ttc0169
Everything posted by ttc0169
  1. Happened when the Cravens sets went through a rough patch with the GSVs breaking down and steam heating pipes puncturing during the winter of 1995-they were replaced by Mk2 a/bs on the 17:00 to Ballina on Fridays only-a welcome change for the passengers and added more variety for me with 2x121/141 and 071s working the trains.
  2. 47404 deposits the ballast hoppers into the up siding and moves into the factory sidings on standby on Ashburton grove earlier
  3. Aer Lingus 747 EI-BED takes off from the airport with an evening flight to JFK…
  4. A private operator has purchased a former London transport double decker bus for use in the locality….seen here passing through station road on Tara junction.
  5. Thanks to Tom at IFM for converting the commer into a P&T van-fits in really well with the surrounding vehicles of that era.
  6. The superb IRM oil tank wagons arrive behind locomotive 018 with their first delivery to the MPD on Tara junction, Another gem of a model-thank you IRM.
  7. Good to see you on here Jim, I enjoyed the Model world exhibition-put it in the diary for next year….
  8. Must have Denis-the box arrived earlier
  9. Notification received-it’s going to be a busy weekend on Tara junction…..
  10. I worked in the freight yard and have never seen such scotches there.
  11. Wooden scotch blocks -no ropes attached.
  12. Sounds very familiar there Rich…
  13. A superb prototypical formation from the 1990s-well done warb..
  14. And here it is hauling the IWT liner train to Ballina-it was the first HVO liner train in Ireland
  15. Nothing so far Denis.
  16. Sulzer locomotive 107 has been reactivated and has been restricted to work only with the permanent way open and flat wagons on Tara junction.
  17. 47404 works a ballast hopper train out of the up loop after the passage of an oil train 37118 works an oil tanker train and was replaced in the up loop by 37264 20172+20001 work an MGR train on Ashburton grove.
  18. After a suggestion from Philip Clampett and photos of the real “bubble”railcar 2751 from Colm O Callaghan-I set about altering a centre car from a three piece ICR,I had converted from a Bachmann 170 to the single car unit 2751, Thanks to the gentlemen named above-2751 operated a test run from Inchicore to Limerick and return this evening, The unit is seen here passing through Tara junction.station heading back to Inchicore.
  19. You’re a bit too young at the moment,you are correct minimum age is 16.
  20. Thanks Davenport-it’s the EMD power unit in 001.
  21. Locomotive 001 works the Tara junction.steam crane through the station-the superbly detailed Irish Railway Models open and flat wagons along with a brake van make an ideal companion to this late 1980s scene, Well done IRM and Gareth Brennan for the brake van.
  22. My ones arrived yesterday.
  23. To acknowledge the efforts of Sean Brown for his preservation and museum in Castlerea -maybe a model of his A class-A55 in green livery would be a fitting tribute to him. https://www.hellskitchenmuseum.com/
  24. Any chance????
  25. 001 in Supertrain livery with the black roof….
