Interesting not-so-early Irish Railway photos
9 hours ago, Mayner said:
Probabably still goes on, I understand that about 30 years ago loco maintenance staff at Inchacore were severely pissed off when bogies from withdrawn 001 Class locos kept as spares were scrapped without consulting maintenance during a scrap drive. Often stopped/withdrawn locos/rolling stock are used as a source of spares, with usable parts removed 'as required" rather than removed and stored.
A tale as old as time. Withdrawn locos that are kept for spare parts are sometimes called “Christmas trees” but I’m not sure how common that expression is.
NCC Jinty No. 18 being delivered to Northern Ireland
J15 No. 130 in use as a stationary boiler
461, then No. 15, in DSER days
  • Like 7
What was the deal with stationary boiler locos? What were they supplying steam to? I assume they were withdrawn locos used in that capacity until they needed major attention and then replaced with another off the scrap line and cut up?
Variety of things - heating, washing, machinery supply. 130 was on railtour duty in June 64 so this is mid to late 60s. The GNR loco 131 was stabled in front of her on similar duties but more intact !
Usually steam heat would have been supplied to buildings.
Sometimes stationary boilers weren't actually stationary; if engines were still capable of moving under their own power then they could supply steam for carriage-warming duties. Couplings would generally be removed so that they would be unable to haul stock.
Sometimes the alterations were dramatic. Here’s a Jinty ex works at Darlington in 1965 ready to serve out its last years as a heating boiler in Manchester
MF 60s steam 19th September 1965 Ex-LMS Jinty 3F 0-6-0T 2022  in Darlington Works.
Cómhlucht Siúicre Eireann Thurles No. 1 (now preserved at Downpatrick) in use as a stationary boiler, April 1963.
CSE was quite a diverse operation, so it's hard to narrow down what the steam is being used for – in addition to refining beet, they made animal feed, lime for fertiliser, and agricultural machinery. In 1957, they bought Ireland's first stored-program computer for making calculations for refining sugar and paying beet farmers across the country
  • Like 7
CSE Carlow No. 3 (Cockerill 3096/1926) seen in 1954, It was withdrawn in 1956. I always wondered why CSE bought vertical boiler Belgian locos, but I recently read that Carlow sugar factory was built under the guidance of a Belgian company so perhaps it was due to their influence. Note that one of the buffers has a curved edge, and the other is flat – standard practice in much of continental Europe to prevent buffers from locking.
Edited by GSWR 90
  • Like 7
One of these, albeit standard gauge rather than Irish standard, was seen on a YouTube video recently, working on a UK preserved line (think it was the Lavender Line at Isfield). Remarkable little machine.
I saw this original slide for sale on eBay and I think I must have had a couple of pints of ale inside me when I paid rather more for it than I had intended. Oops.
Still, it's a lovely photo and shows several items of rolling stock that I would like to model.
The photographer was Ken Cooper and the date was 9th June 1957. The location is obvious from the station nameboard.
655 appears to be arriving with a rake of elderly MGWR 6-wheelers - a lavatory first, lavatory second, and two seconds. Behind them is what looks like a bogie corridor second. The second coach is in plain green without waist line or class digits, whereas the others have the lining and class digits (second class, post-1956, rather than third). The shade of green looks identical though. My impression is that the 6-wheelers are all in light green, but the distant bogie coach may be a darker shade. It's a very sunny day though, which can make even the dark green look bright.
The track is a mixture of bullhead and flatbottom rail, with some points controlled from the box (just visible in the distance) and others with manual levers on the ground.
I have a kit in the stash for this class of loco, with round-top firebox as seen here, and 655 is my preferred prototype. The weathering pattern is quite typical of these locos in later years - the tender almost entirely brown with brake dust while the loco is an oily near-black (I think this was one of the locos actually painted black).
I've also got a couple of MGWR 6-wheelers on order from Alphagraphix, which together with my GSWR 6-wheelers could build up a similar-looking train.
Just visible on the right is an AEC railcar, what a contrast to the 6-wheelers! I'm still hoping that IRM will produce one of these eventually.
  • Like 14
Outstanding picture, yes. I think they are all light green. Very few dark green ones were in use by 1957 anyway (except Cork area!). Yes, 655 is one that was painted black, though that does not necessarily mean the tender is, under that dirt! Most day-to-day trains there at that time were AEC railcar sets, as seen on extreme right, so this will certainly be an excursion of some sort, or else empty stock for one. While only a slight ppossibility, it's possible they are being brought up to lend to the SLNCR for one of their pilgrimage trains. Probably more likely, it's extra stock for a GAA or Knock special/
Edited by jhb171achill
Snap!
Picked this up at a UK exhibition 25-30 years ago. No info on photographer or publisher, photo stamped10157 at rear with hand written Sligo 2-9-52 which appears to have been a Tuesday so GAA or Seaside excursion less-likely, possiby religious or education. In his late 70s/80s IRRS papers on the Ballaghadereen Branch JP O'Dea wrote about 650 Class locos working excursion trains of 6w coaches to & from Sligo on weekends until replaced by AEC railcars.`
666 "Himself"? looks reasonably clean though the tender sides appear to be covered in dirt/muck, there is a 1956 F W Shuttleworth photo of 659 shunting the Night Mail at Sligo similarly loco appears clean while the tender side and frames appears to be covered in brake dust/road dirt.  The latter Atock tenders with the combination of sprong cut-outs and tender sides/flush with the frames were almost designed to throw up road dirt & brake dust & company image/external cleanliness of locos and stock was low priority on CIE.
The 650 Class are supplosed to have regularly worked the Sligo-Mullingar portion of the Night Mail until replaced by diesel during the mid-late 1950s, relatively 'high speed" duty likely to throw up road dirt/brake dust compared to similar locos working branch line mixed train and passenger duties.
  • Like 13
I'm a couple of weeks late for an April Fool, but I quite like these impressions of what a British Rail Metrovick Co-Co might have looked like:
British Railways: Metro-Vick Diesel Locomotive (fiction)
British Rail: Metro-Vick Diesel Locomotive (fiction)
Embedded images linked from Flickr user northernblue109
  • Like 5
  • Agree 1
3 minutes ago, Mol_PMB said:
Satellite cameras not quite so sharp back then!
No! Would have been handy if the CIA saw CIE as of great military interest, perhaps the KGB have a better Photo, I’ll ask uncle Vlad…
Full interactive map is here….sublime the size of Dublin then. Most terminus are under cloud cover besides harcourt street
https://www.spacefromspace.com/declassified-satellite-images/dublin-ireland-19660219-dzb00402500060h003001/
BCDR railmotor No. 2 at Holywood. The locos were cut off and the carriages were used as autotrains. The carriage portion of No. 2 became No. 72 and is preserved at Downpatrick.
  • Like 5
9 minutes ago, Mol_PMB said:
Lovely photo! It seems there were a lot more steam railcars in Ireland than I had realised.
There are perhaps more still around than you'd think!
  • Agree 1
That one would be a challenge to model, given it is not articulated. Guess you'd have to make the coach wheels as a bogie, otherwise it would be very hard to get it to go round curves and even then those floorboards would get in the way.
 Another one not on my Northport Quay list! Shame, as it is a nice little combo.
3 hours ago, Mol_PMB said:
Looking at the photo, I think the coach wheels were a bogie on the real thing.
Yes they would have been a bogey. Would have been a very long wheelbase otherwise
  • Agree 1
  • 4 weeks later...
I have been spending too much money on eBay again, and I only bought this slide for a little detail hidden in the corner.
Here's a photo by Ken Cooper at Glanmire Road shed on 13th June 1955. Colour photos from this era are scarce.
The main subject is 2-6-0 No.369, a Coey design of 1909 built for heavy goods work but also used on passenger trains. This loco was withdrawn in March 1957, but still very much in service here and with a mound of good lump coal in the tender. The smokebox appears to have been freshly painted or at least oiled, so it contrasts with the rest of the loco livery.
But what's that hiding in the corner? It's an AEC railcar, mostly in the shadows but the part in the sunlight clearly shows that it has a green roof. Or at least the edge of the roof is green.
The vagaries of colour reproduction make it difficult to be certain whether this railcar is painted dark green or brilliant green. Most of the AEC fleet would have been about 2-3 years in service by this time, so one would expect them to be in original paint. If it's one of the first four (2600-2603) which entered service a year ahead of the rest, then it may have had a repaint by 1955.
Here's Ernie's photo of a freshly-painted 2602 in 1955, showing off some of the modifications that may have prompted a repaint - the tablet catcher hatch, the new exhaust pipes, the enlarged buffers. It is clearly a lighter colour than the adjacent carriage.
GMK032 CIE 1955-xx Dublin Heuston 2602 D171
In the colour photo it's also hard to be sure whether the roof is entirely green, but only partly cleaned, or if the centre portion of the roof is painted black and just the edges are green:
In that context I'll put this image here; this is from IRRS journal 25 dated 1959:
I'm probably waffling on too long and this ought to be in the thread on green liveries, but it'll give you an idea of the sort of evidence I'm looking at, and trying to make sense of.
  • Like 6
Correct - used for carriage-heating in the cold mornings. All stock still had steam heating till the late 1960s / early 70s.
I was searching for a container image on the Kennelly Archive and stumbled across some photos that hadn't come up in my previous searches.
https://www.kennellyarchive.com/page/18?per_page=50&search=train
Admittedly, when you search for 'train' you get a load of stuff about sports teams, but amongst them are a couple of hundred railway photos.
Silver G602 when brand new, one of several images showing it shunting various wagons:
https://www.kennellyarchive.com/media/e9d3e2ac-e593-47e4-8ad7-9a6e851516be-cie-goods-depot
Nice view of the brake gear under a goods van:
https://www.kennellyarchive.com/media/08ae083f-9c15-4884-9c01-d9997c995f68-train-derailment
I've heard of cattle wagons with roofs, and without, but this is half rice half chips:
https://www.kennellyarchive.com/media/dfce24aa-2fa8-4453-8813-42e10b795dd0-valentia
There are also a good selection of images of weddings where the happy couple set off on their honeymoon by train, and some of these give some useful closeups of carriage details. In each case there are several different views.
Compartment compo 2124 in 1955, with some MGWR 6-wheelers beyond:
https://www.kennellyarchive.com/media/413087e0-3568-42e7-9fd4-39dccbcca2e7-the-train-for-renard
Here's a detail view of compartment second 1352 in 1956:
https://www.kennellyarchive.com/media/d1567468-f269-413d-a492-08833973d8b9-a-wedding
Laminate open second 1433 in 1960:
https://www.kennellyarchive.com/media/2e3527c8-d519-4c30-9e2f-d61042e5d582-the-o-brien-wedding
4 years later and 1433 again, with a coat of paint this time:
https://www.kennellyarchive.com/media/d5936a45-049b-4e95-a56c-3dc0ec27df96-a-photo-of-newlyweds-on-a-train
Closeup of the cab of an AEC railcar in 1960:
https://www.kennellyarchive.com/media/e90330b3-5c8b-4452-9ff7-f3631f263bfd-padraig-kennelly-junior
And an even closer look inside, four years later:
https://www.kennellyarchive.com/media/6dcf8e97-e9bb-4a9e-a890-1a6cb2c41ecf-a-cie-train-driver-in-casement-station-in-tralee
GSWR compartment third 1311 in 1956:
https://www.kennellyarchive.com/media/6d7ff800-8305-41b6-8ba3-a27b138f0884-locke-sheehy-wedding
I think this is a GNR elephant van in Tralee in 1956. It wasn't just pigeons that sent bogie vans far afield!
https://www.kennellyarchive.com/media/c71a26c1-a025-4c38-80dd-b934ae418461-chipperfields-circus
This must be the interior of a special saloon of some sort:
https://www.kennellyarchive.com/media/2f43eee3-704b-4150-9815-ce5f9247ccc3-the-festival-of-kerry-rose-tour
And for the sports team images I kept scrolling past, their training must have paid off because they got to have a train trip too! A useful interior view of a more typical carriage:
https://www.kennellyarchive.com/media/7c862063-3a6e-4512-800f-6ccdccc8e5d3-the-all-ireland-senior-football-semi-final
I even found one of my GSWR gangwayed open thirds in the background of one image:
The Kennelly Archive has much more than railways, but there is a good deal of railway interest within it. Mostly Co. Kerry. It's worth a look.
Saw that archive a while back - excellent stuff. Vast majority non-railway, but quite a few like the above. Shows a lot of detail.
As I'm always telling the young wans, this is back in the times when the railways were INTERESTING, as were INDIVIDUAL trains, as scarcely two vehicles were exactly the same in ANY train.
  • Agree 1
Ireland's most glorious diesel loco, G613 at Heuston, 1962, from the O'Dea Collection.
But what is it pulling? A carriage (no underfloor engine) with a window and lights at the end? Not a Bulleid AEC, not one of the Park Royals converted to driving trailers for the Waterford and Tramore – what is it?
