murrayec
Everything posted by murrayec
  1. Hi joe123 You can get them on Expotools;- https://www.expotools.com/ and Amazon, or in Marks but call them first! This is what it looks like;- https://www.google.com/search?q=pin+point+oiler&tbm=isch&source=univ&client=firefox-b-d&sa=X&ved=2ahUKEwj1_bPTtI_hAhV0s3EKHbafAaoQsAR6BAgJEAE&biw=1280&bih=891 A light oil preferably plastic safe, the oiler you buy generally comes filled with oil, though you can buy them empty. I've used the Expo one and the oil was OK..... Eoin
  2. @David Holman There's a scene in the station on the layout- two chaps in caps doing the light filling thing? I think I'm liking inverted buckets a bit better now..... Eoin
  3. Hi joe123 A very small drop of oil to the wheel axle bearings from time to time- clean out old oil with a swab of kitchen towel held in a fine point tweezers, and look for hair and the like wrapped around the axles and remove it. Again only a small drop of oil on the axle adjacent the bearing avoiding the wheel if possible, a pinpoint oiler is the best man for the job....... Eoin
  4. I don't like the inverted bucket roof look, I'd go with torpedo ventilators and internal lights I also pondered on those tripod items;- they could be ventilators?, or as popeye says they could be lids? or the buckets are the lids and go over the tripod? or the wire/chain to the top of the bucket might be a control wire operated through the ventilator?...... Eoin
  5. Thanks Guys for all the comments fl It's going to be black n orange white stripe above window Eoin
  6. Alphagaraphix address = 23 Darris Road, Shelly Park, Birmingham B29 7QY. Eoin
  7. Well back to the laminate build! All soldering and gluing is now complete, a little painting prep now being done- I'm using Lidl W5 Limescale Remover to clean up the brass, it does a neat job removing oxidisation and flux. The first few panels of the roof have been brushed over with W5 with a paint brush and washed down with water- sparkly! After a scrub with washing soda, next were painting........... Eoin
  8. Nice find & buy @David Holman Your post reminded me I picked up a nice find also- a Lining Wheel Bow Pen for €5.00 Comes in a neat folding case with pin lock for putting in ones top pocket, Ivory type handle and a bow type affair to load the ink. Three interchangeable wheels;- dot dot dot, - dot dash dot, - & dash dash dash, the handle unscrews to reveal a pin! could be for loading the ink or for correcting mistakes? I plan to make a few continuous wheels, but there is only 1mm width where the wheel goes through the bow- so .3, .5 & .7mm maybe. Back in its box..... Eoin
  9. I saw this back in 2017 not sure of the levels now! Article from 2016 ''Bachmann sells half as much as Hornby does in EU'';- https://masterinvestor.co.uk/equities/why-has-hornby-come-off-the-rails/ Eoin
  10. Lovely looking loco popeye. Eoin
  11. Main frames now laminated and clamped down to the bench for the day, just in case they might want to take a warp! Next step is to mate up sides and ends for dowel pin hole drilling and to route the wire slots ...... Eoin
  12. Hi Cm It was made by Tyco Model Trains and is HO scale, here is a link to a bit of history about Tyco;- http://hotraincollector.com/mantua-tyco-streetcars/ Eoin
  13. I'd like one of those for on the road! very handy for those chaps that cut you off in the traffic! Eoin
  14. Hi Dave This in a Gauge N baseboard module which is the same construction design as the one above except;- it was constructed in cheepo 6mm ply with the 40mm insulation for the deck but has no laminated internal frame like the one above. The flat gusset piece in the corners are glued to the frame and to the underside of the insulation, the insulation is glued in with 'No More Nails' glue on the 40mm edge which makes the board fairly rigid in all directions, each module weighs in at 2lb. These boards fit end to end. The end plates are doubled up with a rectangular slot to take the support system, fixing two boards together involves sandwiching the support leg between the two boards in the slot and using a C clamp to hold in place. These units can go on a table or use their own support system! but I found it was to light and liable to be knocked over so had to add Lidl lifting weights to the leg bases. Eoin
  15. Hi Irishrailwayman Yes hot glue is handy, but the majority of this system is laminated construction, there is a laminated inner frame for strength- when this baseboard is at home it will be assembled and hoofed up to ceiling level in my sitting room- for easy access and maximum fun! Hot glue wont work for laminating so PVA & nail gun it will be... Hi Noel I have seen your glass fibre tape & PVA construction in your posts! I'm not to sure about this construction- PVA is a soft material and would not give the same rock hard finish that resin reinforced with the tape would do, which is what's normally used with glass fibre tape, what I thought when I saw your post was, if one goes to the trouble of taping the joins and painting on PVA why not go the whole-hog and use resin! and Noel when things are hot- 'don't Touch' as mammy always said Eoin
  16. I'm setting up a Gauge 00 Exhibition baseboard 2000x1100mm which will take up to a radius 3 track plan, my design is based on lightweight construction so easy to move around, a four unit system 1000x550mm each, two x two of the units will bolt together making two closed transportable units which will fit on the back seat of my car. The baseboard will also be set-up at home to play with and to test models that I'm working on. This is a drawing of one of the 1000x550mm units which will be constructed in 9mm birch ply, it will have a 40mm expanded styrene deck (not shown) to keep the weight down, there are four M8 bolt fixings through MS dowel pins in each unit, to bolt the four units together. This is the 20mm MS bar stock that the dowel system is turned from- 1 dowel pin and 2 sleeves for each bolt which goes through the dowel and clamps the units together against the sleeves, the sleeves will be permanently fixed into each unit. The bolt and dowel pin are removed when disassembling so nothing sticks out the side for transporting. After a bit of turning, though not finished yet. A dowel pin and the two sleeves, one sleeve still needs a flange and a knurl put on it. And the 9mm birch ply frame parts kindly & accurately cut by baseboard Dave. Boards this size cannot be worked on in my workshop so I have made a ply worktable that fits to the coffee table in my living room with T Slot clamping system to aid construction of this and other jobs. Other items like sky boards, support system and scenery are planned and will come along later. The scenery is going to be based around Dun Laoghaire, Salthill and Seapoint- I hope, with keeping the baseboard compact we'll have to see how things pan out! Now for a bit of gluing......... Eoin
  17. Excellent idea David, Looking forward to seeing this progress and how you handle the recycling transformation- an excellent layout that could go on for ever! JHB's book also inspired me to set up a drawing for a layout of the Achill station- one for the future...... Eoin
  18. Excellent Ken, The makings of a lovely little train, looking forward to seen them painted. Eoin
  19. Hi joe123 Here is a thought- what about removing the two acute bends and have the return loop there! that may be an economical solution. Eoin
  20. Hi joe123 If the temp road bed is held down somehow so that the chain cant push it up that might help! The chain relies on the under road surface to keep it down when there is to much friction. The reason the chain pushes up is because of friction on the bends- the chain on front is going slower through the bends than the chain following behind, the chain behind will go where the least resistance is- that's up if it can push the road surface out of the way! More motors and return loops on those acute bends should help with countering friction- but do try fixing down the road surface first and test again. It would be best if the chain glides around without the road surface on! Eoin
  21. Hi joe123 Thats a lot of Magnorail. When you say 'cant get the right tension on the chain' - what do you mean? Is the chain connecting up? or, Is the chain slipping? or, Does the chain run OK without cars on, and doesn't when their on? In the third photo I see a rather tight curve! for a curve that tight one should use Magnorail's return loop (modified) which will reduce friction. For 6 meters of soft curve rail you should have at least 3 motors- which may run up to about 6 cars. With the layout you have done and if you want to run more than six cars I would put a motor in per meter of track = 6 motors! If you use the return loop unit on the sharp bends or increase all sharp bend radius you may get away with 4 motors. Am I right in saying that you have two separate Magnorail tracks of 6 meters long each? If thats the case you'll need to up the motors on both! I know that might be not what you want to hear, but Magnorail is really designed for nice wide radius loops and small layouts! Eoin
  22. Another paint spraying jig. A 'two axis rotational jig with interchangeable parts cradles';- And turn it this way..... And that way...... And the cradle dismounted for the next part to be loaded! I've made four cradles of this type and a few more variations are on the drawing board yet to be cut out. Eoin
  23. Hi I have some knowledge on Magnorail- What is happening? What length is the Magnorail chain? if over 1.5m do you have more than one motor? What are the radius curves your using? Any other info you can give may help- especially photos of the Magnorail layout Eoin
  24. Hi popeye The test styrene side is scored with the Cameo Silhouette knife for the bumps so not like a model side's deep and wide relief, I used a few drops of PVA in the water as recommended by Railtec's instructions, they say this is preferred to MicrolSol, also to avoid MicroSet. I could not encourage the decal to sit down into the score lines but that might have been expecting to much! But the decal is pretty strong as I had to manipulate the lining with a stick and bud to get it in position with no tares, reckon it will work OK on the actual model sides. I have another styrene side which I'm going to put the high relief vents on and test again. Door handles and guard went on after the decals. Eoin
