Everything posted by skinner75
worth installing this little addon to your browser too: https://adblockplus.org/
Download Malwarebytes removal tool - this should remove it. https://www.malwarebytes.org/
I've used the Lidl soldering iron a good few times on the wiring of my motorbike - always done the job for me. That said, the tip is a bit knackered now. I've been meaning to pickup a variable temp iron. For assembling whitemetal kits, what lower temp range should I be looking for?
Advert for Metrovick, featuring photo of A3. Stick it in a frame and away ya go! http://www.ebay.co.uk/itm/METROPOLITAN-VICKERS-TRAIN-ADVERT-Magazine-advert-clipping-NOT-A-COPY-/161072144083?pt=UK_Collectables_Advertising_ET&hash=item2580a5ded3
Enough with the 201s - make with the 121 class!!!
Football is as corrupt as boxing - especially with Septic Bladder at the helm - little crook bastid
New Enterprise Livery
skinner75 replied to Dunluce Castle's topic in What's happening on the network?
Don't forget the 121 & 141 combo, which I reckon looks as good as two 121s. They also carried all the liveries the 141/181 did, plus the grey & yellow livery they were delivered in -
I've bought plenty of 201s, and anyway, these colours don't float my boat
Enough with the 201s - get the 121 class into production!
Looks like it isn't possible to do Shame, as I have the NCE Powercab myself http://www.rmweb.co.uk/community/index.php?/topic/80262-nce-powercab-changing-latching-keys/
Just thought this may be of use, in a workshop/maintenance depot scene. I was looking through Tindie, and thought to search for DCC, and found this https://www.tindie.com/products/gfetters/arc-welder-circuit/
Adobe Premier is meant to be very good. It doesn't care what format clips are in - avi, qt, mov, mpg, mkv - just loads them all in, and gives you an mpg file output when you are finished
- 19 replies
- nir railcar
- ni railways
(and 3 more)
Tagged with:
He does mention that his 36-557 was the latest revision - you probably got a previous revision that the retailer had in their stock
Interesting vid comparing the 36-557 to the Lenz 10321. Could just be a dodgy Bachmann decoder he got - Noel, you don't have any issue with slow running? Good channel this guy has for tips on all aspects of the hobby
Marks Models stock a dcc decoder with no sound for the 071 - preprogrammed for all the lights etc. Here's the link: https://www.marksmodels.com/?pid=14482
Good idea Noel, on fitting your pre-DCC locos with 8pin sockets instead of directly wiring the decoder onto the loco. As you say, makes it easier to replace in the future if needs be!
The number of pins used to connect them to the loco? ;-) I'd go for the 21pin one, as that what the Murphys locos use. I picked up a couple of different decoder chips from Hattons there last week, just to try em out, but haven't fitted them yet.
I opened up the power supply I got, and snipped off the existing power cord coming from the psu, leaving about an inch on the two wires coming from the board. I then got a 'kettle lead', and cut off the plug, and joined the live & neutral wires to the corresponding ones in the psu. This leaves me with a male kettle lead connector at the end. I will attach a female kettle lead connector to the baseboard, with the two point motors and toggle switches joined to the other end. This will allow me a quick but solid connection for hooking up power to the point motors. Before doing all the above, I opened up the psu block and tested it. I offered up wiring from an unmounted point motor, just to see if it would activate the solenoid, to the power output points on the psu - it did. The point motor sheet lists 16v AC as the power source, but the psu I'm using is 19.5v DC as mentioned earlier. I then fitted both point motors under the baseboard, after making sure they were spot on so as the throw bar could travel freely & switch the points above. That was a bit fiddly, but got done in the end. I have the peco wiring looms attached to the point motors just waiting to be joined up. I'll pick up the female/male kettle lead tomorrow in work, and that'll allow me finish off the electrical side of the layout. Next on my list is to find something I can mount the NCE Power Cab power connector board, and the two toggle switches into.
Found a load of big power supplies for laptop docking stations due to be sent off for recycling in work - 19.5V / 11.8A, so I'll grab one of these to use on the layout
After a bit of research, I've ordered a 'DCC Concepts ADS2 Solenoid Point Motor Accessory Decoder'. Looks like it gives the option of either DCC control or toggle switch control. Can be powered off the DCC bus too, or from a seperate power supply. It can only handle two points, but that's all I require so will do the trick nicely.
Cool, I'll take a look at the old supplies and see what the beefiest is & use that. As for joining up my board, I'll decline, as this is really just a test of the various skills more than anything else. That, and I don't drive a car, so transporting it by motorbike would be a no-no! ;-)
Hi all, I've just started my first layout, well second if you include when I was a nipper! It's nothing fancy, just a 4'x2' baseboard on which to set a 00 Inglenook, or shunting puzzle. I'm using it as a test bed for my first foray into DCC. Track is Peco code 100, with electrofrog points. I've one of Tam Valley's dual frog juicers to hook the two points upto. Currently have the track wired up to the dcc bus, and the loco can run to the end of all sidings & across the points at a crawl without stalling, so I'm happy with that. I'm using the NCE Power Cab for my controller, and find it easy enough to get the hang of. I picked up an 8 pack of bachmann 12t vans to use in the shunting puzzle. I tried popping out the tension lock couplers on them, and fitting kadee #19 couplers in their place, but they appear to sit a tad too low. Looking on the kadee site, they recommend #5 couplers for bachmann branchline wagons, so I've ordered some of them to try out instead. The #19 coupler appears to be at the correct height when fitted to a MM141, which is the loco I plan to use. I'm waiting on some on/off/on toggle switches for remote point control. I have peco point motors, the pl10e, to fit under the baseboard. On that, can I ask for some info on point motors and dcc? The point motors says to use a 16v supply, so is this seperate from the dcc bus then? I have access to plenty of used laptop power supplies - can they be used for powering point motors? Anyway, heres a link to my flickr page with pictures of progress so far, which I'll update as I go along
It's been a while, but I have two bodyshells left over from MIR 071 donors. Not 100% sure, but I think they are only the Athearn ones
