TimO
Everything posted by TimO
CIE locomotive livery variations 1960-1990
TimO replied to jhb171achill's question in Questions & Answers
@jhb171achill In the first post on this thread you state that following A46 being painted in dark green with light green band there were another 12 A class locos (numbers listed) that were painted in this livery. Is this correct or were these other 12 in a slightly different dark green? Secondly you make no mention of any of the light green locos having a painted waist line. Did any of the light green A class have this eau de nil waist line or was that only on the light green C class? While looking for examples of above I came across two photos in the book “Irish Traction in colour” by Derek Huntriss. Page 59 shows A46 as modelled by IRM and page 83 shows a very clean A19 in the livery A42 is modelled by IRM, even the black staff snatchers are as prominent. Only a light weathering required on A42 but in many photos the light green livery looks much lighter green, for example A41 on page 58 of the same book. Was that because it faded alarmingly or was there a third shade of green? -
Self propelled cranes and small coasters
TimO replied to David Holman's question in Questions & Answers
Not too different to Arun Quay then! Going back to Westport, I don’t know the exact details of the mill in question. However I would hazard a guess that it is much later than the c1900 implied by the sequence of photos though I believe the others might date from around about then as there is not a motor vehicle in sight. In about 1934 the Irish Government started an economic war with Britain and as part of this a lot of industries were grant aided so that the state could become self sufficient. These included flour milling, grain storage and the sugar factories. Given the style of architecture of the mill with the mass concrete and especially the horizontal design of the windows I believe it dates from this period along with Milford Flour Mills in Donegal and a number of others. It is clearly not shown on the 1913 map. -
Wexford Model Railway Club Festival Open Day 2021
TimO replied to Irishrailwayman's topic in What's On?
The views of Bog Road level crossing show just how much detail can be modelled in a relatively small space and still have a continuous run, I didn’t fully appreciate its size until I saw this photo:- 98 replies
- 6
- model railway exhibition
- trade stands
- (and 3 more)
Does anyone have a track plan of Ardee? That was goods only for a time and might suffice.
Could you show us pictures of the model please! I am very pleased to see that the Supertrain livery colour looks just the shade I recall and the loco seems to have a beautiful realistic stance on the rails, even the narrow track gauge does not detract. As a matter of interest what are the dimensions of your layout?
One feature that always strikes me about the Mills’ designs are the significant number of openings for windows and doors. As the ‘horizontal’ black and red brick courses always travel around these openings we get the very distinctive style. This horizontal theme continues with the horizontal planking on the wooden building structures and follows the linear flow of the stations with platform, track and fencing.
Good to see the progress on this layout. The buildings are looking at home here. As Noel says I see the DMC school of wiring but are you using DCC controlled point motors or have you control modules to install. I’m also interested to know what length of train can use the platform? Is it designed for a GWR ‘B’ set?
- 68 replies
- passenger & goods traffic
- steam era
- (and 3 more)
Eoin, Fantastic detail and planning, perfectly executed again. Great to see this progressing. Tim
Adding to the above and after a lot more research the TARIC code for imports is a 10 digit number made up of HS code 6 digits, CN (Combined Nomenclature) 2 digits and TARIC 2 digits. When you enter the TARIC database and select section XX, chapter 95 and then code 9503 0030 for model trains this number will be in blue and underlined indicating it is a declarable code, you might think this is the end of the story but you must hit return on this which brings you back to the first page and now displays the TARIC code as a full 10 digit number 9503003000. This last step is not intuitive but is described in one of the user guides. Hope this helps and perhaps the suppliers need to be advised.
George, When you look up the EU website for TARIC codes they clearly show an 8 digit number such 95030030. There is no mention of 10 digits for imports. What are the two additional digits and where should they be placed? A bit more research and I found out the answers. See subsequent post.
@mmie353, if your loco has been in storage you might want to check the backs of the wheels and the pickup contact points are clean and not covered in oil. Unlikely they are all affected but you never know until you test. Checking continuity from each wheel to the pcb is the place to start.
Once the container train is on the Alexandra Quay sidings there is a loco release cross over so the loco can change ends and draw the loaded wagons back to North Wall Yard. On the Tara’s I believe the loco is released using the traverser in the unloading shed. The loco then uses the empty wagon line to access Alexandra Road. The length of the sidings limits the maximum numbers of wagons in the Tara train.
You say that the motor biggie is locking. Does this happen on straights or curves or always at the place on your layout? Does it happen when travelling both backwards and forwards? Have you turned the loco over and looked to see if you can see anything that might catch? I have a C class where the glue holding on the bogie sides formed a glue string that acted as a brake and prevented the loco running properly in one direction. As others have said, more information would be useful. You may have to separate the body but as it’s glued on this is not a very simple task. Let us know how you get on.
Definitely interested. I would purchase one.
Thanks for the detail, lots of frame spacers there. I will follow this build / rebuild with interest. Good to see the Kadee planned in here from the start.
Eoin, I have just read through this thread from the start, very interesting detail on what at first might seem like a straight forward project. I was particularly taken with the section on your notes, it just shows the amount of planning that’s done before you start. Am I correct in thinking that I even saw where you made a jig just to position the hole for the nut on the boiler dome in the correct place? What precision! I’ll shall be following carefully to see how you progress with the authentic side frames with openings, will you be able to maintain enough strength? Your idea with the axle tubes is intriguing but I wonder will the bottom of the frames tend to splay outwards. I’m sure you have a solution to that, perhaps with the mounting for the pickups. In the photo of the prototype it looks to me that the centre axle is closer to the front one than the back one, are you building the new chassis to prototype dimensions (wheelbase) or sticking with the Mainline ones to match your superdatailed body? Tim
Beautiful detail on the footbridge. They are an icon of many Irish railway stations.
Another very interesting thread. Have you used Humbrol paint for the red brick? It looks quite light in colour on here, is that what you planned or is it darker in reality? The signal box looks very large for a twelve lever frame. The directors must have been in generous mood the day they signed that one off! Love the interior detail. As others have said your buildings are perfectly constructed and look fabulous, I am sure I’m not the only person on here that is eagerly awaiting your track plan.
- 68 replies
- steam era
- (and 3 more)
Something new this way comes, from Accurascale
TimO replied to BosKonay's topic in British Outline Modelling
Cracking video. Can’t wait to see what the models look like in the flesh. Do you know when the BR ones got their green livery? If you manage to produce the model with all pipe work, pumps, brackets, spring hangers etc in full 3D that will make it stand out from the crowd. -
The renderings look fabulous. I look forward to seeing the first engineering samples.
There was also a tar/ bitumen unloading facility in the Conniberry sidings in Portlaoise. The Laois County Council tar lorries used to reverse into the building below rail level to be filled. The building still exists. It was certainly used in the 70’s and there were regular fires, presumably from leaking bitumen. Does anyone know how the heating coils were kept warm in traffic or were they only connected in the depots?
Hi Ken, I don’t know much about the origins of the MCW but is it possible the order was placed in 1856 with one of the constituent companies and the photos were given a later date. I have seen this postulated for other drawings in the HMRS archive. I am very impressed with your cabinetry and your etches. Looking forward to seeing how the ballast wagons turn out.
