Everything posted by Mayner
Kildare to Connolly from late 2016.
Mayner replied to Broithe's topic in What's happening on the network?
I don’t know whether to laugh or cry it has taken IE 25 years to finally implement its 1990 proposal to introduce a suburban rail service between Grand Canal Dock and Clondalkin. The Heuston-Kildare Arrow service seems to have been introduced as a lower cost option with minimal signalling and infrastructure costs compared to completing Grand Canal Dock for its intended purpose as an interchange between the DART and Southern and Western suburban service. A second platform opposite Platform 10 would open up Heuston & the Phoenix Park and apartments and businesses in the Island Bridge area as a destination. Terminating Northern Line outer suburban services at Connolly would improve line capacity over the Loop Line Bridge. -
The Official Irish 'Might Have Beens' Thread
Mayner replied to minister_for_hardship's topic in General Chat
JHB. The GSR appear to have been plans to develop a 2-4-4T as its final steam design. The proposal is mentioned in "A Decade of Steam", the view was that it was a well thought out modern design similar in principal to the LMS 2-6-4T locos. Do you know if any drawings exist of this loco. -
Possibly an amalgamation of the MGWR, GNR & DSER, the NCC absorbing the BCDR and the GSWR absorbing the West Cork. There were supposed to have been rumours of a MGWR GNR amalgamation and the DSER wanted to amalgamate with the GNR in 1924. Possibly an Irish branch of the BTC had the whole island of Ireland remained in the UK , possibly some of the lighter BR standard steam types, the NCC / UTA engineers had invented the DMU ahead of British Railways. Harland & Woolfe might have become a serious diesel locomotive builder with a potentially wider market than the County Down & NCC. An Irish Railways Executive would have to develop its own diesel loco designs as most BR classes were too heavy for use in Ireland I am not sure if the Beeching cuts would have been worse than the cuts of the 50s and 60s, CIE, UTA & Stormont were years ahead of the UK mainland in closing railways
Oil headlamps on GM diesels, what was the point?
Mayner replied to minister_for_hardship's question in Questions & Answers
The oil headlamps were mainly to assist the signal man to identify the class of an approaching train, though most GSR/CIE mainline passenger and goods trains used to display the UK Express Passenger code (a lamp over each buffer) https://en.wikipedia.org/wiki/Train_reporting_number#Headcodes. The practice of using oil headlamps seems to have died out in the early 1970s when CIE introduced a computerised train control and the 1st stages of widespread CTC. -
Do the right thing and move the airport to Baldonnel or Saggart
motor speed control + rods
Mayner replied to controller's question in DCC, Electrics and Electronics
Controller Is there a makers name stamped on the bottom of the loco? If there is, it might be worth doing an on-line search to see if there is a photo of the same type of loco with valve gear and rods. Assembling etched coupling rods and valve gear can be quite tricky, accurately matching the wheelbase can be quite difficult and there may not be enough metal in the rods to open up the crank pin holes to fit around the bosses and crank pins on your locos. Alan Gibson and most British made rods are designed to fit over a 14BA crank pin bolt and bush (very small). If you want to experiment the Alan Gibson 4M92 Universal Adjustable coupling rod would probably be the best option. http://www.alangibsonworkshop.com/Catalogue.pdf, If you have access to a small pillar drill and accurately measure the wheel centres, you could try and make up a set of rods using KS strip or rail filed flat like the Workbench photo of the GSWR A1 4-8-0. Once you are happy with the running, you can file the rods to their final shape. -
Most likely the lack of resources up to the setting up of the Railway Safety Commission and Accident Investigation Unit about 10 years ago the Department of Transport employed only one Railway Inspector with very limited powers of enforcement Completing the report into Dalkey would have been low priority compared to the reports and follow up action in connection with the Buttervant & Cherryville disasters, and possibly Keeping some oversight over the DART, MK3 and major main line re-signalling projects.
Nine years later the investigation report http://www.raiu.ie/download/pdf/accident_dalkey.pdf
Proposals for privatising the road network have been kicked around from time to time in New Zealand http://transportblog.co.nz/2014/03/09/privatising-roads/ but usually dismissed as to extreme even by centre right political parties. In other words privatising the roads would be political suicide, while the majority of voters would not be too worried about privatising justice, health, welfare and education. Personally I would agree that the rail infrastructure and passenger stock would remain in state ownership, passenger and freight operation opened up to competitive bidding. Access to the network should be charged out on a similar basis to the roads and there may be justification for subsidising certain passenger services on the basis of reduced congestion, environmental or road maintenance costs. An incumbent monopoly operator whether it is the state or private tends to take a defensive approach towards running a business and abusing its monopoly position. Opening IEs passenger services to competitive tender based on service level for a given level of public subsidy might actually resulted in an improved level of service, providing tax breaks for freight forwarders and ports like Waterford or Foynes-Limerick and making rolling stock available to open access operators might actually open up the rail fright market
The US has H&S Legislation and the legislation is enforced: https://www.youtube.com/watch?v=RIl0BM0ZEE4. There is even a similar overlap to the UK & Ireland between the rail and occupational health and safety regulators http://utu.org/worksite/PDFs/safetylawsummary/OccupationalSafetyHealthAct.pdf American H&S legislation is more prescriptive or rule based than the UK & Ireland. Workers are trained expected to follow the rules or face the consequences The less rule based performance driven legislation in the UK & Ireland may lead a duty holder to take a more cautious approach than what is actually required by legislation or would result in any real risk reduction. I suppose the big question is how IE & Network Rails injury rate for track workers compares with Union Pacific?
Like the Network Rail video, UP turnout replacement looks like a very professional operation that involved a lot of planning. The level of risk and required controls are far different the American example is on low speed trackage in a yard, the UK example the replacement of a crossover on a relatively high speed freight and passenger line. The absence of fencing and people/equipment crossing the track in the American example is not really an issue, all trains are required to stop and obtain authorisation from the person in control of the possession before proceeding. It noticeable in the UP video that all machinery movement is stopped and the crew return to a safe position during train movements.
Guards vans on Adelaide-Dundalk goods trains rings a bell. For some reason keg traffic from the Harp Larger brewery to Belfast was worked for several years in loose coupled trains after other freight services on the Dublin-Belfast line went over to liner operation. Not sure if it was something to do with the loading arrangements at the brewery or an industrial relations issue.
Dart underground plan time limit running out
Mayner replied to GSR 800's topic in What's happening on the network?
How will the Government raise the Billion + € needed to build the DART underground? Higher taxes or congestion charges in the Greater Dublin region? Traffic figures on similar schemes in Sydney & Brisbane have not lived up to expectations with the Government having to step in with a much higher level of subsidy than originally planned. Accepting EU or World Bank funding could leave Ireland even more indebted and economic policy subject to the whims of the Trokia. -
BR Vans & TPOs on Galway Night Liner/Mail were piped to run with 62'9" air braked container wagons.
TL suffix dating from the early 70s for conventional coaches fitted with Train Line lighting system powered by a generator in the guards van rather than battery and dynamo under each coach. Suffix carried by BR & Dutch Vans, Brake Generator Steam Vans, Cravens, Park Royal, some Laminate & Buffet cars.
What happened in Melbourne and Victoria in a nutshell In 1999 three concessions were awarded to private operators, two of 15 years for the urban area and one of 10 years for the country trains. One of the urban concessions was awarded to a French group trading as Connex, and the other two were awarded to National Express (UK), each on the basis of a range of management criteria and of minimum subsidy requirement. The operators improved service quality, added some additional off-peak services, and introduced some new rolling stock. However soon they were bogged down in disputes including revenue allocation, and they failed to negotiate major productivity improvements with staff. Patronage growth, a healthy 3 percent per annum, was much less than the over-optimistic forecasts. Within two years the companies were in financial distress and at the end of 2002 National Express exited, taking a large financial write-off. A new (2004) contract, under which Connex has a concession over the whole system for 4-6 years, draws on the previous lessons and appears to be more successful. The country train concession also awarded to National Express was not successful and was handed back to the Government.
The main risk with privatising uneconomic road or rail passenger services is poorer service levels than under state control or threats to shut down operations unless the government increases the level of subsidy. This tends to happen when an operator puts in a low bid to take on the contract for a set level of state subsidy and revenue growth does not reach expectations or simply signed the contract intending to farm the subsidy by providing a minimal level of service. To quote a World Bank Paper on Australian & New Zealand Railway Privatisation ƒ Passenger rail concessioning is more complex than freight rail privatization because there are multiple aspects to address (for example, subsidy levels, performance, risk allocation, end-of period issues) and because governments typically remain closely interested in day to day operational effectiveness. ƒ There should be more emphasis on the operational and financial robustness of bids and less on the best financial outcome : RESULTS OF RAILWAY PRIVATIZATION IN AUSTRALIA AND NEW ZEALAND 53 - Governments cannot contract out of its obligation to ensure continuation of urban rail passenger services. If a private operator fails, the government is politically or legally obliged to intervene. Having the operator on the hoop If the operators get into ‘survival’ mode, or are distracted by continuing disputes, management effort and focus is taken away from improving service performance towards managing for survival – which often will mean managing the funder of last resort – i.e., government; ƒ If the private sector is to deliver efficiencies, it must be given the capacity to effect reforms.
There was no real union or staff resistance to the ending of the elimination of goods brake vans on fully fitted trains, the loco cab was safer and a lot more comfortable than a standard CIE 20 & 30T van at 50mph. Fully fitted freights with brake vans were restricted to 35mph A guards van was sometimes used on Foynes Byrytes trains so the guard could close level crossing gates without having to walk the length of the train when the crossing keepers had finished their shift. CIE seem to have been quite cunning in their dealings with the unions in the 50s and 60s, eliminating the requirement for a fireman on diesel locos years before BR by placing the train heating boiler in the van. A lot of IEs labour relation problems arose as a result of worker frustration with the large general unions after ASLEF withdrew from Ireland and the lack of long term Government commitment to retaining the railways. IE was able to offer better terms and conditions and re-deploy 'redundant" staff to other roles after the EU Working Time Directive and a buyont economy freed IEs hand to negotiate with the unions
The BSSGVs were late 1970s rebuilds of Corridor Standard coaches into Brake Standard Steam Generator Vans to replace the last of the Tin Vans still in service BSSGV from corridor side. Compartment side Close up boiler/generator/luggage compartment. Boiler roof panel Van from corridor side. The BSGV overlays are priced at $53.00 NZ +$10 postage (approx. £22 Stg + £4.5 postage) The $NZ has taken a tumble in recent months which results in a real reduction in shipping costs to Irish and UK customers. The sides for these coaches should be ready for shipping in approx. 3 weeks
http://www.britishpathe.com/video/railway-modernisation 1:39 Still in use in the 1960s the granddaddy of tracklaying machines "The Morris Tracklayer" was invented by the MGWR civil engineer in the 1920s and a relaying train built. The design was licensed to Morris Cranes in the UK and a relaying train built for the LNER. After the Amalgamation the MGWR train was used mainly for track lifting on the Midland rather than relaying for the singling of the Main line during and lifting the Western Branches. The machine was basically built to quickly catch up on the arrears of track maintenance after WW1 & the troubles rather than a cost saving exercise
Freightliner traffic to Ireland was originally shipped through Holyhead to Dublin and Belfast ports. The Dublin Freightliner terminal never had a rail connection despite being at the end of the Alexandra Road Tramway and talk about a connection. IE operated two return Freightiner trains on the Belfast-Dublin line for a short time in the early 1990s when Freightliner closed Holyhead & cancelled the Dublin sailings and concentrated Irish traffic on the Liverpool-Belfast sailings. The Belfast-Dublin Freightliner traffic was lost to rail when Freightliner traffic returned to Dublin Port. Some photos of typical Freightliner formations on the North Wales Coast Line in the 80s http://www.penmorfa.com/Archive/nine.htm
The UK rail privatisation was more tied up with neo-Liberal theory that idea that the private sector would make a better job than public sector at anything from sweeping the streets to running hospitals and prisons. Much the same thing happened in Australasia and South America with state owned railways either privatised completely or loss making passenger services opened up to competitive tender. Personally I don't have an issue with the Department of Transport opening up passenger rail services up to competitive tender, in a similar manner to the LUAS and intercity and regional rail services in many countries. http://www.transdevna.com/Rail.aspx Commuter, regional and Intercity rail services are likely to require some form of subsidy regardless of Irelands population density or size of regional centres. Comparing Irish services levels with parts of the UK and Europe with similar population density would assist in establishing a benchmark. Rail services in parts of Scotland, Wales and East Anglia come to mind. L
The Irish Government cannot have it both ways in accepting over £500m in EU Structural Funding to upgrade the railways as part of the deal for signing the Maastricht Treaty in 1992 and then looking for a get out clause on implementing an EU Directive that potentially may open IE up to competition. I suppose IE could do a DB and bid to operate rail services in other EU countries.
CIE management in the late 49s seem to have been heavily influenced by American practice with a powerful twin engine Sulzer design for the Cork line and a single cab Bo Bo design for freight. The selection of a Sulzer engine and Metropolitan Vickers electrical equipment was a wise choice at the expense of a high axle load. With the right choice of bogie these locos could have been a real success. It looks like the Sulzer Twins were intended to replace steam on the Cork line which would have been a propaganda coup for both CIE and the Government in challenging Ireland image as a backward place, after all this was the era of the big infrastructure schemes that eventually transformed the Republic from an agricultural to a manufacturing and service economy. Going back to the multi engine Gen-Set idea for the 201s the biggest challenge and cost is likely to be the need for a complete frame up re-design of the electrics and control system. The Gen Set idea is similar to the production Detics, where a complete power unit and generator is maintained by the manufacturer or their service agent rather than the railway. Its hard to see the idea flying with the entire class of 201s, it might be a viable options for locos allocated to specific duties such as IWT, Coillte or Tara. A multi engine loco could be shut down to one engine for shunting or running an empty freight, though an electronic traction and engine management system with the present engine would probably achieve the same result.
