irishthump
  1. Yes, and the website has a large selection of files from various countries which are free to download. No UK outline but there's plenty of US locos which is good if you model Irish! Is there anything there that would work for your DART project?
  2. Divecontroller, DC Kits have an excellent range of soundfiles for British locos. They may be willing to write a bespoke file to your specifications if you just want to change a few horn sounds. Might be worth contacting them....
  3. You can't import a sound file from a decoder. You need to be in possession of the original file.
  4. Lads, they are absolutely stunning. Great job!
  5. Excellent little tutorial there, Dave.
  6. I order online from them a lot. They're a good local(ish) source for US detail parts and spares.
  7. Looks dreadful..... http://http://www.bbc.com/news/world-europe-36774059
  8. 48 if memory serves....
  9. If you're talking about the manufacturers ID then it's 36 if I recall.....
  10. Aargh! I have to wait until next year for the Supertrain livery! Never mind,great news all the same......
  11. Folks, Haven't been doing much as railway related modelling lately but I have been busy with some of my wargaming miniatures. Same cr*p, different scale as my wife likes to point out! Here's a batch of WW2 American and German tanks in 1/100 or 15mm scale. A platoon of 4 Shermans, M4A3's to be exact. A German Panther and Tiger...
  12. If you're ordering from the UK then use Parcel Motel, it will save you a fortune! I tried the Railmatch acrylics myself and did'nt really like them. I generally don't like acrylics much at all for airbruhing as they dry too quickly which makes cleanup a pain. For weathering I use Humbrol Enamels. They are cheap enough and readily available from hobby and toy shops and can be thinned with normal white spirits. For weathering I really only use Matt Black no. 33 and Matt Leather no. 62, the Matt Leather straight out of the tin is very close to a rusty rail colour and mixing it with the black with give you pretty much any shade of trackside muck you could want!
  13. Many happy returns, Boss!
  14. I'm not sure you would have enough room for the Soundbug inside the 141 as space is tight under the shell. Putting an adaptor on the decoder will take up even more space and you more than likely won't have room for the Stay Alive capacitor (if fitted) in either case. Do you have any pics of the decoder with the 8-21 PIN adaptor fitted to it?
  15. Absolutely cracking job! Can't wait to see the finished product....
  16. They look fantastic! Can't wait to see the real thing.....
  17. Bit early for a resurrection, Dive. Easter Sunday is next week!
  18. Surely that should be Claremorris'? But I do feel your pain. You should try reading through some of the emails that I have to endure from the learned people I work with.....
  19. No, Gaugemaster are rebadged MRC not NCE controllers.
  20. I've ordered from both Digitrains and Wickness Models and found them both to be excellent.
  21. He only asked for advice on the paint.
  22. Cold weather really isn't good for aerosol paint! The cold actually affects the pressure inside the can resulting in the paint clumping when you're spraying it. Try storing your spray cans indoors for a few days, it makes a big difference. If there's any chance you could spray paint indoors then that would be the best option, otherwise you need to wait for warmer weather. This is reason that many modellers (including myself) prefer to spray the primer into another container then apply it to the model with an airbrush. *Sorry Weshty, you beat me to it!
  23. Jayzus.... There's going to be a van driver with one hell of a bad back tomorrow!
  24. You need to remove the square plastic clips from the top of the bogie assemblies. Just carefully lever one side out with a small flat screwdriver being careful not to break it. You can then lift the drive rods away from the worm gear and the bogie should just drop out. Bear in mind you will need to remove the pickup wires from the circuit board if you want to remove the bogies completely.
  25. You beat me to it! Yes, that HST used a motoer form a cd drive. I gave it a good run after installation and never noticed the motor overheating to any degree.....
