Graham's layout - Monkhill and Saltstown.
The layout is looking good and taking shape with the platforms looking particularly good.I can certainly recommend the use of sandpaper for the platform surface as I have used it on my own layout,painting it with weathered concrete paint and finishing it with matt varnish.
  • Replies 169
  • Created
  • Last Reply
Top Posters In This Topic
Some detail was added to the platform sides. Don't ask me what these are supposed to be, I just make them to resemble what I have seen on the real thing!
Next step is to weather them and they'll be ready for the layout.
I really like the cable detail on the platform wall. What did you use for the black cable. Looking good
I used thin wire that I stripped out of some old computer cable.
Guest hidden-agenda
I think the edge of the platforms are white and the more modern edges have small indents for the visually impaired. open to correction if i am wrong.
Nice work by the way and i like the cable detail.
Thanks for the comments lads!
Here's a few more of the platforms after weathering and placing on the layout.
That last pic looks a bit odd! There seems to be a bend in the mdf causing the platform to lift at the end. Just a matter of fixing it
down securely.
Looks fabulous keep up the good work. :-bd
As far as the white line is concerned, it was usually quite thin 100 - a 1.3mm strip at 00. The most common approach was to lay 600mm concrete paving or granite slabs as the platform edge, and tarmac/gravel up to it and paint the platform edge white. Later on when the yellow line was introduced it was set back behind the concrete, using a road marking roller to paint the yellow line, again 100mm wide.
Ashtown and Attymon Junction are the first that come to mind made entirely of brick as a platform side.Richie.
  • 1 month later...
Finally some progress!
Finished the retaining walls around the station platforms...
The kiosk, sandwich stall, bike rack and footbridge were Xmas presents!
The headshunt to the left of the platform is also my programming track which is wired through a DPDT switch.
When the led on the buffer is lit the track is under main power and it goes out when the track is in programming mode.
I also made a start on my freight yard and sidings...
The concrete hardstanding is foamboard painted with a mixture of grey emulsion and plaster which gives a good concrete effect.
I have to make some sort of backscene for the yard to hide the mainline running behind it.
Looking absolutely excellent!!! The walls are very effective at 'anchoring' the scene! Loving the hardstanding - what kind of foamboard did you use?
5mm foamboard from my local art shop, the kind with smooth pressed surface on each side.
Looks brilliant! How did you do the walls? Love the programming track with the led.
The walls are 6mm mdf covered with brick paper that I downloaded for free from newrailwaymodellers.com, it looks a lot better when
weathered as you can see.
The brick courses on top are scored in 3mm foamboard painted grey with Halfords primer.
The wall,platforms and hard standing area all look great and blend in well together.A nice airy feel to the layout,which even with lots of stock present would still be a good characteristic of it,well done.
The layout's looking superb! What era is it?
Mainly mid to late 70's. I'm running a lot of Black and Tan and Supertrain liveried stock. But to be honest you cound find anything
running on it, so I'm not too hung up on it! And anyway, I don't know of any Irish stations that resemble mine!
Over the last few days I got the the rest of the freight yard ballasted. After the glue dried I toned it down with a thin black wash applied with an airbrush.
As you can see in the pics I scratchbuilt a couple of sets of floodlights, these have leds fitted but I have'nt got round to adding a power bus yet.
Here's a better pic of them...
I also fitted leds to the sight office in the backround.
More scratchbuilding; a couple of simple ground levers for the points in the freight yard.
Another view...
All that's needed now is some grass/weeds to finish it off.
