Timmycork's workbench
Hi lads,
Said I'd post what I was working on, ye may have some advice for me.
Got an airbrush set over Christmas and have just started trying it out.
First off I tarted to smarten up my few buffer stops, resprayed the black and brushed on the red.
Will put red led in at some point, think it improved them anyway.
Great pic, health and safety is right, no hi vis to be seen!!!
Was thinking of leaving it stationary, building an loading/unloading yard for my timber wagons, painting the jib would probably help it look better alright, what is the best thing to weather it with?
The photo is a bit of a shocker although they killed few passengers CIEs employee safety record was nothing to write home about. Apart from the public wandering about the guy that looks like an Inspector and his side kick seem to be standing dangerously close to that wire rope if its under tension, at least the crane is clipped to the rails a practice long outlawed in the UK.
Interestingly one of the figures seems to be wearing a hard hat and another high-vis shoulder panels. Apart from letting Sean Citizen have a wander around th guys p
Ahh, 1974 would make even more sense then. As said H&S pretty much non existant. I thought that cable under tension was a cordon-off rope!! Yet probably the most dangerous bit there.
Why was clipping to the rail outlawed?
At a guess, it might bend rails out of alignment and /or stress rail fastenings if crane moved under load?
Apparently allowed on the Continent probably ok for lifting along the centre line of the crane, but don't attempt to slew unless the outriggers are fully extended otherwise http://www.youtube.com/watch?v=cz22Wty5Rks.
If it clipped I would imagine a steam railway crane would take the track panel with it if it overturned. It doesn't take much in the way of lad to overturn, usually an outrigger that's not fully extended or blocked.
Timmy, shes beautiful! whats the story with the wheels?
Thanks, looking forward to showing my friend who gave it to me,
I have the original wheels, like I said I had intended having it stationary for a loading/unloading siding, after seeing glenderg's pic it's hard not to want to recreate the scene!!! Think the wheels will be put back on!!!
go on and do it ya good thing!!!:)
Got another bit done last night, beginning to look a bit better now. Heirflick will be glad to see it on wheels again!
All I'm waiting for now is westy's pm about sponsoring a set of decals
Superb Timmy, but you gotta play the ol "rebel county" card if you're gonna get anywhere with sponsorship, methinks!
What's the background to the model? Triang or something? R
  • 8 months later...
[ATTACH=CONFIG]12149[/ATTACH]
lovely job of weathering on her timmy - well done
Have found up the second wagon of that crane set so when I get an airbrush will have to try and finish it up.
The an post decals look the part alright, will give it a go!!
  • 7 months later...
