David Holman
  1. Fintonagh's PECO N gauge turntable has been adapted by adding an extra layer above the well, so with a wider/thicker deck for 21mm track, it is now 168mm diameter, so a scale 42' in 4mm scale - or more to the point 27' for 7mm narrow gauge. It happily takes my developing CVR Railcar, though as you can see, the overhangs are prodigious! Arigna's Dapol/Airfix TT scales out at 60' in 4mm scale. As you can see, I again made it longer, in order to take the railbus and G2 in 7mm scale.
  2. Not flimsy, Tony, but needs work. I turned mine upside down to make it underslung. Also, it is quite big, being 60' diameter in 4mm scale. No brainer for me though, a motorised Metalsmith 42' model in 7mm is over £200...
  3. Have a look at the first page of my Clogger Valley Project and you can see photos of my 21mm track. Ok for 3' narrow gauge in 7mm scale, but to EM standards, to the same in all respects. Each point took about an hour to make, including filing the rails.
  4. Surely every self respecting Irish model railway needs a turntable! Also, one adds a useful extra dimension to operation. On Arigna, only the railcar doesn't use it, because it is too big, while kids of all ages love seeing engines being turned. Arigna's TT is a £4.99 Dapol/Airfix plastic kit, designed for 4mm scale. It uses a Frizinghall Model Railways hand cranked kit (a few bits of Meccano), plus the Mark One human eyeball for alignment. However, though cheap, the Dapol kit has no provision for powering the track on the TT itself. Mine uses 7mm scale plunger pickups in the well wall bearing on brass plates on the girder ends. The Peco ones use a neat system in the central boss. I have the N gauge version on Fintonagh, with the Frizinghall electric motor kit. Rather noisy and slow though, so may yet replace with a hand crank... Would say TTs are not for the faint hearted. They will need either a well cutting in the baseboard surface, or track raiding if a surface mounted one is used. Automatic alignment requires complex electronics too, which is why RTR versions are expensive and I don't go there! Definitely something to aspire to though.
  5. Good on yer. Well done.
  6. That's a shame JB, but understand the reasons why. In terms of why 21mm is a virtual non-starter in Ireland, that is hard to quantify when run alongside EM and P4 in Britain. Am guessing most know it all stems from the early days of HO, when the smaller loading gauge of British engines meant it was very difficult to fit the mechanisms of the time. Equally though, that was precisely why EM and P4 started (the former in the 1950s), because people were unhappy running scale trains on narrow gauge track. These days, I'm not sure EM and P4 could be described as 'niche'. Minority perhaps, but both have a healthy following, with their own dedicated exhibitions up and down the country. One can only wonder why things didn't take off in the same way in Ireland? Maybe the lack of RTR has been a factor, though that is hardly the case today. My only other thought is that, as far as this forum is concerned, the number of layout builders far exceeds the number of loco builders and maybe if there had been more kits available in the past, then more folk might have taken the plunge and learned that such things are not alchemy after all. However, it won't stop me continuing to fly the flag!
  7. Don't forget to use the old engineer's trick of putting a bit of spot on the drill bit/hole. Does a good job of lubrication. Expect the drill bit to clog up when going into white metal.
  8. What a great thing for a dad to do for his son. Way better than anything straight out of a box. Great satisfaction for dad, because he's made it himself (and now clearly better than the original), great satisfaction for the boy because he will own something unique. Nice to think that a fine partnership could develop from here over the years.
  9. Approaching half a million views. Amazing.
  10. It has been good to see that there is some genuine interest in doing 5'3 in these pages. Maybe a good step forward would be for someone to do a blow by blow account of how to convert a Murphy's diesel to show that such things are not in the realm of watch making. A similar thread or two on basic wagon and coach conversion might be valid too. All my fingers and toes are crossed for you, JB.
  11. Alternatively, for anyone seeking a completely fresh start, a simple shunting layout in 7mm scale would require the following: One Tyrconnel/Alphagraphix loco kit. Approx £200 with wheels, motor, gears. About £2-300 for track. Assume points at £60 each if custom made, half that if you build them yourself. Assume around £35 per wagon. Wheels are £10, couplings, axlebox/Wirons, brakes, buffers about £5 each set. A kit is the same as a scratch building in this scale, with the wagon body costing almost nothing if you make it yourself from plastic or card. An Alphagraphix wagon kit, made from card will cost maybe a fiver less, with their white metal fittings and Slater's wheels A workable model can be done in around 8 feet, so total cost would be approaching £1000 (say it quick) and occupy around a year or so to complete. Compare that to a 4mm scale layout with a dozen locos, 20 coaches and 40 wagons and it is not quite so scary. Less is more, especially with the added satisfaction of making it yourself. Beware though, 7mm scale is VERY addictive!
  12. at least it is a J15, even if not the correct one! Love the colours on the building.
  13. Good for you, JB, all power to your elbows! John-r, the answer to your question is a scale 1 foot two inches. 00 track is a gauge of 16.5mm in 4mm to the foot scale [1:72]. In this scale, the correct gauge should be 18.83mm for 'standard gauge [4'8.5"]. In other words 00 track is around 7 inches too narrow. Irish track being 5'3, to use 00[16.5mm] gauge track means you are modelling at 4'1 inch gauge, or 14 inches too narrow. Now, I sincerely hope I don't offend anyone here, not least because so many on this site have been incredibly helpful and complimentary to my own modelling. However, I do find it extraordinary that apart from the late, great, Tony Miles' Adavoyle, I do not know of a single layout built in the island of Ireland that is to the correct track gauge of 5'3, in any scale and it seems to be a handful of people in Britain who have flown the flag. Please tell me I'm wrong! Indeed, I will hazard to opine that railway modellers in Ireland prefer to find excuses not to work to the correct gauge, rather than attempt to do the right thing. I find this doubly strange when there are clearly many talented modellers out there, as this website illustrates so well, with many real sticklers [rightly in my opinion] for getting everything else right, yet happy to work in a gauge that is 25% too narrow! Now, I very much appreciate the reasons why folk might stick to what is available - commercial support and ease of modelling, the latter especially important to those who are not confident at building locos or adapting mechanisms.Be that as it may, I must stress that I was not born with a silvered soldering iron in my mouth. I have no formal training in wood or metal work and am essentially self taught. By that I mean reading widely and having a go - not being put off by failures [and there have been a few, believe me], plus talking to those who have succeeded to find out how it is done. I am sure for most that the hardest thing in contemplating 21mm gauge will be the combination of making track and widening the wheels to suit. In 7mm scale, the latter is a piece of cake. You go on the Slater's website and order the appropriate loco axles, while the wagon and coach wheels simply get pushed out to the wider gauge. In 4mm scale, I can't see that track should be a problem for anyone willing to have a go. C&L do point kits with ready assembled crossing vees and machined blades. All you have to do is slide chairs on to the rails and then weld them to the plastic sleepers with solvent. The only soldering will be to add the tie bars. The single issue is that of a track gauge. It ought not be too difficult to get a 21mm roller gauge turned up somewhere. C&L may be able to do one on request. Alternatively, talk to Marcway [phone number in their advert in Railway Modeller]. They do custom track for pretty much any scale or gauge, using soldered, copper clad sleeper construction. Plain track is easy to do: make a simple jig using card to get sleeper spaces. Solder one rail in place, then put this half track on the layout and then solder the second rail, using a 21mm gauge. On Arigna, my 36.75 [ish]mm track gauge is a piece of flat aluminium I filed up. The layout has never suffered from derailments because of this, while the Marcway points I commissioned have been superb and the layout has its 30th exhibition outing in January. Now, I have no experience of building 21mm gauge locos or rolling stock, but I am fairly sure I've read in several places that replacement wheels/axles for Murphy's diesels are little more than a drop in. However, if not, then this is probably where the main barrier lies. A wagon kit [or indeed regauging a proprietary wagon] should not hold any terrors. Chop off the narrow gauge W-iron/axlebox castings and fit new ones wider apart. If 21mm axles are not readily available, buy some brass/steel/nickel silver rod of 2mm diameter [an internet search will soon find you some] and cut some yourself. This is what I have done on Fintonagh, using 2mm brass wire/rod and making 'pinpoint' ends [to go in the bearing cups] by spinning the rod in my fingers while holding it against a slitting disk in a mini drill. It takes less than a minute... The issue with a locomotive is that [if steam outline], the wheels need quartering, to ensure they turn smoothly when the coupling rods are attached. Not the case with diesels & I would think that something similar to the wagon exercise could be done - you just need to make sure the main gear is a good fit. However, I'm sure this must be the heart of the problem - where do you get 21mm loco axles from, that are easily quartered [like, say Romfords] because they have square ends? Fear not though, because the Scalefour Society website tells you how to do it with plain ended axles & it is very simple. It must be, because I've done it several times. If a kit of your chosen loco only comes with narrow frames, note that , by fitting the wheel bearings back to front, you get the right spacing, without the need to resort to making new frame spacers. I could go on & no doubt some of you will be thinking 'its alright for him, he has years of experience'. Remember though, I started with zero knowledge and zero experience and has simply persevered and learned as I've gone along. What I do really isn't that difficult - otherwise I would have given up years ago. Believe me when I say I am in no way criticising those who want to stick with 16.5mm track. It is your hobby, to do with as you wish & as long as you enjoy it, so much the better. I guess what does disappoint me though is that there appear to be so few people doing 5'3 [in any scale] & it really would be wonderful to get a few more on board. Currently, its lonely out here! It does look rather splendid after all & makes the extra effort so worthwhile. There, I've said my piece and sincere apologies if I've offended anyone.
  14. One 25th of an inch JB. Code 100 is a tenth, code 75 is 75/100ths
  15. No prizes for guessing my view on this JB - just do it! If wary about track, phone Marcway in Sheffield. They custom made my points for Arigna for not a lot more than Peco. They are robust and self isolating, so no extra switches required and can be operated by wire in tube so overall cost no more than if points motors are used . Plain track can easily be made using copper clad sleepers, or C&L components, which only require glue. A 21mm roller gauge will be needed, but again, Marcway could turn one of those for you if you didn't"t want to make your own. For Arigna, I filed a thick piece of brass to 36.75mmish and have no derailments whatsoever. As Eoin says, locos and stock need not be a problem if you choose carefully. With only a couple of locos needed, it should not be expensive to pay someone to convert them anyway. Everything else is the same and with a small layout, there is little to lose and everything to gain. Remember, 21mm gauge does NOT mean P4 standards. You can specify finescale flangeways on points so they will take mainstream wheels. The main reason though is why model 4'1 when the gauge is 5'3, especially on a small layout? It bugs me that there are now only three 5'3 layouts being exhibited. Mine, Valencia Harbour and Ballyconnel Road. Correct gauge really isn't anymore difficult once you get started, but as Henry Ford famously said 'if you think can, or if you think you can't - you are right'. I would also say, ' come on in, the water's lovely!'
  16. Bexleyheath today. The new G Class, Deutz diesel acquitted itself very well today, in somewhat trying circumstances. Nothing wrong with the show, or indeed the hospitality, but the weather highlighted the problems of a winter show. The day began in pouring rain and 1c, soon turning to snow, so by the time I reached the venue at 8am, there was an inch of slush on the ground and it was snowing hard. Not the best recipe for getting a layout 50 yards from car to halls, especially when other exhibitors vehicles blocked the way necessitating sackbarrowing the boards across more mud and slush. With the doors open, the hall was pretty damned cold, but unfortunately it stayed that way as this was the entrance and, there was NO heating! Arigna Town lives in what was once an integral garage, but now my workshop, complete with central heating, so it does not enjoy the cold. Axles boxes seem to tighten, meaning the two small tanks especially suffer from wheel slip, while the turntable also tends to catch the coping stones around its edge. Add in a broken toggle on one of the points [meaning the wire in tube could only be push/pulled using pliers] and it was a more trying day than usual, with a fair bit of remedial work needed for the next outing at the end of January. Equally, such things are all part and parcel of the exhibition scene. Layouts lead a hard life on the road, with 7-8 hours of intensive use each day, so you tend to expect stuff to happen from time to time. If only it hadn't been quite so cold! However, the little G did itself proud, substituting for the J26 on the stores/coal trains. It could probably do with a bit of weight in the bonnet to help the four wheel drive, but has proved to be a smooth, slow runner, ideal for such duties. By packing up time, at least it had stopped snowing and the roads were mercifully clear on the way home.
  17. B*****. And there it is, in my 1960s Observers book...
  18. Indeed! A 4mm scale Merit GPO sack masquerading as such. Don't look too closely at the builders plate either. It actually reads 'Built in Derby'...
  19. G Class complete -ish. Remaining work was to fit the bits I'd bought at Reading. A nice set of sprung buffers [Markits from Roxey] and a much less pleasant set of axles box/spring castings from JPL, which I may well replace when I can find something better. Not their fault, these were just the best of a bad job in terms of trying to find something suitable. Despite being cut down, they are still too chunky. Thanks to all the photos and advice, I've managed to do a representation of the cab interior, while the roof [being etched in thinner brass than the rest of the 'kit'] was easy to form. A long wax casting of a horn [EDM Models], with a bit of brass shim soldered above it as a weathershield completes the picture. So to painting. I'd figured that getting some silver grey car spray paint wouldn't be difficult, as 50% of models in Britain seem to be this colour. However, there lies the problem - 50 shades of grey [at least] and all of them metallic, so not really suitable. Eventually, I found a can of 'aluminium', a bit shiny, but of course, like all other CIE silver diesels, this was never going to be clean. In fact, it is much dirtier than the pictures show, but certainly nowhere near as shiny as it started. Numbers are a bit of a bodge. I found some prefix transfers in my collection, so it is a GWR 'G', with BR numerals. Was briefly tempted to make it G604, as an extra loco for the SLNCR, but went for 602, with the cream colour painted over in green with a fine brush. Overall, not too bad, considering I only began the model a week last Wednesday and Sunday - Tuesday was at Birmingham Christmas market.
  20. Easy-Build Coaches, Eoin. Got them at the Reading Trade Show last Saturday. They do a lovely range of coaches, DMUs and the like, plus various bogie kits that are so good you only need to shake the box to make them. Well, nearly... Website is easybuildcoaches.co.uk Proprietor is Shawn Kay, based in Camelford, Cornwall.
  21. Thanks yet again, JB. The model is making decent progress, though am saving pictures of it until finished. However, built the chassis today. It is a sub unit, with the frames made from brass strip. Soldered two pieces together so I could drill out the bearing holes, then after separating them used some 32mm gauge spacers left over from my SLNCR Small Tank kits. As this inner frame cannot be seen, I've used the Alphagraphix/Tyrconnel trick of soldering the top hat bearings in back to front to give the correct wheel spacings. Unfortunately, I wasn't able to get any broad gauge axles at the Reading Trade Show, so I've borrowed a pair from my J26 loco, to go with some 3'1 DMU wheels I was able to buy. Power comes from a Premier Components 40:1 gearbox and Mashima 1933 motor - this is a ready made unit & ideal for this model. I also got some Delrin chain and idler wheels from Easy-Build Coaches. The idler gears had to be cut down a little to fit between the frames, but the model now has 4 wheel drive. Pick ups could be very basic, as they are hidden behind the outer frames, so not much more than a morning's work and the G could move smoothly under its own power. The Delrin gears make it a little more noisy than the other locos, but so far, so good.
  22. Probably the best designer of small layouts is Iain Rice & have attached a photo of his drawing of Wantage Town, where you can see that the station is only 4' long AND, this is very much to scale! However, in his book 'Urban Layouts', he has created some real gems, including a straightforward shunting yard, but also a super little two level layout in just over 6' and finally three separate 4'6 modules, designed to be linked together vertically using cassettes. If you can get the book, it is well worth reading.
  23. Superb. Thank you. However, at the risk of stretching things even further, given the 601s had no vacuum brakes, presumably there must have been a handbrake somewhere. Was it a wheel type or the old style brake stand we see on Steam locos. And if so, where, please...?
  24. It is on the Irish Traction Group website, Eoin. I found it by googling CIE G class diesel. On the site are notes about various withdrawn classes and among them the G. Each loco has a click on section and one of them shows a before and after shot of the control desk.
  25. Does the 4x1 include the fiddle yard/headshunt? The smallest prototype yard I can think of is Wantage Town, which scales out at just over 4' in 4mm scale. Not Irish of course but not dissimilar to Irish practice. The other thought is Inglenook Sidings, a shunting plank designed some years ago. No loop, just three tracks for wagon shuffling using a card system to create a puzzle. Either way, nothing is really that small, so you are better off with a track plan that suits your needs and the make it Irish in theme by deciding what the traffic source(s) will be.
