ttc0169
Everything posted by ttc0169
  1. Wooden scotch blocks -no ropes attached.
  2. Sounds very familiar there Rich…
  3. A superb prototypical formation from the 1990s-well done warb..
  4. And here it is hauling the IWT liner train to Ballina-it was the first HVO liner train in Ireland
  5. Nothing so far Denis.
  6. Sulzer locomotive 107 has been reactivated and has been restricted to work only with the permanent way open and flat wagons on Tara junction.
  7. 47404 works a ballast hopper train out of the up loop after the passage of an oil train 37118 works an oil tanker train and was replaced in the up loop by 37264 20172+20001 work an MGR train on Ashburton grove.
  8. After a suggestion from Philip Clampett and photos of the real “bubble”railcar 2751 from Colm O Callaghan-I set about altering a centre car from a three piece ICR,I had converted from a Bachmann 170 to the single car unit 2751, Thanks to the gentlemen named above-2751 operated a test run from Inchicore to Limerick and return this evening, The unit is seen here passing through Tara junction.station heading back to Inchicore.
  9. You’re a bit too young at the moment,you are correct minimum age is 16.
  10. Thanks Davenport-it’s the EMD power unit in 001.
  11. Locomotive 001 works the Tara junction.steam crane through the station-the superbly detailed Irish Railway Models open and flat wagons along with a brake van make an ideal companion to this late 1980s scene, Well done IRM and Gareth Brennan for the brake van.
  12. My ones arrived yesterday.
  13. To acknowledge the efforts of Sean Brown for his preservation and museum in Castlerea -maybe a model of his A class-A55 in green livery would be a fitting tribute to him. https://www.hellskitchenmuseum.com/
  14. Any chance????
  15. 001 in Supertrain livery with the black roof….
  16. Delighted with my PWD open wagons-well done yet again IRM. Keep up the great work.
  17. PWD open wagons arrive on Tara junction behind pioneer A class locomotive 001.
  18. No flats arrived either….
  19. 47404 settles in on Ashburton grove,it is seen here working the Stanlow-Leeds laden oil tank working.
  20. Friday 31/05/1994,-summertime at the junction-we see… 112 working a Connolly -Belfast service 133+143 work a BELL liner from Northwall to Waterford 174+130 work a Sligo-Northwall BELL liner 054 work a Ballina branch Park Royal set. Thanks again to @Past-Avenuefor supplying the French style tail lamps that are fitted to the rear Park Royal coach-one of which is actually working…
  21. And the later Telecom Eireann vehicles too…
  22. Had the same problem with Rail Express so I decided not to renew the subscription.
  23. May he rest in peace
  24. Another new addition to the aircraft fleet is British Airways 747 G-BDXA-it is seen here taking off from the airport while en route to San Francisco.
  25. Apologies Dave-code 3 decals done by Micheal Walsh.
