Tullygrainey Posted July 26 Posted July 26 2 hours ago, Mol_PMB said: Well done for getting it sorted and I admire your persistence in the face of adversity. I'm not sure I've got it in me to take the risk of exhibiting anything, so I really admire those who do. It certainly seems like you need multiple backups of everything to ensure the layout keeps working. It can be challenging for sure but very satisfying when it goes well. Even when it doesn't, it can be an incentive to try harder and the satisfaction comes from solving the problems (or taking a hammer to the insoluble ones - just joking, there's always a solution). In actual fact, it's likely that visitors often don't notice that you're having a bad time because many don't spend long observing any one exhibit. And if nothing is moving on the layout they just pass on to the next exhibit, leaving you to have your nervous breakdown unnoticed 5
Colonel Posted July 27 Posted July 27 Very true Alan! It can be hard to rationalise why anyone would dismantle their layout, bounce it over potholed roads to an alien environment, reassembled it and then run it in public for seven hours or more only to then reverse the process and take it home again. We do though, probably because underneath it all, there is a quiet satisfaction in creating something that others might want to admire. Talking with people at shows is always enjoyable, from how you make things to trying to explain scale/gauge combinations and all points in between. You learn a lot too. For anyone considering getting into exhibiting, I would suggest joining a club or group and then volunteering to help at a show. That way, you learn about all the preparation that goes on beforehand and well as stuff like operating in public - which is very different to doing it at home. I think many exhibitors are closet thespians at heart because you are very much putting on a performance, one where you even build your own theatre before setting a scene and telling story. And when the muse takes us luvvies, the show has to go on! 5 3
Colonel Posted August 17 Posted August 17 Swillybegs was at the Dreamworks 1:1 at the weekend. DreamWorks is of course the Hornby factory in Margate but the 1:1 part is special as it is a a collection of full size stuff that currently opens only one day a year. It must be the closest thing to the show that Cultra used to run, because of being among the real locos. The ground floor includes a Eurostar loco, Deltic 9016, Royal Scot 46100, a Hall 4-6-0, a breakdown crane and a 4SUB EMU. Below that are working layouts in 0 and 00, alongside display cases of large scale models. The mezzanine above has the restored Gresley beavertail observation car, plus a small selection of motorbikes, cars and a tank! There are also many five inch gauge locos too. I was there with the Chatham Club, plus several other ones who brought layouts and stands from some of the local preserved railways. It really was a splendid place to be, but though I took my camera, I'd left the memory card out. Took pictures on my phone, but at the moment can't get them transferred to my laptop. Hopefully will post some later... 6 2
Broithe Posted August 17 Posted August 17 2 hours ago, Colonel said: though I took my camera, I'd left the memory card out. Having been very nearly badly caught out in the same way, my rule now is to not close the door, if there is not a card in the slot. This has saved me a few times.
Colonel Posted August 20 Posted August 20 By the way, it is Wonderworks, not Dreamworks. Google the latter and you get Disney... 1 1
GSR 800 Posted August 20 Posted August 20 41 minutes ago, Colonel said: By the way, it is Wonderworks, not Dreamworks. Google the latter and you get Disney... I was thinking surely they'd run into a copyright issue
Colonel Posted August 23 Posted August 23 Unfortunately, haven't been able to find a way of posting photos of the Hornby 1:1 weekend, but here's another salutary tale of exhibiting a scratch built layout. Swillybegs as a layout, still works as well as ever, but issues with some of the stock continue - not helped last weekend when a stock box nearly fell out of the car. Caught it just in time, but only to find that several couplings had sprung and loco crew clearly jumped to safety! Some things worked well all weekend: Railcar 10 and the West Donegal Trams were pretty much faultless, probably doing twice as much mileage as the rest of the trains. Following the usual post show cleaning & fettling, the latter can now do as originally intended, by accessing the layout via the front track. This means Railcar 8 can enter via the mainline. The two Swilly trains suffered mixed fortunes. My Barclay 4-6-0T is already looking a bit battered and at times was limping along in very ungainly fashion. Turned out the were no less than three separate faults! First, noticed a crankpin has come loose off one of the rear drivers, also one of the front drivers had come loose on its axle & gone out of gauge. A built in problem caused by using Gibson 4mm drivers because the right diameter 7mm ones were not available. However the real culprit was part of the brake gear. This had also worked loose and was flapping around behind the frames, catching on the driving wheel spokes. Despite all this the engine did its best to perform, but was looking an increasingly sorry sight, so had to be retired on the Sunday morning with one of the Clogher 0-4-2Ts substituting. Back home, the mechanical issues were easily sorted, but the paint work will need a bit of work before the the next show in October. The 4-6-2T and fish train had different problems as this was in the box that nearly hit the floor. The loco was alright, but both bogie vehicles suffered coupling damage. Managed to get these repaired at the show, but the train kept derailing as it entered the layout from the fiddle yard. Back home, traced this to the cassettes not aligning. Hard to work out why, but various amounts of filing and adjusting have been needed to set everything right. The photos show a rarely seen corner of the layout though, so may be of interest. The Unit & its short goods train [along with Phoenix] were in the same stock box, so also suffered some broken couplings. There are enough spare wagons to cover occasional problems like this, so we got by, but some erratic running towards the end of Sunday afternoon turned out to be rather more crud on the pick ups than I'd expect from an air-conditioned exhibition hall. Maybe I needed to clean the track more often? The last picture is my take on Maggie Coulter's goat - a tale from the Clogher Valley railway, which always causes amusement. The model was hand made by me a few years ago, when I could't find a ready made one. Anyway, such are the slings and arrows of exhibiting and it only goes to show you always need plenty of stock - just in case! 16
Mol_PMB Posted August 23 Posted August 23 3 minutes ago, Colonel said: Unfortunately, haven't been able to find a way of posting photos of the Hornby 1:1 weekend, but here's another salutary tale of exhibiting a scratch built layout. Swillybegs as a layout, still works as well as ever, but issues with some of the stock continue - not helped last weekend when a stock box nearly fell out of the car. Caught it just in time, but only to find that several couplings had sprung and loco crew clearly jumped to safety! Some things worked well all weekend: Railcar 10 and the West Donegal Trams were pretty much faultless, probably doing twice as much mileage as the rest of the trains. Following the usual post show cleaning & fettling, the latter can now do as originally intended, by accessing the layout via the front track. This means Railcar 8 can enter via the mainline. The two Swilly trains suffered mixed fortunes. My Barclay 4-6-0T is already looking a bit battered and at times was limping along in very ungainly fashion. Turned out the were no less than three separate faults! First, noticed a crankpin has come loose off one of the rear drivers, also one of the front drivers had come loose on its axle & gone out of gauge. A built in problem caused by using Gibson 4mm drivers because the right diameter 7mm ones were not available. However the real culprit was part of the brake gear. This had also worked loose and was flapping around behind the frames, catching on the driving wheel spokes. Despite all this the engine did its best to perform, but was looking an increasingly sorry sight, so had to be retired on the Sunday morning with one of the Clogher 0-4-2Ts substituting. Back home, the mechanical issues were easily sorted, but the paint work will need a bit of work before the the next show in October. The 4-6-2T and fish train had different problems as this was in the box that nearly hit the floor. The loco was alright, but both bogie vehicles suffered coupling damage. Managed to get these repaired at the show, but the train kept derailing as it entered the layout from the fiddle yard. Back home, traced this to the cassettes not aligning. Hard to work out why, but various amounts of filing and adjusting have been needed to set everything right. The photos show a rarely seen corner of the layout though, so may be of interest. The Unit & its short goods train [along with Phoenix] were in the same stock box, so also suffered some broken couplings. There are enough spare wagons to cover occasional problems like this, so we got by, but some erratic running towards the end of Sunday afternoon turned out to be rather more crud on the pick ups than I'd expect from an air-conditioned exhibition hall. Maybe I needed to clean the track more often? The last picture is my take on Maggie Coulter's goat - a tale from the Clogher Valley railway, which always causes amusement. The model was hand made by me a few years ago, when I could't find a ready made one. Anyway, such are the slings and arrows of exhibiting and it only goes to show you always need plenty of stock - just in case! Without any coal to hand, what did the driver of the Unit fling at the goat? Your tales of exhibition woe despite the highest quality modelling continue to discourage me from aiming to exhibit anything of mine. I’ll just keep filling the display cabinet at home… 1 1
Colonel Posted August 24 Posted August 24 (edited) I've wondered that too - maybe they just slowed right down and called its bluff? Or maybe, by the time diesel power appeared, the goat was no more? Exhibiting can require a certain masochistic mindset at times, because you just can't predict some of the things that happen. Equally, it is always nice talking to people and you learn as much as you share. At Chatham, the failure of my HH controller came after 20 years of faultless exhibition use. The W was always the spare, but never appreciated it wasn't good enough, so now have two HH, just in case. The biggest problems at shows are dirty wheels and dirty track, for which the only solution is regular cleaning. The semi open nature of the No5 Covered Slip at Chatham, together with its unsealed concrete floor, means you do that two or three times a day. Large school or sports halls are usually much better, with only a general clean first thing each morning required, while smaller/stuffier rooms seem to increase the need again. With rolling stock, it is mainly couplings that need attention. Can't imagine tension locks cause many problems, but the DGs I use, while very effective can be fragile, with the loop coming adrift the main problem. Likewise the AJs on Northport Quay - any misalignment and they don't work. I still occasionally think about going back to three links (never screw links though), but operating from the front it is not fair on the viewing public. You always need spare motive power because a weekend show mean around 15 hours operation and if something goes wrong, it can be difficult to fix on the spot. The other potential big problem is wiring of course. A single dry joint or short can scupper the whole layout and they aren't always easy to find. Only happened to me once, in over 100 shows, but it wasn't funny. Have occasionally thought of converting a couple of locos to battery power, just in case... For some reason, layouts seem to get heavier as we get older (!), but for anyone interested in going public with you layout, would suggest joining up with a club layout to learn about the whole process first. Transporting, setting up etch as other elements that need care and there is always safety in numbers. Edited August 24 by Colonel 4 2
Colonel Posted October 4 Posted October 4 Swillybegs is out next weekend at the Farnham [Aldershot] show. So, much time is being spent trying to get things ready - or as much as they can be, before everything is boxed up, bounced fifty-odd miles and then reassembled for the show. As Alan [Tullygrainy] has previously said, all stock has received a thorough service and been given a good talking to. Likewise track and fiddle yard, in particular the cassettes and all important interfaces with the layout. Thus far [whisper it quietly], all is well - even the DG couplings and I've had a couple of enjoyable sessions at home without any need to address derailments or succumb to fingerpokens. So, not wanting to over cook things, there will be one final track and wheel clean [for the motive power - all rolling stock wheels have been cleaned this afternoon], then all will be boxed up, ready for the weekend. The final jobs will be giving the scenic part of the layout a thorough clean, then check the lighting system and my "sundries' crate, which contains the electrics, tools & other odds & ends vital for any show. After that, it will be a case cross everything, avoid ladders, mirrors etc and hope for an easy weekend. A few pictures below show a couple of changes to the running sequence, with the West Donegal Tram now emerging from the front siding [as originally planned], with CDR railcar 8 going to the main platform. Oh yes - after the controller horrors at Chatham, back in July, I am now packing four of the blighters - two Handheld and two Ws. If I need anymore, the Moderators made need to censor my next post! 15 1
leslie10646 Posted October 4 Posted October 4 Hi David, I had to check when you sent this as I was aware that a show was at FAREham this weekend, which clashed with a Didcot show (don't ask, very poor) and the Madder Valley at Pendon. - see: https://irishrailwaymodeller.com/topic/8988-growlers-at-goring-and-other-freight/page/3/ However, FARNham is much closer and I'll try and be there. I hope that I don't jinx your operations. Good luck with the drive from Chatham through leafy Surrey to Hampshire. 1 minute ago, Galteemore said: Fabulous - sorry I’ll miss it! Poor show, @Galteemore, I'll miss the pleasure of meeting up!
Tullygrainey Posted October 4 Posted October 4 Looking magnificent. Best of luck for the show David. I'll cross my fingers here too. 1
jhb171achill Posted October 4 Posted October 4 (edited) I think exhibitions are gremlin breeding grounds...... but for us mere mortals who go to them to see these spectacular layouts in action, worth it! Edited October 4 by jhb171achill 2
dropshort105 Posted October 5 Posted October 5 7 hours ago, jhb171achill said: I think exhibitions are gremlin breeding grounds...... but for us mere mortals who go to them to see these spectacular layouts in action, worth it! Absolutely, my layout still isn't working right after it's recent outing, and it's all little, not obvious glitches, my poor turntable is knackered. 1
leslie10646 Posted October 10 Posted October 10 Swillybegs was looking great today at Farnham (Aldershot really), even if my presence put the mockers on @Colonel's turntable, which seemed determined to derail everything that went near it! I can confirm that David's wonderful rolling stock looks even better in the flesh. It's variety was a wonder to behold - Swilly, Donegal and especially the Cloger Valley's "Blackwater" which looks magnificent in its red / maroon livery. Thanks, David, for the highly educational "behind the scenes" look. Good luck tomorrow! @Andy Cundick was there as well and I was able to eavesdrop the two great men exchanging War Stories. Andy was "Lochty", his North British Railway layout, but as usual had a display of his locos to be admired, including a Cork and Macroom tank loco - I'd never seen one modelled befoore and very nice it looked too in it's green livery! I'm looking forward to the Basingstoke exhibition in the Spring when both are exhibiting again in my neck of the woods 6 1
Colonel Posted October 11 Posted October 11 Always good to see you Leslie. Swillybegs did pretty well over the weekend, which only goes to show that cleanliness and and proper maintenance is essential. You just can't cut corners. There's a knack to lining up the turntable. Get it wrong and it will bite - and narrow gauge stock can be very difficult to rerail... Anyway, the newly adjusted couplings stood up well and the to do list before Kempton Park in December is fairly short for once! 6 1
