BosKonay
Moderators
Everything posted by BosKonay
  1. Typically one goes for a high price, so a few eager sellers hop on the proverbial bandwagon.
  2. Hi Robert, Do you mean on the A class? Chinese New Year has been essentially ongoing the last two weeks, and the factories are only coming back online at the moment. It will be another week or so before they are back up to speed as workers return from 'up country'. The Plough is in the final assembly phase, and the 42' project and A class are in the toolroom however. Updates as we have them!
  3. http://archiseek.com/2009/1926-former-great-northern-railway-engine-shed-clones-co-monaghan/ http://archiseek.com/2014/engine-roundhouse-portadown-co-armagh/
  4. Check out these options https://www.modelrailbaseboards.com/storage-units @Dave
  5. Our market research would indicate, particularly for the UK market, that the 'KEY' era(s) for modellers is from roughly 1945-1975
  6. We're working on it....
  7. Lot of love for Slate grey!
  8. Now you just need to convince the other three lads!!!! I’m sold!
  9. https://www.ebay.co.uk/itm/BACHMANN-MURPHY-MODELS-CLASS-221-VOYAGER-REWOKED-INTO-IRISH-MK4s-/183611919110?nav=SEARCH
  10. You’ll need to desolder the wired speaker too. Also be sure the onboard is 8ohm a super the TTS only work with 8ohm speakers.
  11. Sounds like the speaker is blown? That or one of its connections is loose in some way. Inspect for any loose wires first off. If all looks ok you could check the resistance across the speaker with a multimeter. If there is no reading the speaker is gone
  12. Assuming it has the right number of pins you can plug in any sound chip in theory.
  13. Our version, included with the Buffer Stop
  14. Pretty sure that’s a 3D CAD render not an actual print.
  15. Everything.
  16. D'Oh, thanks railer, fixed and more coffee applied
  17. Corrections Made https://irishrailwaymodels.com/collections/a-class-locomotive?grid_list=grid-view
  18. Initial deco plates of the loco fronts have now been added. More to follow! https://irishrailwaymodels.com/collections/a-class-locomotive
  19. Adding this via Wrenneire
  20. BosKonay
    Tara's
    https://irishrailwaymodels.com/blogs/announcements/ploughing-champions-decorated-samples-arrive
  21. BosKonay
    Tara's
    Sorry! Basically the wagons have a sprung mobile coupling pocket installed to nem352 standards, underneath the body not on bogies, which allows you to close a couple using the bar or your preferred coupler. The coupler itself can swing independent of the bogie position
  22. BosKonay
    Tara's
    The NEM362/kinematic coupler assemblies on the wagons should make draft boxes redundant. It’s also why we included close coupling bars with the Tara’s.
  23. BosKonay
    Tara's
    Has anyone tried the supplied close coupling bars?
