Even though these seemed to be pretty clean in most of the photos I have seen of them, a little weathering would add some realism to the garish PW yellow
Oops, my mistake. I have the book so I'll actually take a gander at that
Many pictures of the grey livery running bonnet first before the reversal but very few I would think in IR livery in 1990. I don't have the IRRS book mentioned by @murphaph but he was referring to 121 bonnet first other than parked/pilot/shunting/running around in more recent decades
Been a long time since I messed around with decoder so have forgotten quite a lot. Test the motor on DC, connect power to the wheels first , then test on a section of track. If it runs well on DC then there's an issue with the DCC decoder or CV settings such as starting voltage etc if its struggling the same section of track. I'd start by resetting the decoder to factory settings (CV8 to 8 usually) which is usually sufficient to get most thing started. The Stay Alive will work for dirty track but not if it runs well on DC already. Which decoder? Do you have the manual? If not, it may be online
Sorry for the late reply. I don't have any of these but I looked it up on the Hattons site and they refer to the instruction manual here https://images.hattons.co.uk/mediafiles/hattonsdecoderinstructions2016.pdf Oddly the 6 function decoder refer you to this manual which refers to a 4-function decoder. Nonetheless int he absence of any better advice you might be able to use use F3 green wire and CV51 to operate the cab light. Maybe setting it as directional will allow the cab in the direction of travel to be illuminated by selecting F3?
Will the RPSI 134 be arriving c. September 2020 with the grey liveried MM 121 class?
Indeed, if there are any Mk3s to come I know this livery will be very popular (despite my preference for an ST livery, I'd certainly make an exception).The elusive restaurant coach with correct IE style windows, obviously
Belmond Hibernian - Luxury Touring Train
DiveController replied to Broithe's topic in What's happening on the network?
@Railer Many thanks -
Does anyone happen to now off hand which if the MK3s were purchased to form the Belmond GH set particularly the generator, was it 7602? -
@leslie10646 Thanks for the info Leslie. You gotta look down from the semaphore observations occasionally or this is what happens (Get Well Soon) PS Is that arm in an upper quadrant or a lower quadrant plaster? ..... somersaults, well you did those already
Regardless the van looks great and I'll definitely be taking a couple! Early livery?
I think the one at Cultra may have a torpedo vent but that may well have changed in preservation. Hard to find many photos of the roofs, what was typical on there?
Speaking of EGVs, I didn't know they were fitted with integral rear lights eventually
Peco Code 75 or 100 Wooden Sleeper
DiveController replied to burnthebox's question in Questions & Answers
The gauges are usually back to back to measure the distance between the rails on one track. There are others but don't know that much about them. The 67mm rec is from between centers (or any given same point on both rails e.g inside of the R/H rail on track 1 to inside of R/H rail on track 2). It might be easier for spacing to lay two parallel tracks with 67mm centers and then measure exactly the correct distance between the rails of adjacent tracks (less than 67 mm), or between the sleepers (less again). Then you can get some spacers to shove between the tracks as you lay them rather than keep trying to measure 67 between centers. Other option is to mark one track center, then an adjacent line 67 away and stick your pins in but it get trickier if you want to put down cork or closed foam then you remark etc. Seems like spacers would be easier and if you get a mm or 2mm off laying the first track, your track separation is maintained -
Actually, I meant the second coach which has the updated blued stripe livery. Alway thought the earlier version and that one with its tippex edge looked really well. It's actually hard to reproduce it well on a model. I think @Dhu Varren did a really nice job on this livery also, a few years back @Galteemore It wasn't bad when new but that wasn't always pristine as you say. Yes, lovely layout this one
- 464 replies
- 1
- ballyercall
- layout
(and 1 more)
Tagged with:
Oooh! love to see the NI post '1988? Intercity coach
- 464 replies
- 1
- ballyercall
- layout
(and 1 more)
Tagged with:
Help with NIR Class 111 liveries
DiveController replied to murphaph's question in Questions & Answers
Regarding venturing south, looks like 113 went on a test run to Limerick , then Waterford then back to home turf in 2003 and with the deeper yellow warning panel on the cab front. 111 was on a rail tour along the western Rail Corridor in 1990 -
The 111s came with the thinner italicized (slanted-type) NIR log with sharp corners. In Jonathan's Allen book 35 Years of the NIR he shows the newer thicker NIR logo with rounded corners on the the locomotives after 1993- using images but no associated text that I noticed. Likely they were resprayed and had new logos applied at the next overhaul after that year. I'm not sure when the full height yellow end was applied to 113, much more recently maybe c.2003 -
track occupation, need advice
DiveController replied to WaYSidE's question in DCC, Electrics and Electronics
I'd like to add something constructive to this conversation but I actually have no idea what either of you are talking about. At some point on a layout STILL not in progress I'd like to have some basic track occupancy in the sense that I'd like to be able to have trains come to an automatic gradual stop at junctions and so forth if the rand is not set/signal at danger- 7 replies
- loss of hair
- rake of questions
(and 3 more)
Tagged with:
@Past-Avenue Is it 4 function or 6 function chip (one above seems to be 6 functions)? If I recall correctly there is no, or no controlled, cab lighting is the 141s but there is in the 071s. You'll need an extra function or an extra function per cab to control those. If not one of the CVs may need to be changed
Did that work? Occasionally you'll have a main wire come loose due to bad solder. Happened to me with a lighting wire only on a 141. You'll have lights if it a wire to the motor only. Which chip, wonder why it failed if so?
I don't think I've ever heard when the lighter blue changed to the darker on this forum and even in the shot you and hexagon posted above it is hard to determine how light it is. If you told me the shot of 113 was later than 1981 and not just recently delivered, that would have seemed reasonable when you compare to the shot of 112 on the enterprise leaving Connolly above. I think the photo technology of the time, processing, exposure & lighting can alter things significantly like previous discussions on orange liveries. Hopefully someone with a more intimate knowledge of NIR stock might help on the changeover dates from lighter blue to darker blue? -
Bottom line is that all the MM coaches sold as Dave says but I suspect that having extra GSV/EGV is probably a sound strategy. I don't think someone who merely wanted to add an EGV to another rake would necessarily buy new whole stock to get an EGV, unless they regard the new product as superior and want to buy a whole new rake anyway. Even if you sold the EGV in a pack with something else, someone just wanting to complete another rake would buy that pack alone leaving a shortage of those packs as they other coach packs sell out. Anyway all that strategy is up to the producer.
The SSM kit does three for only 20 euro but they're neither lit nor motorized I believe. Cosmetically they're a nice option. I think someone did a motorized one in OO I believe with 'bounce' and everything but I don't recall
they look great but shame no 4mm version
