of the driving I witness on a daily basis along with their attitude to the rules of the road is beyond belief. Luckily these type of planks are in the minority.
You have to suspect that the car was stolen and/or driven by someone who had overestimated his capacity for pharmaceutical products, probably those of an amateur origin.
.....in which case the food chain has even less use for the driver. Bring on the double headed 201s!
