Noel
Everything posted by Noel
  1. Well done Tony securing a U class. Lovely loco. If I had one I would have needed to add power pickups to the pony truck to get over my points, or alternatively fit 'keep-alive' capacitors to something like a Lenz Gold decoder. 4-4-0 will look great on Omagh junction.
  2. I was asked on a kadee coupling Q&A thread over on RMweb what glue I was using to fix the couplings to the underside of wagons and coaches rather than screws, in situations where NEM pockets were not available or unsuitable. So far "Deluxe Materials Rocket" super glue has worked well with a great variety of plastics from the soft shiny stuff Hornby used in the 1970s, ancient Lima plastics, to recent production Bachmann wagons, and indeed IRM ballast and cement wagons. I usually rub down the surfaces and the side of the kadee shanks or topside of draft gearboxes before gluing with a micro file or fine sand paper. So far I have found it more efficient and faster than drilling and screwing. Nothing has fallen off so far after converting about 60% of my stock and extensive running. I'd nothing to lose by trying glue, having screws as a fall back alternative had the glue not been effective. Below, Bachmann Y25 bogies converted to Kadee couplings.
  3. Impressive base board construction. Looking forward to following this layouts development.
  4. Looking superb as is now expected. A rake of eight should fit nicely on Kingsbridge. It is bizarre that this extremely high standard of model is becoming considered the norm or almost routine - it is not normal, it is exceptional.
  5. Yes Hornby stuff back then really was rubbish until Bachmann forced them to raise their game. Bachmann were light years ahead of them.
  6. Work continues on the 3D FUD 42ft wagons by Neil. Fitted kadee couplings tonight and test run on layout. A little plastic fettling needed to glue kadee no 20s to the Bachmann bogies. Quick check on height gauge. I was impressed with 3D using FUD (frosted ultra detail) so had to try one. Looking forward the IRM wagons later this year. Bell 42ft container arrived on the layout today from C-Rail. The 42ft flat wagons loading gauge seems lower than 20ft container flats, don't know if thats a model error or was the case with the prototypes. Test runs on the layout went ok with and without a container load. Now for decals, few paint details and light weathering.
  7. Captured the atmosphere of this city railway scape sublimely. Modelling to a high professional standard.
  8. Well its a reflection of economic progress, thankfully we are no longer a poor country and most of our citizens can afford to travel by their own means on roads and motorways. Back in the distant past many folk especially in rural areas could only afford public transport and either a bicycle or a horse/donkey. A greenway seems the best way of preserving an amenity and the railway heritage, and at least it puts the line space back into use as a significant tourism amenity boosting local economies. The Westport to Achill greenway on its own has transformed the economy of that entire region, and the Waterford to Dungarvan similarly in time. Having Dungarvan connected as a greenway on former railway lines all the way to Rosslare seems the best alternative to just closing the lines and letting them disappear into decay. We would all prefer to see trains operating but progress and economic reality dictates otherwise. For anybody who has not yet had a chance to cycle the Westport/Achill or Dungarvan/Waterford Greenways I would highly recommend both. Stunning scenery, fabulous hospitality and one of the best 'chill outs' you'll ever enjoy. These greenways are family oriented and walker friendly too. Sad to see any line close but at least the end game seems positive.
  9. Noel
    RIP Jim Bayle
    Sorry to hear. A true gentleman.
  10. Did the loco run ok with the decoder before you added the lights? Are you using a DCC ramp meter to measure the track voltage? An ordinary Ammeter/Multimeter won't read track voltage properly even if you set it to AC because of the DCC wave form. Most DCC systems will output 15-18volts to the track. US systems tend to be closer to 15v whereas European gear such as Lenz, ESU, etc are closer to 18v. DCC decoders will convert this to max 12v going to a loco motor. I suspect the wiring for the lights may have been your problem rather than the Prodigy. Some systems such as NCE have an adjustable pot inside the controller for fine tuning track voltage, but this is only for small changes and not enough to blow a decoder. Hope this helps.
  11. Hi Patrick Enjoy the transition. That's a good DCC system. For whenever sound becomes of interest, links below to two excellent producers of Irish diesel DCC sound chip projects. I've used both types on my MM B&T 141/181 locos. Fitting speakers and soldering to the loco PCB is straight forward and both supply speakers with the chips. Wheeltappers use LokSound chips with PowerDrive feature and MrSoundguy uses Zimo chips with RealDrive. I just love the sound especially flange squeal shunting a rake of wagons into a siding or over station pointwork. The LokSound has a kadee uncoupling function for use over uncoupling magnets which synchronises engine and coupling sounds with the brief backwards/forwards motion needed to release the buckeye over an uncoupling magnet. Noel http://www.wheeltappersdccsounds.co.uk/page78/index.html http://mrsoundguy.co.uk/msgdclass141.html
  12. AS getting very positive reviews over on RMweb as the first HUO's arrive with customers. Well done guys. http://www.rmweb.co.uk/community/index.php?/topic/130571-accurascale-announce-4mm-scale-huo-and-buffer-detailing-kits/page-14
  13. Noel
    OO Works J15
    Yes at £295 they are rather expensive but I felt worth it if the quality was as good as their previous RTR projects, and it is a unique and classic Irish steam era loco. OO Works have a good track record. Commissioning a top job on a brass kit would have cost more, and there is no way I could build a brass kit to a standard that would look as good as this and equally important run as freely and smoothly as this hopefully will. I doubt we will ever see RTR versions done in finely detailed injection molded plastic due to economics.
  14. Noel
    OO Works J15
    Really looking forward to this GS&WR 101 class loco later this year. I ordered the grey livery last year. http://www.ooworks.co.uk
  15. Seven ages of CIE coaches I've collected over the years starting back in 1972 with a hand repaint of a Hornby LMS maroon coach I was so frustrated there were no Irish trainsets available back then. Then some early Lima and Hornby stuff that was rather crude before Bachmann and Murphy Models came to the rescue in the more recent past. I seemed to have missed the entire Lima mk2 and mk3 coach era. I still vividly remember the excitement back in 1972 mixing humbrol paints in an effort to brush on a shade of CIE tan/orange. I was determined as a youngster to have at least one Irish looking toy train.
      • 5
      • Like
      • Informative
  16. Well done AS. Looking forward to reading the positive reactions over on RMweb when folks get delivery and are bowled over.
  17. This project is a great idea.
  18. Fab set of photos in great light. Parts of Norfolk are living in another era, the land that time forgot. Love the shots around Brundall. Shame Broom have ceased both manufacturing and sales as they wind down the boat business. I understand their main sales guy Paul Pardon retired last year. Top guy. Nice pic of the 39KL on the hard standing. Love the class 37s, brings back memories of travelling there the late 70s and early 80s. Some of the stations seems in a state of mild decay, weed growth, etc.
  19. Bizarre you should mention that @popeye, only about 60 seconds ago I realised I had forgotten to put the brake parcel van in the formation for the video.
  20. TPO running trials prior to finishing. CIE night mail train. Thought it wiser to test run before fitting the small fiddly bits in case any manhandling was needed with bogies, but all went well and CIE bogie TPO 2974 is running well at all speeds in all directions over a variety of track work and points.
  21. Very nice David. Where did you source the magnets?
  22. Wonderful work looking fabulous. Filled with nostalgia looking at the subjects and the brass workmanship.
  23. Expensive for a paper weight. Thought they generally go nowadays for between €50-70
