Mayner
Everything posted by Mayner
  1. Very tasty job on the tank wagons Patrick. The Bachmann model really lifted the standard for rtr tank wagons and a good candidate for limited run production for Irish Shell, Mc Mullen Brothers, Mex. The silver tank barrel with horizontal red stripe or red solebars was an early form of hazmat marking applied to distinguish Type A tank wagons used carry petrol and other highly flammable liquids from the usually black Type B tank wagons used to carry heavy fuel oil and other flammable liquids. The position of the red strip tended to vary between the centre of the barrel and solebars, silver gave way to light grey in the 60s. The type A & B tank wagons had different discharge arrangements petrol was basically siphoned out of a Type A tank wagon with U tube arrangement on top of the barrel, heavy fuel oil though a valve under a Type B tank wagon. The Type A tank wagons tended to look cleaner than the Type B without the usual build up of grunge around the tank filler usually seen on wagons used to transport heavy fuel oil and bitumen
  2. Mayner
    Snow!
    Not quite as bad as 1947 Dublin was more or less cut off from the rest of the country by a blizzard on a Friday in January 81 or 82. Most of the roads in the higher area of South Dublin were blocked by drifts by early morning, the Naas Road blocked around Rathcoole by early afternoon. At Heuston CIE staff worked to keep trains moving clearing snow from around points. The station became a gathering place for people marooned by the storm, a train was used to provide an emergency night shelter for people from the storm. More snow fell overnight most roads in Dublin were blocked, the Government chartered a special train to transport milk powder from Cork to Dublin. Most of the railway lines were cleared quickly though it took a week to re-open the Sligo line knocked out by a combination of fallen trees and telegraph/telephone lines. To be prepared for the next winter CIE acquired a small plough for use with the 071 Class, it usually lived in Inchacore not sure if it was ever used in anger.
  3. I can certainly relate to an unfinished projects thread. About 10-12 years ago I stumbled across a collection of unfinished TMD (pre-SSM) loco kits at an exhibition in the UK. The locos were mainly GNR, but included part built J15 and a un-built MGWR E Class or J26. The original builder worked in P4 and had got stuck at the stage of building a free running chassis before giving up with the majority of the kits. I managed to get 4 of the locos running to a reasonable standard 2 in OO 2 in 21mm within year, but still have not finished the J15 or the Midland tank while the list of unfinished projects seems to get longer and longer.
  4. The Westrail excursion train operation at Tuam evolved out of an unsuccessful attempt to re-open the Loughrea Branch. The original mainly volunteer lead West of Ireland Steam Railway Association (WISRA) planned to re-open the branch in stages working South from a base at Attymon Junction with the intention of leasing the line from CIE. The change in direction came about as a result of a combination of CIEs decision to close Attymon as a block post severing the main line connection, the realisation of the enormity of funding and restoring even a short section of line together with little support for the scheme at the Loughrea end. The local mart built an access road through the station yard before the line was abandoned and track lifted in the 80s. Few suitable main line coaches were available when the society made its first purchases, most of the coaches and engineers stock were pre-amalgamation in Departmental use requiring major restoration work, nearly impossible without a decent engineering base. The Tuam operation was more pragmatic and achievable than Attymon, but dependent on the continued operation of the Limerick-Claremorris line and the goodwill of IE for access to the network. Initially the outlook looked good as large numbers of ex-main line coaches in reasonable condition became available to preservationists following the commissioning of the DART and introduction of the MK3 coaches. No 90 was restored to operation and re-boilered in the early 1990s, agreement appears to have been reached for the long term loan of ex SLNCR 0-6-4T Lough Erne to provide a more suitable & powerful loco for main line operation. The tipping point appears to have been the temporary closure of the Ennis-Claremorris line in the early 1990s lead to the cancellation of the established Galway operations. During the final season of operation No 90 operated between Cork & Cobh in connection with the Cobh Heritage Centre. The operation does not appear to have been a financial success with disappointing passenger loadings and a higher cost structure than Galway with hired IE coaching stock and staff accommodation and travel costs. IE disconnecting the yard at Tuam seems to have been the final straw, having been through a similar situation with CIE at Attymon 10 years earlier. In retrospect it would be difficult to see the operation continuing unless Westrail had the resources IE and Galway County Council backing to take over the maintenance of the Athenry-Tuam line. From a railfans point of view the original WISRA rolling stock was more interesting and varied than the more uniform Westrail MK2 Bredin stock. The original coaches were mainly ex-GSWR stock demoted to departmental use, along with the usual opens and vans wagon stock included some unique items including the last GNR Bulk Cement wagon, MGWR & GSWR ballast hoppers, a MGWR rail wagon, a pair of Shell-Mex Class A (Petrol) tank wagons and last but not least the ex-GSWR 12t brake van regularly used on the Loughrea Branch. The preservation of G613 was significant the first diesel loco to regularly work the Loughrea Branch. Others were harder to explain the survival and presentation of Sulzer B113 Ireland's 1st Main Line diesel electric locomotive to the UFTM is probably down to WISRA who reserved the loco but CIE were unwilling to tow the loco on the main line.
  5. The CIE would probably have ended up with G12s in place of the A Class & G8 in place of C Class if I had gone to GM in place of Metrovick in the 50s. In the early 50s GM also submitted a proposal to supply G8s to the GNR & UTA the light weight GL8 (121 & Victoria Railways T) did not appear until the early 60s.
  6. The Black and Tan and Supertrain styling was almost pure GM with the use of strikingly contrasting colours. I wonder was the Swedish design firm that came up with the Black and Tan colour scheme influenced by the Norwegian GM demonstrators or was CIE still hankering after an American style streamliner after GSR/CIE senior management visited the states in the 1940s. At one stage it was planned to operate the Dublin-Waterford & Dublin-Limerick via Nenagh services with MK2D push pull fitted sets. I always thought that a 6-7 car set topped and tailed with a pair of rebuilt baby Metrovicks similar to the Enterprise would have speeded up these services and made a nice pocket streamliner.
  7. It looks like a lot of work went into the original chassis, it looks like it would have been really smooth riding and a powerful puller with double reduction gearing and drive to each bogie. I tried the same principal with a couple of diesel shunters great runners but sounded like coffee grinders. The MIR GM diesels were quite good in comparison with other resin and whitemetal kits of that era, locos built with a combination of an Athearn drive and whitemetal body could pull any train.
  8. Info on the Kernow DJ models Class 71. http://www.kernowmodelrailcentre.com/page/74/DJ_Models_Class_71_Project
  9. One that did not make it Australian example of crowd funding attempt for an N Gauge loco. €58000 pledged at €350 a skull. https://www.kickstarter.com/projects/1560185090/n-scale-nswgr-ad60-garratt-locomotive.
  10. Interesting topic I suppose the most critical thing is a structure to safeguard the money invested in the fund until the goods arrives. Funding Paddy Murphy, or one of the more established model shops to commission a rtr model seems to be the best option for a mass produced model. There is also the option of commissioning a limited run of rtr models through some of the professional model maker that post on this site. I suppose one of the key questions is whether modellers investing money up front on a new model would have a depressing effect on the sales of Murphy Models current range and on smaller manufacturers. Richie that E Class is a beautiful looking job, I looked at producing a version combining resin casting and etched detail 3-4 years ago, if you are interested I may be able to sort out a set of detail parts including buffer beams, cab windows, roof, engine compartment, doors & grills
  11. Interesting time capsule of the last days of the traditional steam age railway, the RPSI special narrows the time period to June 1972 when 186 worked the "North Kerry" raitour to Tralee visiting Castleisland & Fenit. Probably more interesting seeing Tralee still had a G Class for shunting the two goods yards and trip working to Fenit and possibly Castleisland. Goods traffic at both Tralee & Castleisland seems to have been heavy at the time with a hint of the modern era creeping in with Guinness, Bulk Grain & ISO containers handled at the gantry in the North Kerry Yard.
  12. I think the continued survival of the railways has more to do with changes in social & economic policy in the 1960s that reversed the long term decline in rail passenger figures rather than any coherent government transport policy or actions by CIE. Passenger figures were in decline since the 1920s, the trend only started to reverse with the improved economy in the late 60s, fewer people emigrating, higher income and probably most significantly a new travel hungry student class with more people staying on in education into their 20s than emigrating or settling down and starting a family. The implementation of Railplan 80 slowed rather than reversed the long term decline in railfreight, tonnage basically dropped year by year in the 70s & 80s as many Irish companies developed their own road fleets to get around CIEs near monopoly on road haulage. The growth of the Courier companies basically wiped out sundries and parcel traffic, railways struggle to make money on container and timber traffic, leaving Tara the only heavy bulk flow though this is probably marginally profitable, ore trains of less than 1000 tonnes gross are very light by international standards. With light tonnage and short line hauls the writing was on the wall for Irish railfreight once the road haulage was de-regulated in the early 1990s
  13. Well spotted this Italian loco was basically the standard for a C Class rtr conversion before the repainted Lima 33s arrived on the scene in the late 70s. The Rivarossi HO & N versions had better motor bogies than the Lima locos.
  14. The tractors were owned by Dublin Port and Docks Board and more recently the Port Company. The tractors seem to have been mainly used to move tank wagons between the Granary Sidings East Wall Road and the various oil and bitumen siding on the Alexandra Road Tramway. Irish Shell had its own shunting loco. Traffic on the Tramway would have been heavier in loose coupled days with wagon load traffic to and from Alexandra Basin, grain traffic for Ranks and Odlums and fertiliser from Gouldings East Wall Road.
  15. Most of the larger Irish companies had TPOs with South Eastern, Midland, GSWR & Great Northern vans including some 6 wheelers in service until the new CIE vans appeared in the late 50s. The Hornby model would makes a passable CIE van. In later years the POs ran mainly on the Cork & Galway mail trains. The Galway Day Mail was usually a mixed rake of TPOs, Parcel Vans & MK2D Supertrain coaches, the Night Mails BR Van, TPO, Parcel Vans with a tail of container wagons for mail and Liner traffic.
  16. Very attractive station might even model it some time. Photo taken in summer of 85 while exploring the remains of one of CIEs mouldering branch lines.
  17. The video includes earlier CIE publicity material including the Cork Glanmire Road-Alexandra Road B&I liner Irelands 1st company train and footage filmed or the introduction of the Supertrain in 1972. Interesting to see CIE filmed the Supertrain on the South-Eastern, publicity included a poster of an aerial photo of the train passing Avoca village. I always thought 001 looked really well with the roof painted black. The modernisation plan was pared/cut back radically as CIEs financial position worsened, while most of the freight part was implemented, it took another 30 years to upgrade the track and signalling to modern standards. The plan was a lot more wide reaching than just freight and basically involved total route modernisation in addition to the new trains. Push-pull trains were to be used on Dublin-Waterford & Dublin-Limerick passenger services, some freights were planned to go out by one route and return by another. At one stage there were plans to serve Waterford and Wexford with one sundries train serving South Eastern & Kilkenny line depots. The bogie fertiliser wagons with their steel mesh doors were originally nicknamed Long Kesh wagons. Sundries traffic was originally to be carried in block trains of 60' sliding door vans. Some of the H&S stuff is scary, I wonder how may of those Inchacore workers in the video ended up without some form of occupational disease. Internationally railways were never good at looking after their workers health
  18. Sunday afternoons 30 odd years ago sent exploring abandoned branch lines after getting my first car. Very attractive line with riverside sections & a backdrop of the Wicklow Mountains. More common view of the North end of the train shed Not sure of the purpose of the stone building on the right it looks more like a farm than a railway building and too small to be a loco shed. Station building from the South East similar to Rathvilley I will put up the goods shed and trainshed when I get a chance. The branch lost its passenger and regular goods service in the late 1940s, the only traffic appears to have been cattle specials to Baltinglass with the loco running light to Tullow to turn. The branch seems to have been quite run down and over grown in later years, most photos in later days show trains running through a sea of grass with the rails hardly visible. There are a couple of nice photos of the Station in GSR days with a 52 Class on a passenger and a J15 on a goods in Great Southern Railways by Donal Murray (ian Allen 2006). The trains are a nice mix the passenger with a corridor coach in chocolate and cream and a 6 wheeler in what looks like the then new maroon livery, the goods made up of old style14' wagon is a bit like the old Triang-Hornby Freightmaster set with no two wagons the same. One of the oddities for the terminus of a long branch line is that Tullow does not appear to have had a engine shed at a time a shed or workshop was essential for carrying out maintenance light repairs between runs.
  19. Neil Ramsey' C Class comes pretty close.
  20. Possibly commissioned by Metrovick as a boardroom ornament for CIE or for publicity purposes.
  21. Taken with an Instamatic (I hadn't anything better) around 1980 wont find this one on Eiretrains
  22. Its a bit ironic to see luxury tourist trains appearing so many years after the most scenic lines like Achill, Clifen, Valentia and Waterford-Mallow closed. CIEs 1st diesel programme in the 1940s included a luxury train aimed at the American tourist market. It will be interesting to see if the new train will involve an element of overnight running, this would have advantages for Belmond and IE in moving guests between attractions, avoiding the boring bits in the middle, feeing up line capacity and improved security.
  23. Good to see that tribalism is alive and well in Ireland. Funnily I haven't heard similar calls for "The Model Railway Club" in London or "The Ulster Model Railway Club" to change their names or calls for a ban on the imperialist NMRA recruiting members outside the US. The club is similar in a way to the MRC in London one of the oldest in the country with good working relationships with other clubs and members drawn mainly from the greater Dublin area with even a few from the SDMRC Dunlaoire-Rathdown heartland.
  24. I like the 3/4 view the model really captures the look of these coaches. The IFM Park Royals look like good layout coaches and are reasonably priced for what they are and fill a huge gap in the rtr/easy to build market. To a degree comparing the IFM & Worsley Works Park Royals is like comparing apples and oranges. The IFM model is aimed at the modeller/collector who wants a coach that looks like a Park Royal, rather than someone who wants to build a scale model of a Park Royal.
  25. Mayner
    Bulleid TPO
    The TPO/Tool Van kits are in stock at $106 + $20 shipping prices quoted in NZ dollars. I will be in contact with anyone who has expressed an interest or placed an order for one of these vans.
