Mayner
Everything posted by Mayner
  1. A 1953 built Brake Standard 1904 and Laminate Standard 1442 appears to have been the ‘official” Ballina coaches in the 70s and early 80s, both were fitted with storage heaters so the train could be operated without a heating van. Earlier some C class diesels were fitted with ETH equipment for use with a handful of early GSR composites fitted with electric heating. Although similar in general appearance most early CIE coaches were slightly longer and had different window arrangements to the LMS Stanier stock. Rather than carve up an expensive Bachmann or Hornby model I have designed brass overlay sides "shrunk to fit" the inexpensive Dapol Stanier composite http://irishrailwaymodeller.com/showthread.php/3482-JM-Design-Coach-Sides-amp-TPO-kit
  2. IE seems to have recently lifted all the yard trackage in North Esk https://www.flickr.com/photos/be216cd1/sets/72157626321868083. This would seem to go against any plans to use the yard as a Cork railfreight freight terminal
  3. Great looking test pilot job on the flat Richie, really captures the look of a skeletal flat Des! Going back to the Hornby MK2As I have a sneaking suspicion I tried kitbashing a pair into Cravens back in the early 80s by cutting out the centre set of doors and gluing the two parts of the body together.
  4. Brilliant find: Quite stylish almost a cocktail bar. I am definitely tempted to do an interior, probably nickel silver. Miller Engineering pushed the boundaries with this sort of thing in Z & N http://jamesriverbranch.net/project_7a.htm Iarnrod Four Buffet Cars seem to have lasted in service into 1987 most likely for Connolly-Sligo & Rosslare Trains. Most of the wooden bodied stock were withdrawn in the early 80s, several of the side corridor standards passed into preservation 1st with the GSRPS in Mallow & Tralee, some were overhauled & repainted in lined green with flying snail at Tralee and were eventually used by Westrail between Tuam & Athenry.
  5. Kevin Good to hear you have decided to take the plunge to Code 75, it easier to work with than Code 100 and looks one hell of a lot better. I used Code 75 on an American HO layout the running was very good and it looked fine. The Dapol or Wenn wagons should be fine, in the long run it will pay you to change to metal tyred wheels (sounds better and results in cleaner track. It should be simple to re-wheel with Hornby, Bachmann or Jackson or even Gibson wheels. Intercity Models Superoller wheels seem to be the best option for re-wheeling Lima wagons with their short 24.5mm axles, and dirt magnet wheels with deep flanges. http://www.intercitymodels.com/Superollers.html
  6. The test etches for the 4w TPO kit & Buffet Car sides arrived last week. Some minor modifications required to the TPO tooling otherwise everything looks good. TPO with alternative sides for engineers tool van. Buffet Car Sides Dapol Stanier CIE Buffet Conversion Side Corridor Standard Mock-up. The Buffet Car and Side Corridor Standard sides should be available October. The first batch of TPO kits November. If there is enough interest I will produce an interior kit for the buffet complete with bar counter and tables and chairs.
  7. Alphagrafix no web site but advertises in the railway magazine (23 Darris Road, Selly Park, Birmingham, B29 7QY, England) produces card kits of Irish buildings and steam era rolling stock. Several articles on assembling the kits in New Irish Lines http://newirishlines.org/tag/alphagraphix/
  8. I started tracklaying on the latest version of Bankfoot about 3 weeks ago based on ideas in Iain Rices trackwork book. Progress ground to a standstill when I could not find my track gauges. General view of the station and yard The buildings are the Wills small station and goods shed kits, similar in general size to some of the smaller branch line and light railway stations in the Welsh Border country, the layout will be modelled as a goods only branch kept going by traffic from the quarry and the odd wagon load of coal or fertiliser for the goods yard. The wagons were built from a mixture of Airfix mineral wagon kits and the much more recent Parkside Ore Tippler. Trackwork is prefabricated on a sheet of kraft paper on the work bench before laying in place on the baseboards. First the Templot track templates are glued in place spray mount, sleepers or flexible track laid on a bed of PVA and ballast scattered in place. Sleepers/crossing timbers are ply stained with a water based wood stain, excess ballast is brushed vacuumed off before dropping in the rails. The C&L chairs are threaded onto the rails then glued down to the sleepers using Plastic Weld or Butnol. This is not as tedious as it first seems, the secret is to first file/sand any burrs or rough edges off the end of the rail before threading on the chairs and work on the little and often principal, points can be built quite quickly.
  9. I managed to convince myself that I saw 207 Liffey at some time between first hearing “She loves me” and “Satisfaction”so definitely post 1963. A master for a resin UG should be fairly straight forward to produce. Alternatively if you can find a builder the Worsley Works UG might be a workable alternative for batch building, especially if it can be made to fit on a Bachmann SECR C Class chassis.
  10. Definitely worth a field trip to West Cork apart from lifting the track very little seems to have changed since the track was lifted in the 1960s. http://eiretrains.com/Photo_Gallery/Railway%20Stations%20C/Courtmacsherry/IrishRailwayStations.html. There are some very atmospheric photos of the line in Ernie Shepherds CBSCR book. The branch is probably the nearest thing in Ireland to lines like the KSER, Mid Suffolk & Tanat Valley corrugated iron buildings very light construction. Courtmacsharry would make an attractive model with the main street as a backdrop, single slighty curved platform road, run round, two sidings one to pier, loco shed, small goods shed. Timoleague station curving layout squeezed in between the Abbey and town, seems to have been the operating hub of the line, cattle bank, carriage, loco shed/workshop on down side, single platform goods yard on up town side of line. The station site is now a car park. Colour photos of T&C in both editions Irish Railways in Colour Steam to Diesel Tom Ferris (Midland Publishing) incl. brand new C Class at Timoleague on excursion, J26 on beet working late 50s including a great shot of Timoleague yard full of wagons and trucks transferring beet.
  11. I went the opposite way accidently building a MGWR 6 coach possibly I S scale from a drawing in Model Railway magazine, I only noticed something looked when I built a matching pair of coaches from a drawing in a later edition of the magazine. I transferred the dimensions directly off the drawings without checking the scale.
  12. I though for a moment that Laurie was announcing a rtr Vs 4-4-0 http://transportsofdelight.smugmug.com/RAILWAYS/IRISH-RAILWAYS/GREAT-NORTHERN-RAILWAY-IRELAND/17846660_NWbrJP#!i=1744829757&k=ZTq6jCm. I have managed to convince myself that I saw 207 in action on the main line, my first loco a a chisler in the early 60s GLR3D Model Design seem to have mastered the art of 3D design with this van and the GNR full brake all that's needed is a couple of non-corridor coaches and a few bread vans to make up a typical Irish North passenger train. Surprisingly kits of most of the common loco classes are available in kit form from SSM, Worsley Works and GLR3D. The little GLR JT tank appears to be a reasonably simple to build model for the beginner and ideal for the Belturbet branch. The blue liveried S & U Class 4-4-0s added a splash of colour, S worked to Enniskillen on a GAA special and possibly other excursions, while the modern U class regularly worked daily the Bundoran Express through from Dundalk. The SSM PP 4-4-0 and SG and AL 0-6-0 are suitable goods engines.
  13. Brilliant stuff Tara & Valarie seem to have found a winning formula of using a the branch line railway as a vehicle to launch a performing arts project. It will be interesting see I the evening train ride develops into a regular thing nice way to unwind after a busy day/week, a couple of drinks would go down very well with the food and conversation.
  14. It might be worth while looking at getting a Silhouette Cutter! I would recommend preparing a template drawing for one wagon and doing a test build to check fits and minimum width/sizes for strappings and other details, to avoid repetitive errors before batch building. If you haven't gotten to deep with TurboCad it might be worth trying Draftsight its free 2D software http://www.3ds.com/products-services/draftsight/overview/. The main disadvantage is that the TurboCAD is that the file format is incompatible with the programmes used in photo etching, laser cutting and 3D printing and its necessary to export the file to a dxf. or a 3d modelling format which can result in all sorts of interesting problems.
  15. The 071s were delivered in a slightly darker richer shade of orange to that used for other locos and coaches. They were more intensively used than other classes and tended to be look a lot darker as they were usually covered in road grim.
  16. Good to see those old H&M controllers still going strong.
  17. A little information on the plough wagon. 3409m bought 1924 possibly war surplus built by a Belgian company 40 ton capacity 60' long bogies 49' centres.
  18. I read somewhere think it was IRN that its planned to permanently close central cabin and control movements to and from the platform lines from the Waterford Check Cabin. The Line to Belview appears to be worked as an extension of the goods yard. From an operational point of view modernising/rationalising the signalling at Waterford is long overdue. I suppose the big question is whether the citizens of Waterford or the rail users & the NTA pay for the preservation of the cabin,IE is basically broke.
  19. Spudfan Any idea what's the purpose of the machine that looks like a loco with hydraulic jacks? The underframe looks very light for a loco. The yellow machine with caterpillar tracks, dozer blade and Hiab crane is used for preparing the trackbed and laying track, saw one operating at Boora in the 90s
  20. Not your regular excursionists I love it some very cool and happening people! Could make the branch a trendy venue for cultural events and parties. IE might even get Arts & Heritage Council funding.
  21. It seems to be more co-incidence than anything else that Tyrconnel and myself started work on a G2 luckily we work in two different scales. Though Tyrconnel range is becoming increasingly tempting as I am searching for a 14BA nut and a crankpin bush that fell on the carpet. A G2 would be a very tight fit on your turntable 47' 1½" over buffers 34' 8¼ engine and tender wheelbase. The Midland/GSR would have probably used a Standard Goods J18/19 or possibly a H Class J6 for long distance coal traffic with a J26 or possibly the ex Fenit Hunslet 0-6-0ST 299 for the Arigna Valley shunt. The GSR used J15s sometimes with the leading rods removed on sharply curved Castlecomer Branch which served Deerpark mine in the Leinster coalfield.
  22. I just completed the test build of the horse box, need to beef up the strapping detail on the doors. The production versions of the Horsebox and Meat Van should be available before Christmas. The horse boxes and vans lasted in CIE services into the late 50s, there is a photo of a van in CIE livery with flying snail in Des Cookham's Irish Broad Gauge Carriages. The kit features fold up and slot and tab assembly, suitable for solder or glue assembly designed for 21mm or OO gauge.
  23. Most large organisations tend to have white elephants tucked away. Guinness spent/wasted millions on product development that flopped anyone remember Guinness Light? Apart from the 500 & 800 Class 4-6-0 & the Woolwich most of the GSWR and GSR steam locos of the 1920s & 30s were flops or not as good as engines they were intended to re-place. The whole business of the Drum Battery Train puts the waste with Alstom DMUs & EMUs into the halfpenny place, the final units were withdrawn after less than 10 years service because no one was willing to fund the cost of replacement batteries. This was at time CIE was struggling to import coal while new hydro electricity and peat burning power stations were coming on line.
  24. The Fermoy & Lismore was basically the Duke of Devonshire’s private railway, no doubt the station buildings were intended to be in keeping with his castle. The Duke seems to have been something of a railway enthusiast ,besides financing the Fermoy & Lismore and other local lines in Munster the Duke had his own private engine Dunrobin and station on the Highland Railway in Scotland. The WDLR struggled to make ends meet, building its own station in Lismore probably cost less than paying the F&L for the use of its station and share of the signalling and infrastructure costs. The diagram looks like the F&L and WDLR each had their own signal cabin controlling the signals and crossover at the approach to their stations. This would have allowed passenger or mixed trains from Tallow Road and Cappaquin to arrive in their platforms simultaneously. The F&L side of the station is basically a typical branch line terminus with single platform roof, runround loop, goods yard and loco shed. The WDLR appears to have a platform road, run round loop and loco shed. Crossover 6 in the diagram may have been hand operated at some stage and used to allow a loco to run round at train at either platform. The crossover with the diamond crossing from the loop to the engine shed is a GSWR arrangement, which allow a train to shunt from the loop to the loco shed while a train is in section from Tallow Road. The WDLR appears to have had its own loco shed but no turntable shown in the diagram. Train working at Lismore in WDLR days would have involved a lot of shunting, possibly with two passenger trains in the station at the one time, locos running round turning and servicing before re-marshalling their trains and in American terms interchange traffic between the GSWR & WDLR. The GSWR may have routed goods traffic from the South-West to Waterford over the WDLR as a friendly connection rather than over the W&L which was considered a serious competitor. Small obscure railway almost no published information, no kits or RTR sounds tempting
  25. The engineers equipment makes an unusual model, I like the look of that drilling rig. The scrap containers were very heavily weathered to a browny black colourprobably a combination of road dirt and brake dust. It might be worth while looking through back issues of the IRRS Journal from that era for equipment used in the electrification. CIE was acutely short of coaches at the time, s mainly loose coupled corrugated opens and the odd 1/2 height container wagon used or spoil. Ready mixed concrete agitator on bogie wagon used to transport concrete to work site for signal and mast bases, short trains made up of 4w open and closed containers to transport tools and equipment, MK1 4w container flats fitted with Haib crane for erecting signal posts. I lost most of my very grainy photos from the electrification. Loose coupled train made up of unconverted beet wagons and 4w container flats with half height containers seem to used to carry spoil, most ended up dumped a Liffey Junction. Atlas "Rubber Duck" excavators widely used, CIE Priestman crane on Lomac hired in Ruston or NCK crawler cranes for lifing in point and crossing work, baby Metrovicks n engineers trains.
