Andy Cundick
Everything posted by Andy Cundick
Its an oft repeated mistake that No2 in the Red wagon series was one of the Clogher vans i've got 3 photos of No2 (ex Castlederg) (been there modelled that).So the numbering for the opens start at No2,No1 being the much photographed Breakdown wagon,now it is usually stated that the opens were numbered 3 to 9 now we know that s wrong as the above photo shows,now the next problem is that the above numbering allows for 7 opens,the problem is that the Castlederg only had 7 opens and No 28 (the odd one) became No228 in the ordinary wagon series,so that suggests that 8 and 9 were Clogher vehicles possibly the one counted as No2 and the rogue Clogher brake van which appeared on a Donegal chassis,which none of the books mention . Hope this is of interest Andy.
Simple answer is noAndy.
I did however i'm at the Oxford narrow gauge bash at Steventon with Castlederg this saturday.Andy
Railcars 9 and 10 were the two survivors of the 4 REO buses the Donegal used in the early 30s,Andy
The Broad gauge "Iron Duke" built for the Science Museum, Boiler and cylinder block from an Austerity,tender and carrying heels were 08 shunter wheels and the tender axle boxes and guides from a pair of ROD tenders which had been sat in the con yard at Swindon for a fair number of years shame really as they had been used as sludge tenders with the middle axle removedyou could still see ROD on the side of them,Andy.
Cavan & Leitrim Railway brake van 16L - ref pic?
Andy Cundick replied to Pete00018's topic in Irish Models
I suspect the paneling differences are down to what alli sheet they had,probably 16 was paneled first and got away with full sheets whereas the others end up with increasingly more joints,Andy -
MGWR Passenger and Goods Stock - is there a need?
Andy Cundick replied to 2996 Victor's topic in Irish Models
Quite agree about Recreation 21 their MGW brake 3rd hangs above my workbench as an awful warning about how bad things can be better approach is probably resin cast bodies.The North British Railway Study Group have done several wagons which need nothing in the way of tidying up afterwards just adding w irons and brake gear.Similarly Cam Kits do some Cambrian Locos with the main body in resin which exquisite.(just lining and lettering an "Albion" 240 ready for Expo EM),Andy. -
Completely agree about the pandoras box,my first two full scratchbuilds were Castlederg 4 and 5,then a Rhodesian Class 15 garratt just because i always fancied one(looks a bit odd at Castlederg).Another goods source of tools and metal is Chronos their small drills are about 2/3rdsthe price of Eileens with no minimum order and freepost.Andy.
- 309 replies
- 4
- mgwr
- 21mm gauge
(and 1 more)
Tagged with:
Thats certainly 16,the usual trouble is that most photos don't identify stock and even if they if surprising how often they're wrong,good luck with the vans i ought do another 1 or 2 for Arigna Andy -
Pete the "strap" around the middle is a joggle in the top sheet to overlap the bottom sheet in stop water ingress whereas the doors on the others seem to have residual framing 16 is just plain sheet so is the plainist one of the lot,Andy. -
The thing with using the Mainly trains chassis is that you have all the bits and instructions which if its your first chassis will simplify things.Alan Gibson did do the frames even though they are not in there current list however bear in mind that what you get is just that a pair of frames with cutouts for hornblocks,Two tools i would suggest you acquire is an 1/8th reamer and the GW Models wheel quartering jig (makes quartering simple).Andy.
- 309 replies
- 1
- mgwr
- 21mm gauge
(and 1 more)
Tagged with:
My E Class (thats the MGW one no the NER one),was built from the TMD kit now done by SSM,i don't know how much it has changed but the (about 35 yrs ago) it came with 2 chassis neither of which i was very impressed with,the fact that Gibson does the frames indicates i wasn't the only one.If you are thinking of doing a 21mm gauge one,i would suggest the best plan would be to use the Mainly trains J72 chassis with longer axles and spacing washers.For the chassis and then have go at building your own body,its a nice simple one to do,brass tube for the boiler and next size up for the smokebox.There are drawings for the loco in Model Railways Oct 1976.For cabsides/tanks the trick is to sweat two bits of brass together then using PVA glue stick the plan onto the brass and cutout round out round it once done unsolder the two sheets and there you are both sides done at once.The trick with scratchbuilding is not to focus on the whole thing but just on the bit you're doing ie footplate that way its less daunting.Why brass and soldering? because i when you cock it up a touch of the iron and you can have another go,try that with plastic.If you do go down that route i've got the original pattern smokebox and chimney you can have which came with the kit as did 552 in the 30s so they're surplus to requirements.Andy.
- 309 replies
- 3
- mgwr
- 21mm gauge
(and 1 more)
Tagged with:
16L final condition is the same as 17L apart from the side doors which are paneled the same as the side.Andy. -
Just checked my Cavan albums and come up with 3.As my computer skills are not up to this picture sending lark i'll have to print them up and send them by post,however the details are very simple,the whole van including ends are alli clad with single swage line halfway up the body this includes the side doors,hope this helps Andy. -
Bear in mind Wizard does the Mainly Trains replacement chassis kit for the J72,my one went together easily as did the conversion bits to a J71. My own Class E uses the frames from Alan Gibson as i didn't fancy either of the chassis that came with the kit.Andy
- 309 replies
- 2
- mgwr
- 21mm gauge
(and 1 more)
Tagged with:
Thats part of the challenge i'd never built trackwork until i did Valencia and as there was no way i was going down the 00 route i just got on with it(a fairly steep learning curve admittedly)and now building track is no problem (famous last words).Though i admit a broad gauge (7'0") threeway point is causing a certain amount of a challenge.Andy.
The thing to note regarding coaches is that the Southern filled in the door toplights which is how PECO depicted them, The thing that slows me up is the early livery which is to put it politely fiddly.Though saying that i've just finished three North British locos in pre great war livery ready for Expo EM in a week now that is over the top.As to the modelling an actual location lets just say it works for me.Andy.
Hi Mark Yes The locos are all Backwoods in the early cab form,the coaches are all Worsley as Alan has done them in the original form,sadly the Peco and Langley ones are both in the Southern condition,still at least i can use the PECO brakevans the first bit of ready to run i've bought in years.To be honest doing an actual location is easy someone has already done the planning for you and if its an interesting prototype it should come through in the model plus i find knowing what is needed in advance stock and that can be built first along with buildings etc and only then do you put saw to wood and by that stage what you have is kit of parts for the whole layout.The downside to this approach is the vast number of appealing prototypes which leads to multiple layouts,in my case 8 up and running and another 4 in the planning construction phase,Andy.
Nice to see someone else doing early L&B one of my current projects is Lynton in 1898 to scale(it works out at 12'x18"),currently got one Manning finished and 6 coaches with enough little green boxes to do the other 2 and Lyn, Fortunately Worsley does etches for all 17 coaches in their original condition so i'm plodding my through them,its the livery that takes the time.still its a bit of challenge,Andy.
For the topfeed try 247 developments they do a Stanier one.Andy.
My planning is a bit more basic comprising of a sheet of ply 3 foot steel rule and a pencil.Andy
