Mayner
Everything posted by Mayner
  1. A bit more progress this weekend. I had originally planned to use Peco Point Motors with baseplates and extended drive pin salvaged from an N gauge layout, but decided to fit the motors directly to the points to eliminate the risk of lost motion with the extended drive pin and floating track base. The first job was to accurately fit and test run the track before cutting out the holes in the baseboard for the point motors, at the same stage I drilled holes for the power droppers, I cut out the holes for the point motors using a drill and jig saw, test fitting the point/point motor subassembly as work progressed, the hole in the top right hand corner has to be squared up.! Test fitting and checking alignment of point work and main running road on one board checking that the running road aligns with a point on the second board. Its necessary to cut the hole longer and wider than the headblock timbers to allow the motor to fit through, I infill the excess with black paper before ballasting the track The tricky potentially messy bit track lifted on packers before gluing and ballasting showing droppers to DCC track power bus. Track bedded in office glue aligned and lightly pinned in position, I was a bit to generous with the glue on this first section. Ballast sprinkled on and pointwork installed on second board. Underside of baseboard showing power droppers and point motors. I had shaken off excess ballast at this stage. Tracklaying and ballasting complete. I used fine ash ballast on some of the siding roads and a medium brown on the running line and loop, the difference in shading is probably related to the drying of the glue. Looking back towards the staging From the buffers the lines in the foreground are supposed to have been re-aligned in the 30s when a new grain feed store was built. I may inset the track on the right with cobbles or concrete as its supposed to be part of a quayside line or simply treat as a railway siding as it would be tricky insetting the point and not look very good in OO. I will do any necessary topping up of ballast covering baldspots by dry ballasting and gluing with dilute office glue and a wetting agent using an eye dropper. The glue is a white office glue which hopefully is more resilient than a woodworking pva. It will be interesting to see whether noise transmission from the track to the ply becomes a problem (especially locos with sound), the track is basically floating on foam underlay and will only be fixed rigidly at the baseboard joints, this layout is basically a test bed for a permanent 21mm gauge layout if it ever gets built. The Mill/Feedstore area the hoppers are spotted for unloading over the intake pits, the vans spotted for loading feedstuff from the dry store. I am almost tempted by Ranks Clara which had quite grusome corrugated iron grain elevators and stores in contrast to the massive brick and stone 18th and 19th Century maltings and mills.
  2. There was a king of inferiority complex about Irish railways and particularly CIE when I first joined a club in the early 70s, the majority of members modelled British, Continental or American outline, Irish railways particularly the GNR tended to be modelled by craftsmen for the challenge of modelling something different and novices like myself who could only afford second hand Tri-ang. People who wanted quality models and reliable running tended to buy and collect Marklin, Fleischmann, Trix and Rivarossi Continental while a smaller number collected Wrenn and Hornby Dublo, a few collected Athearn, Walthers and Atlas but the running quality and detail of American stock was not great until Walthers and Atlas commissioned Roco in Austria and later Kato in Japan to produce locos during the 1980s. Irish outline became more main stream with the introduction of kits and later rtr models from the mid 1980s, but I suspect like NZR modelling in New Zealand remains a minority interest compared to modelling and collecting British, Continental and American models. Curiously despite New Zealand modelling having a high profile with a national guild similar to the NMRA that published a quarterly magazine available in book and magazine stores nationally and the availability of a comprehensive range of kits produced by several manufacturers in three scales , its still pretty much a minority interest and no manufacturer has commissioned high quality models of New Zealand locos and stock. British, Continental and American modellers have all established national groups, the New Zealand Model Railway Guild, AMRA (American Modellers) and Garden Railway Associations host bi-annual national conferences with regional annual conferences. Because of its craft base the standard of NZR modelling tends to be higher and more realistic than mainstream British, American and Continental modelling, with realistic scenery and structure modelling including accurately modelled native trees, vegetation and land form (either flats or mountain), birds, animals human figures, buildings and structures. Clubs are not all in major cities some are small remote centers, Athlone is a large town by any standards
  3. Interesting mainly West Cork, South Eastern and Midland wagons with a small number of GSWR/GSR. I wonder had they been carded/withdrawn/broken up and Carriage & Wagon Department not informed the Traffic Department or the Control Office. Railways are famous for siloed thinking I had some interesting interactions as a HSA inspector with IE about 20 years ago and quickly I found out that Signal and Electrical did always not keep Permanent Way in the loop about things they were doing on or very close to the line.
  4. Reminds me of a fire drill during the construction of a large Watford shopping center during the late 80s. Although there was relatively little of a flammable nature on site we were constructing the concrete frame the company recently had major fires on two of its most prestigious London sites and an order went out from head office for a fire drill on every site. Anyway to get to the heart of the story, my job was to physically check that the site was clear after our trade contractors managers and foremen had completed a head count that the site was clear. Like Harry a concrete finisher was diligently chipping away with his hammer and chisel wearing ear defenders inside a plant room. At the time apart from safety helmets and steel toe capped boots construction workers seldom wore ppe, our concrete finisher was probably the only one of the over 100 workers on site to wear hearing protection, being already a bit deaf he did not hear the klaxon and preferring to work apart from breaks he was invisible to his work mates and his boss forgot to check. The look of surprise when he realised that he was the only one on site was something else, al those were the days!
  5. Interestingly Colin Flannigan appears to have built his first BCDR 4-4-2T out of a Ks Adams Tank Loco kit during the 1970s
  6. Nice to see these Triang(-Hornby) upgrades, their main line diesels & MK1 coaches were cutting edge models by the standards of the day and still pass muster 60 years later.
  7. Kia Kaha! (Maori Stay Strong) Don't let it get you down, life is full of ups and downs it will come right in the end. As a teenager I wanted to be a mechanical engineer but could no get into college because secondary school did not teach the required subjects, was unemployed for 6 months before I was offered what's now called an Internship in construction, very quickly discovered I had strong problem solving and project management skills and completed a lot of interesting projects over the past 30 years. Although there have been setbacks along the with construction boom-bust cycle I am definitely better off than when I started out and in a way have fulfilled my mechanical engineering ambitions even if its in 1:76 scale
  8. Final castings arrived for the Luggage Vans on Monday morning, expect to start shipping outstanding orders of Heating and Luggage and Luggage Van Kits from early next week.
  9. Mayner
    KMCE's Workbench
    The Ore Wagon looks fantastic combination of dumb and sprung buffers, IRM highly unlikely to bring out a mass produced rtr version, real Mike Sharman or Richard Chown stuff. The British Builders archives held by the HMRS and various Museums are a real treasure trove of 19th and early 20th Century Irish locos and rolling stock.
  10. Mayner
    KMCE's Workbench
    The DWWR opens almost look like early ore wagons with those massive solebars extending past the end framing almost like dumb buffers. Perhaps a hangover from the boom years of the Avoca Mines when copper ore was shipped by rail to Kingstown (Dunlaoire) Mineral Wharf. Hopefully some day you will get round to building a typical 19th Century DWWR 0-4-2 Goods Locomotive to haul them
  11. It might be worth while trying Humbrol Decalfix rather than Microset and allow at least one week to allow any trapped moisture to evaporate before applying a clear sealer. Microset may be too severe Railtec Transfers recommend Decalfix which has worked well in finishing our rtr 3D printed brake vans. I use Gunze B523 "Mr Super Clear UV Flat" aerosol(misted on from a distance) for finishing wagons and locos as Testors Clear Cote is no longer available. Batch building wagons I allow a minimum of one weeks drying time after applying decals in a room with temperature and humidity control before finishing.
  12. 1100 and 1101 were basically the fore runners of the British Railways Derby and BRCW Type 2 Classes probably one of the most successful and useful Modernisation Scheme designs. https://www.derbysulzers.com/cie.html The main weakness in the two Irish mixed traffic prototypes was rough riding due to the plate frame carriage bogie design, the 1100-1101 engine and electrical were sound the Metropolitan Vickers electrical system was considered superior to the systems used in the BR Type 2. Its possible CIE went for plate frame bogies because cast steel bogies were un-available or prohibitively expensive in 1948 or someone in Inchacore simply compared notes with Eastleigh on Southern Railways experience with EMU and diesel electric locomotive bogies. Its a pity that CIEs budget did not stretch to bringing 1100-1101 into line with the B101 Class by increasing the BRCW order to 14 sets of parts, an additional pair of B Class locos with universal route availability would have been very useful until sufficient re-motored A Class were available to replace the B101 and pairs of GMs on the heaviest duties. The E Class are German locos with high speed Maybach Engines and Mekydro hydraulic transmissions, CIE gradually phased out the D301 Class Ireland sole example of the classic British diesel shunter by the late 1960s.
  13. Completed the baseboards and installed track underlay this weekend. I fitted DCC Baseboard Alignment boards to the baseboards ends using a piece of ply with two pilot holes as drilling ji The underlay is dense foam ground sheet glued with PVA and weighted down until dry. I fitted strip basswood to the baseboard edge to assist with track alignment. Mock up on the outside work bench, Tower Building inspired by Grand Canal Street and overbridge will act as fiddle yard view blocker. Set up in the Workshop/Layout Room with Fiddle Yard baseboard fitted. The fiddle yard baseboard is basically an inverted box with an open top. I am planning to use a traverser using metal drawer slides., I will need to fit stripwood runners to the ply ends and an intermediate to support the slides, the traverser table will basically sit on top of the slides clear of the ply framing. The next jobs are to sort out the traverser top for the fiddle yard and drill out the pilot holes for the point motors. I seem to have disappeared most of the track/pointwork for this end of the layout since Saturday morning, I suspect it has fallen into the narrow gap behind the under-baseboard storage units which will require a major clear out
  14. Dan Renehan a CIE driver wrote a series on papers on CIE diesels including the E401 & 421 Classes in the IRRS journal during the 1980s. The majority of the operational E401s lost their exhaust cowl and silencer as a result of an exhaust fire when one of the class was working as Inchacore Works Pilot (Sambo). The class were gradually withdrawn in the late 70s/early 80s though apparently the the last operational loco possibly E401 retained her silencer and cowl. The E401s were basically worn out after years on heavy duties working Heuston-North Wall transfer freights. Some E421 originally based at Connolly were transferred to Heuston to undertake coaching pilot duties. According Locos and Stock of CIE & NIR (Doyle & Hirsch) E401,411,415,417 and 419 were withdrawn by 1979
  15. I did not realise that the GSR operated a Cork-Bandon local passenger service, I was under the impression that Bandon was served by Cork-Skibbereen & Clonakilty trains in CBSCR and GSR days. The Muskery is an odd one the GSR received a 5% Baronial Dividend on the CMLR share capital for 10 years following the Amalgamation, the GSR operated a skeleton service of one or two trains daily in its final years until the dividend payments ceased in 1934. Presumably the payments would have ceased if the GSR closed the line earlier. According to Shepherd the GSR wanted to close the Timoleague and Courtmacsharry line in 1925 but continued to operate the line possibly in order to continue receiving a dividend under the Baronial Guarantee scheme but was worth while keeping open for goods and excursion traffic.
  16. Branch lines feeder branch lines close to large cities and towns such as Dublin, Cork and Drogheda tended to loose their passenger service or completely once the railways established their bus and road delivery services. Macroom lost its passenger services in the early 30s and the Passage and Muskerry lines were closed completely during the same era, I suspect the Muskerry hung on until the Government Baronial Guarantee payments ceased in 1934 otherwise the GSR would have closed the line earlier. The GSR & CIE seem to have operated a sparce passenger service on the Tullow Branch, the Meath line and Cavan Branches, it was cheaper to serve Naas, Navan and Cavan by bus direct from Dublin with the bonus of GSR/CIE operating a direct Dublin-Navan-Kells-Cavan service something that was impossible to do by rail. The Ardee goods service appears to have survived because it could be worked as a Drogheda shunting or pilot duty in a similar manner to the Tralee Pilot working the Castleisland, Listowel and Fenit shunts rather than an allocated locomotive. The principal applied on a larger scale before the 1963 Closures with the Liffey Junction Pilot (G 611 Class) working the weekly Edenderry Goods and trip workings to Kilmessan and Drumree when Clonsilla-Navan closed to through freight workings, the Clara Pilot (G601) worked the Banagher Goods in addition to shunting the goods yard, Ranks/RF Hall and LF Goodbody Jute factory sidings, during the 1930s the Mallow pilot worked the Kanturk Newmarket goods allowing a Sentinel Railcar replace a locomotive and coaches on the branch passenger service.
  17. Its interesting how overseas railways turned out successful 4-6-4T locomotives while British companies struggled to produce a successful 4-6-4T tank with the notable exception of the Brighton Baltics. The main problems with the British locos appears to have been poor front end and ashpan design. On the 3'6" gauge NZR successfully used 4-6-4T for branch line, mixed traffic and suburban design. Interestingly the first NZR Baltics the WW Class of was a 1913 development of a 1904 2-6-4T design, the final NZR 4-6-4T design the Wab/Ws class was a 1919 development of a 4-6-2 Mixed Traffic design https://en.wikipedia.org/wiki/NZR_WAB_class All NZR 4-6-4T Classes were modern designs with long travel valves outside valvegear and free steaming boilers.
  18. Mayner
    Customs & VAT
    I worked for regulatory bodies in both Ireland and New Zealand, sometimes they end up in the pockets of the industries they are intended to regulate. Large organisations such as Government Departments, regulatory bodies, the banks and An Post tend to behave as a living organism and tend to treat any challenge or criticism in a similar manner to our antibodies fighting an infection and are prepared to fight most challenges through the courts until the plaintiff either dies or runs out of money rather than admit to a mistake or error.
  19. Mayner
    Customs & VAT
    I had an interesting response to a complaint I lodged with the Office of the Communications Regulator that An Post was misleading customers and postal authorities by advising that items were rejected by the Revenue Commissioners and items still in An Post's possession had been returned to sender. The Irish Communications Regulator basically replied that they did not want to know, as I had not lodged an official complaint with an Post and were not interested in anything to do with customs. An Post advised me early in September than an item was rejected by the Revenue and had been returned to sender, but managed to scan the item in the Dublin Mail Centre four weeks after it was returned to sender, eight weeks later I can only assume that An Post have lost the item as it has not re-materialised in the NZ Post tracking system or been physically returned. On the positive side I am trialing DHL Express for a high value DTP shipment to the UK, our DHLs account managers advice was not to complete or worry about the customs declaration as they would complete it correctly as customs clearance is included in the shipping fee.
  20. It would be worth while having a look for Vol 1 RM Arnold's Golden Years of the GNR through the library system if you do not have a copy. Mac Arnold focused on train working and the people that worked the railway more folklore than a conventional railway history.
  21. Brookhall Mill was one of the inspirations for East Dock. Assembled the baseboards this afternoon, ensured consistency by ripped the framing using a circular table saw and cut the framing to length with a cross compound mitre saw. I marked the position of the point tie bars before positioning the intermediate cross members. The fiddle yard will be a traverser on a separate 250X300mm baseboard. The layout will have a painted hardboard fascia and backscene, backscene will have radiused corners similar to that in the background.
  22. It looks like Tim Cramer did a lot of the original research before Cork area locos and stock were scrapped in the 50/60s. Roger kindly provided a Tim Cramer sketch of a MGWR tender bunker detail possibly from a J18 that was overhauled and painted black in Cork during the late 1950s. Tim popularised Irish modelling during the 1970s published drawings and articles on No 90 and the "Bandon Tanks" in the Model Railway Constructor late 60s early 70s and the "Irish Miscellany" series of articles which included the 800 Class, Kerry & Achill Bogie 4-4-0s, MGWR 6w Coaches, MGWR small tanks, Argadeen, GSWR Brake Van, GSR Open, B141 and Waterfall Station in Model Railway magazine in the mid late 70s, together with articles on his own work in 4 and 7 mm scales.
  23. Brings back happy memories reminds me of days trainspotting on the Midland in the 80s and 90s. Usually Craven train consists until MK2D cascaded onto the line in the late 80s
  24. It seems a co-incidence that we both end up building dock harbour layouts to fit a 7'6" space though in different scales. I went for OO and Peco small radius points as I would have struggled to fit the tracklayout in the same space in 21mm gauge because of the longer point leads! Would you consider moving the crossover towards the tunnel to provide a longer run round loop, though it leaves you with the downside of loosing part of the quay siding, I guess you could build a GSWR Railmotor for passenger services and use St Molga or possibly a model of GSWR 100 for goods. I better be careful I seem to be talking myself into a 7mm Timoleague & Courtmacsharry layout before I even get to grips with 4mm in OO or 21
  25. There were 3 Black Hawthorn 0-4-2Ts built for the Ballymena-Parkmore-Retreat line which became NCC 101-103, 102 & 103 had their saddle tank extended to the front of the smokebox as in the photo. Two were loaned to the Cavan & Leitrim to work coal trains in 1920 but later returned to the NCC and scrapped so I just have to have one!
