DiveController
  1. I think you're probably correct. I think there's a little pussy on board more frequently nowadays than on the Shackleton;)
  2. Whose pilots are these exactly? No excuse for not keeping an eye on instruments in low-viz conditions. Modern fighter/interceptor aircraft have so much tech the pilots become complacent regarding situational awareness. THe HUD not turned on then?
  3. This is to be used as a lightship or a ferry? The crew should be able to find where they docked her even after a few beers! Probably look better after a few........
  4. Very nice job, indeed!. Is that scratchbuilt? Would be a lovely little kit in OO but I guess wouldn't have very broad appeal, I suspect
  5. Does anyone have any input on these points?
  6. And this is probably that probably occurs more frequently on express points, with a longer well due to the narrow angle of intersection?
  7. Knew that, but not what BBC stood for. Thanks
  8. Easy way to make the chips! The plane itself would be easily outrun or shot down by any modern fighter aircraft but its payload is the very real and dangerous relic of the Cold War and it's been looking like we're heading down that road again
  9. Great clip, John:-bd
  10. Interesting tail fin identifier
  11. Careful, now! …..You reap what you sow;)
  12. I think this is way above the odds and good luck to her. Fortunately a kindly site member found me some a few months back
  13. Great analysis, Eoin. That really describes it well. The problem is that (with smaller wheeled wagons) the wheel nearest the frog falls into the gap/well just before the point of the frog. When that wheel hits the frog point, it meets resistance, momentarily 'stopping' the wheel. A moment-arm through the centre of gravity of the wagon (generally in the center of the wagon on relatively straight track) causes the axle to rotate toward the 'stopped' wheel/frog which (if unchecked) will allow the opposite wheel (on the stock rail) to rotate toward the check rail and ride up onto it - derailed. This also aggravated the wagon 'tilting' toward the frog. If the check rail is the correct distance (close enough to) the stock rail, it provide a counterforce on the inside of the flange of the wheel on the stock rail, keeping it in line with the rail and forcing the 'fallen' wheel to remount the frog point and keep rolling. If the space between the stock rail and check rail is too wide counter pressure cannot be applied to the inside of the flange on the stock wheel flange to prevent the axle rotating. Eoin's solution exploits that by narrowing the gap between the stock rail and check rail (on each road) allowing the counter pressure on the stock wheel to occur. This suggest that the distance between the stock and check rail on the Hornby points is too wide opposite the frog. Does anyone know if the Hornby point stems from an era when wheels were a cruder design with deeper flanges and the point design was never improved upon? As Eoin points out, the deeper the well the greater the probability of the a problem. So this would be less of a problem with a Code 75 point than Code 100 (which is all that Hornby make, I think). This seems of be less of a problem with Peco points, so they obviously have the check in the correct position regardless. The problem does not occur with larger wheeled rolling stock as the wheel crossing the frog is large enough to ride over the gap and frog point without falling and attempting to re-mount the frog point. I suspect that this is also a problem for lighter wagons and maybe bogies more than fixed axles. Since I don't have a layout, this is somewhat speculative so please correct any points that are incorrect.
  14. would this help? http://gizmodo.com/5592010/this-train-lays-its-own-tracks
  15. Thanks for the heads-up, Wally! Products now acquired fom site member
  16. Product obtained. Thanks to those who PM'd me.
  17. Careful, lads! You're close to straying off topic here=))
  18. You paid tax dollars, not punts or euro?
  19. Alan, PM sent. Click on Notifications/Inbox on top right of page
  20. ……...and all because the lady loves Cadbury's Milk Tray
  21. Interesting, I may call them……
  22. Problem with the rails it's running on rather than the rolling stock, I think. Hard to have an appealing service when it's quicker to get there on the motorway … if you don't get a pressure sore on your buttock waiting to get there:D
  23. It's called the Woolworth principle, I think. they'll likely sell out first and Kernow maybe last (which is fine if you're looking for something that's almost sold out)
  24. The Independent article refers to a website http://www.trainsplanestoys.com but this doesn't link to a server and does't even appear to be under construction
  25. She's a lovely model, Sulzer! Also on my list (eventually). Glad you're happy with her. Sensible swap by model shop…...keep the customers happy. They don't have a website though…. they did, by all accounts on the web, but it's gone for at least a year
