irishthump
  1. No you're right. I meant to say cab lights in my above post. Also, the function outputs differ slightly between the 071's and 201's. It's a bit hazy, as I haven't had to programme one for a while, but I think the headlights need 2 functions on the 071 and 1 function on the 201.
  2. Maybe, but they are there and they're supposed to work!
  3. Check for wires going between the tender and the loco. If there is a lot of them it would indicate the decoder is in the body.
  4. I don't think there is a problem with the loco. What decoder are you using and which DCC system do you have? The reason I ask is: 1) The decoder probably does'nt have enough function outputs. The headlights requires 2 separate functions for them to work in both directions. This is the reason it only works at one end. 2) The reason F2 has to be held down is because of the DCC controller. A lot of brands set F2 to only operate as long as it's pressed (This is because most sound decoders assign the horn to F2.)
  5. Just as well.... don't have the cash for a pair of 121's right now!
  6. Have to agree, it's a cracking job. It will be a good runner too (even with the stock Athearn mechanism) as long as you use the right decoder.
  7. I'd be very wary of not looking into it further. There could be a problem with the PCB or maybe a loose wire somewhere in the loco. Although the fact that it happened in both locos would make a PCB fault more likely. Also, if the locos were'nt ran for some time were they stored in a cold/damp environment? That could cause a buildup of moisture. Personally I would open the loco and have a look, the body is tight fitting and could trap a wire against the chassis. Also check how the decoder is sitting on the PCB. Esu decoders tend to sit a little high which can result in metal on metal contact when the body is placed on top.
  8. So did you need to perform the decoder reset or did the problem go away on it's own?
  9. That's unlikely, Noel. Those switches are basically on/off and would'nt really be able to affect the cab lights the way the OP has described.
  10. These decoders can be programmed to make the lights behave like this. As you say, probably more prototypical the way it is.
  11. Try resetting the decoders to factory settings by entering a value of 8 to CV8. Decoders can sometimes behave peculiarly if they have'nt been run for a while.
  12. Bleedin' masterpiece!
  13. Having notching assigned to high numbered function keys is only part of the problem, you also have to aware of how notching works within the sound file. Once you activate notching up it will remain active until the function key(s) are pressed again. It can also take a second or two to activate so you need about of practice to get the feel of how it operates. Assigning the notch functions to lower keys makes it a lot easier. Again, this is a much easier process with the Lokprogammer.
  14. I forgot to mention. The MM 071 Loksound decoders have a notch up/down feature which allows you to change the engine sound independent from the loco's speed. You can notch right down to idle without altering the speed at all.
  15. Yes. You can play back the various sound functions but you can't really see how the loco drives without having it on the track.
  16. Yes, they use the same files.
  17. For what it's worth, the Lokprogrammer will set you back about €120, basically the cost of one MM 071 chip, but it's probably the best investment I've made. I can overwrite any of my Loksound decoders so I'm not stuck with sounds I don't like. Also, blank Loksound decoders can be got for €100 each plus free shipping.
  18. You can download the Lokprogrammer software from the ESU website for free and play around with it before you even buy the programmer itself. When you download the software it includes several sound template libraries which contain various engine, horn, brake, whistle sounds which you can use to build your own soundfiles from scratch. These libraries don't contain the Irish-specific sounds but if you download the 201 and 071 sound files you can copy these sounds to the libraries on your PC. It's then a fairly simple job to download whatever US sound file that has the engine sound you need then just swap out whatever sounds you want for Irish ones.
  19. Noel, Yes, the decoders require a small firmware update to use the new files. Obviously you need the Lokprogrammer to do this. There's a large range of updated soundfiles already available on the ESU website and they're adding to it every month. These features are aimed squarely at the US market so the engine sounds we need are well catered for. There are already several different soundfiles just for the EMD 567 so you can programme 3-4 141's each with a slightly different engine sound.
  20. Setting the deceleration to it's maximum would simulate coasting, but there's problem with doing that with MM decoder. ESU decoders use a different setting to practically all other makes of decoder when it comes to acceleration/deceleration CV's. There is a standard NMRA formula for this which ESU for, some unknown reason, didi'nt follow. The result is the maximum acc/dec rate on their decoders is about 25% of other makes. So if a loco fitted with a Zimo decoder takes 2 laps of a track circuit to stop then an ESU decoder with the same dec value will stop in .5 laps of the track.
  21. No, driving characteristics such as Real Drive are controlled by the actual sound file that is loaded on to the decoder. The CV's have no control over this. personally I'm not too fond of the Zimo decoders. The braking and coasting features are very good but the way the engine sounds react to throttle changes leaves a lot to be desired IMHO. However, ESU recently realeased a new set of soundfiles that have similar features under the name "Full Throttle". These include a working brake, a "Coast" function which brings the engine sound down to idle while you control the speed independently with the throttle as well as "Drive Hold" which locks the speed of the loco while you adjust the engine sound with the throttle. Sounds complicated but is simple in practice. I've programmed one of my own locos at home with one of these files and it works great. You can achieve very realistic running with it. I was planning to post a video of it when I get the chance. Here's a video from ESU's YouTube channel. It's a bit long winded but you can get the idea.... [video=youtube;3k-MfiBY7eQ]
  22. As far as I know mine have the same gap. Probably necessary for the bogies to clear the underframe on tight radius curves.
  23. Well you could buy one in the hotel bar, but by Jayzus you'd pay for it!
  24. irishthump
    DCC Decoders
    That's a curious one! Exactly what settings do you lose when you power down?
  25. Great tip! Can you post a link to the sellers on Ebay?
