raymurph Posted March 31, 2024 Posted March 31, 2024 The 0-6-0 475 is lovely, what is it and where did you get it? 1 Quote
Galteemore Posted March 31, 2024 Posted March 31, 2024 36 minutes ago, raymurph said: The 0-6-0 475 is lovely, what is it and where did you get it? It’s an OO works CBSCR loco. Now out of production. https://www.ooworks.co.uk/reviews 2 Quote
Westcorkrailway Posted April 1, 2024 Posted April 1, 2024 2 hours ago, Galteemore said: It’s an OO works CBSCR loco. Now out of production. https://www.ooworks.co.uk/reviews Lovely model, shame about how they run themselves into the ground… 1 1 Quote
Noel Posted April 2, 2024 Author Posted April 2, 2024 (edited) On 31/3/2024 at 9:44 PM, raymurph said: The 0-6-0 475 is lovely, what is it and where did you get it? Cheers, it came from 00 Works a few years ago [GSR 475 (Ex CBSCR)] Edited April 2, 2024 by Noel missing data 1 Quote
minister_for_hardship Posted April 10, 2024 Posted April 10, 2024 On 1/4/2024 at 1:07 AM, Westcorkrailway said: Lovely model, shame about how they run themselves into the ground… I suspect bunker capacity may have limited usefulness on longer runs and aprés amalgamation there was no shortage of handier locos available to poke around the city quays and Courtmac. 1 1 Quote
Galteemore Posted April 10, 2024 Posted April 10, 2024 31 minutes ago, minister_for_hardship said: I suspect bunker capacity may have limited usefulness on longer runs and aprés amalgamation there was no shortage of handier locos available to poke around the city quays and Courtmac. I think he’s referring to the working life of the model on this occasion….based on previous posts….is that correct @Westcorkrailway? 1 Quote
Westcorkrailway Posted April 10, 2024 Posted April 10, 2024 Yup. The reason they were got rid of them was a slightly non standard design next to something like a J26 the model itself just does not work. For all me and Rodrick attempts to make it work. The gears just wear themselves to naff. I suspect it’s something to do with the wheels as a pose to the worm and wheel like I previously suspected. I’ll still keep it because these locos often worked Cork-Kinsale. I don’t run models all that often anyway. It’s just a shame this model will likely never run again unless I paid for serious surgery 2 Quote
Mike 84C Posted April 10, 2024 Posted April 10, 2024 Funny thing Westcork, mine also stripped the pinion gear within a few hours running. Rodrick did supply a new gear FOC for me to fit. I have washerd the lateral play to the absolute minimum keeping the worm in the centre of the pinion. Although with straight cut gears that should not be so much of a problem. The worm teeth on my loco are so sharp you could shave with it! 2 Quote
Galteemore Posted April 10, 2024 Posted April 10, 2024 Is this simply a CBSC problem or have similar issues emerged with other OO works locos? 1 Quote
Flying Snail Posted April 10, 2024 Posted April 10, 2024 36 minutes ago, Galteemore said: Is this simply a CBSC problem or have similar issues emerged with other OO works locos? It looks like a couple of J15s had gearbox issues in Raheny in 2022 .... 2 Quote
jhb171achill Posted April 11, 2024 Posted April 11, 2024 I know of another J15 owner who encountered this issue. I’ve three, plus a CBSCR tank. No issues so far but none have seen huge running. Quote
Westcorkrailway Posted April 11, 2024 Posted April 11, 2024 17 hours ago, Mike 84C said: Funny thing Westcork, mine also stripped the pinion gear within a few hours running. Rodrick did supply a new gear FOC for me to fit. I have washerd the lateral play to the absolute minimum keeping the worm in the centre of the pinion. Although with straight cut gears that should not be so much of a problem. The worm teeth on my loco are so sharp you could shave with it! Yup, sounds identical to what happened to mine. And Rodrick had it repair d free of charge including the postage to get it there and back but alas it still isint working right. I love 00 works and I without them there is no way in hell I would have ever gotten a RTR CBSCR loco (the most unlikely thing ever) but it’s purley for stationary use nowadays. 17 hours ago, Flying Snail said: It looks like a couple of J15s had gearbox issues in Raheny in 2022 .... I remember attending the Blackrock show in 2022 and a J15 was working Castletown/ballygluin. I went there around midday and watched the J-15 completely fail meaning a deisal sun had to come in. The lads were not pleased and I explained to one of them my issues with my loco. I think one of them offered to fix mine free of change, but that was too generous an offer for me so I refused. I think they eventually managed to fix it (posted in this thread somehere) 1 Quote
Horsetan Posted April 11, 2024 Posted April 11, 2024 19 hours ago, Mike 84C said: ...., mine also stripped the pinion gear within a few hours running. Rodrick did supply a new gear FOC for me to fit. I have washerd the lateral play to the absolute minimum keeping the worm in the centre of the pinion. Although with straight cut gears that should not be so much of a problem. The worm teeth on my loco are so sharp you could shave with it! I wonder who the original maker / supplier of the gear set is. It's not unknown for the individual gears to be machined from unsuitable or incompatible stock, leading to premature wear or stripping within a comparatively short timespan. Quote
minister_for_hardship Posted April 11, 2024 Posted April 11, 2024 +1 for another J15 breakdown, worm slipping on the shaft if I recall. Fixed free of charge. 1 Quote
