New Layout Plans
If your soldering to the track the best method is use a Dremel and grind the underside of the track to be soldered, then tin the track and solder the wire on. This will ensure a good connection to the track. This is what a good soldered joint should look like.
  • Replies 163
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
What soldering issue are you having?
It's just that the smaller wire won't solder to the larger bus wire even though:
Both area's have been stripped of insulation, I'm using flux , and there is solder on the soldering iron
Lovely work Dave :)
I use a small file on the underside of the rail to rough it up, then tin it with a drop of solder.
I then apply the wire, also tinned and simply melt the solder on both wire and rail.
Two seconds then hold in place for three seconds and done.
You should get a lovely, clean , shiny join :) (it does take practice though, my first few attempts had to end up in the bin :) )
Make sure you tin both wires well first - heat the big wire and melt plenty of solder into it.
For joining bus to droppers, I use solder tags - like these
http://www.maplin.co.uk/solder-tags-29815
They are pre-tinned and make life a lot simpler for joining cables.
[ATTACH=CONFIG]2215[/ATTACH]
Hi Dave
It's not that that I'm having a problem with, though it's probably better than my method of soldering the wire to the outside of the rail
You shouldn't need flux when soldering cables together, most soldering jobs won't need it unless its big items to be soldered. The trick to soldering cables is plenty of heat to the joint, if you apply the solder to the cable and not the iron it should flow freely into the cables when its hot enough.
I'll do a video on it tomorrow if you like.
Awesome! I'll give another crack at it after Dun Laoghaire tomorrow :D
Today I managed to get a train running on the layout after taking Dave and Boskonays advice
Hopefully I'll do the rest tomorrow and get a video out of it
And once thats done I can start on point motors !(sarcastic YAY!!)
I also got some ballast at the show today for the layout once the wiring is done and a decoder to wire to one of my Athearn SD9's as practice
There's nothing as rewarding as seeing a loco powered up on track you've just laid :)
You're spot on there Stephen. Baby GM's layout is really taking shape and looking good.
Rich,
Yep
I opted not to control my points from my DCC controller after some research on other forums, mine are run from a control panel with toggle switches. For one thing it's a lot cheaper and if the layout shuts down due to a short I still have control of the points.
I think Anto also has the same approach on his layout.
Oh:o, I thought you ment by a control panel so no I wont be operating points via DCC
Yep have to agree its the best way
Guest hidden-agenda
Taking shape nicely Brian but for the love of god get a perspex barrier around the edge or you will suffer a hefty loss if you get a derailment.
Have to agree strongly with hidden-agenda, the layout is looking fab with loads of potential but valuable rolling stock will have to be protected - curves and point-work close to edges and I know from bitter experience how easy and often derailments can occur with costly results. Great layout taking shape.
O so true. While testing new track work, I had the sickening experience of seeing my Hunslet instead of going straight on, turning right on points and dropped to the level below. The front coupling and the buffer beam took most of the damage and while I was able to repair it the model will carry the scars. It has made me double check all points before test runs and will include safety edges as soon as the construction allows it.
Thanks for the advice guys
On my old layout one of my 141's had a nice 228 scale feet of a drop onto the floor when it derailed :((
I won't be taking the chance this time
Edited by BabyGM
Great work on the layout BabyGM,the start of any layout is always a pain,but worth it in the end.It is always good to get a loco running on what you have been working on.Just to back up what the other guys have said,be careful with the track close to the baseboard edge as my hand once knocked a 3 car 80 class railcar set of the layout with dire results.
Today I finally finished the first part of wiring and generally cleaned the layout
I also added a maintenance depot and RPSI south-eastern base
E7738D13-4BB4-4FD5-8CCF-06E55CECA1E0-1444-0000017B65F16DAE.jpg?t=1346015949
To the left is the maintenance depot and to the right is the RPSI south-eastern base
3BFE48D5-289B-481C-95CD-ED18A5E54A3E-1444-0000017B441AE657.jpg?t=1346015932
A27BF2B3-56B2-4677-AD65-CD2672F5358B-1444-0000017B26ABD716.jpg?t=1346015906
Much tidier than the photo a few pages back
896A9B02-1580-407E-8D53-529922C19E8B-1444-0000017B0A4D486C.jpg?t=1346015896
Do things run OK over that point at the right-hand side in the second picture? The one that sends the outer track over the crossing. It looks a little bit 'steppy' at the join in the baseboard, where the point meets the cross-over.
Maybe it's just the angle of the photo...
