GSR 800 Posted March 29, 2015 Author Posted March 29, 2015 all i need now is some new track as the flexitrack that once was the main part of my old layout have practically disintagrated!Off to Marks i go!
Kirley Posted March 29, 2015 Posted March 29, 2015 It's a great feeling starting a new layout especially having an previous one and now you know all the things not to do. Having good track is worth the extra investment to get smooth running.
heirflick Posted March 30, 2015 Posted March 30, 2015 great work there - love the work on your bunker! don't forget the all important' KEEP OUT' sign for the front door!! if that dosnt work you can have this .......
GSR 800 Posted April 10, 2015 Author Posted April 10, 2015 By all means, sketch something up and then post it here if you need further assistance or advice on the design... Did some drawing today not really to scale.i am wide open to ideas and criticismsorry bout the bad photo
Glenderg Posted April 14, 2015 Posted April 14, 2015 It looks like theres a fair bit of shunting required to get from the outside lines into the goods area. Perhaps consider integrating the loops into those areas so you can maneuver from the outside track into the goods area and then do all your shunting in there, freeing up the main lines for continous running? A photo showing both areas zoomed out would be really helpful, even if you only have track plonked down roughly. R
DiveController Posted April 15, 2015 Posted April 15, 2015 Did some drawing today not really to scale.i am wide open to ideas and criticism[ATTACH=CONFIG]18649[/ATTACH]sorry bout the bad photo Hi GSR, I can't really make out your drawing all that well and no expert so throw this 'advice' out if it makes no sense. Access from the inner inner loop to the outer platforms seems restricted unless you reverse the crossover or add another crossover in that direction. Maybe consider replacing the diamond crossing with a single slip if you reverse the crossing? What ever is on the bottom right ?good/carriages shed has limited access from the inner platforms. If this is required then maybe think of running this out of platform 3 (instead of 1&2, if you have sufficient length) and use another single slip to allow access from Plat 1&2 to it?
GSR 800 Posted April 15, 2015 Author Posted April 15, 2015 (edited) A photo showing both areas zoomed out would be really helpful, even if you only have track plonked down roughly. R i hope this is what you mean.I could do with all of your help! Edited April 15, 2015 by GSR 800
Glenderg Posted April 15, 2015 Posted April 15, 2015 Stand further back! :-) need to see the whole thing in context.
GSR 800 Posted April 26, 2015 Author Posted April 26, 2015 some pics of kedleston.new yard design .some pics of the shunter taking ash wagons from the unbuilt shed area
GSR 800 Posted April 26, 2015 Author Posted April 26, 2015 For Kevin The sidings on the left would be a bit longer
burnthebox Posted April 26, 2015 Posted April 26, 2015 Well done GSR 800, you'r doing fine, lot's of help on here for getting your layout set, don't be afraid to challenge suggestions, it'll all work out for the better in the end, well done so far,
burnthebox Posted April 27, 2015 Posted April 27, 2015 Hi GSM 800 mind telling me what size is your baseboard, ft. & ins. please, otherwise it's complicated, thanks in advance,
GSR 800 Posted April 27, 2015 Author Posted April 27, 2015 Hi GSM 800 mind telling me what size is your baseboard, ft. & ins. please, otherwise it's complicated, thanks in advance, 10x2runnig round the board
DiveController Posted April 27, 2015 Posted April 27, 2015 10x2runnig round the board it's basically square, 10ft per side times 4?
GSR 800 Posted April 29, 2015 Author Posted April 29, 2015 it's basically square, 10ft per side times 4? yep,dead on
GSR 800 Posted May 3, 2015 Author Posted May 3, 2015 (edited) Kedleston work on hold until i fully figure out everything with this new plan:( Edited May 3, 2015 by GSR 800
GSR 800 Posted May 3, 2015 Author Posted May 3, 2015 No fun for literally hours guaranteed! (straight jacket and hall for being dragged away not included)Also availbile FREE wailing child sound affects
GSR 800 Posted May 10, 2015 Author Posted May 10, 2015 Quick update.Cant seem to upload the pics.scratch built platforms and engine shed under construction. Once I have all the track laid I will start putting down the ballast.A through station will now be opposite the terminus while the shed and sidings will be between them
GSR 800 Posted August 27, 2015 Author Posted August 27, 2015 So haven't posted in a while so let me fill you in. The track plan is finalised, the terminus is now facing the other way so less shunting is required. A extension board will be placed so there is more space for the turntable and a goods yard, adjacent to the will be some carriage sidings. P.S. I will try and get pics shortly but I can't really get the tablet to upload them
GSR 800 Posted August 31, 2015 Author Posted August 31, 2015 (edited) Edited August 31, 2015 by GSR 800
GSR 800 Posted October 25, 2015 Author Posted October 25, 2015 Well lads,I bought some things while at the SDMRC yesterday. Most of the budget went to locos.for a long time I've been wanting to get one of MR Murphys work. I finally got it today with number 073. Fantastic loco. Great runner detail is just brilliant. I also bought a silver fox A class in green. Holy Sambo it is heavy! Reasonably good runner, but very noisy compared with the 071 class! Also bought an N class mogul, which I plan to convert to a woolwich. Will post pics shortly
GSR 800 Posted January 14, 2016 Author Posted January 14, 2016 (edited) It's 1954 and Meadbh thunders through Kedleston, while 073 ticks over in platform 2, having shunted the stock of its train, into the sidings Edited January 14, 2016 by GSR 800
DiveController Posted January 14, 2016 Posted January 14, 2016 It's 1954 and Meadbh thunders through Kedleston, while 073 ticks over in platform 2, having shunted the stock of its train, into the sidings[ATTACH=CONFIG]22144[/ATTACH] Any video of 800 running, Harry?
GSR 800 Posted January 14, 2016 Author Posted January 14, 2016 I'll try Kev, but it will mean a lot of cleaning for me! Thanks Bosko:tumbsup:
GSR 800 Posted January 14, 2016 Author Posted January 14, 2016 I'll try Kev, but it will mean a lot of cleaning for me! Thanks Bosko:tumbsup: Edit: I probably won't post a vid until I have all the ballasting done and a back scene up
BosKonay Posted January 14, 2016 Posted January 14, 2016 Post away!! It's as much fun seeing a layout grow from the boards as it is to watch video of a finished, detailed layout
GSR 800 Posted January 14, 2016 Author Posted January 14, 2016 By the way the photo was edited to give a 50's colour look to it, just in case you thought I was absolutely sh*te at taking photos
