Thirty days has September, April, June and November, all the rest ....... (was that the triple flat pack or did I miss something)
I'd be much more interested in buses from the 60s. Recently, I ordered a triple pack of 42 flats and a weedsprayer (again for the differently numbered flats). Unfortunately when I did so the DCC chip in my unit seems to have malfunctioned, made a misinterpretion 'Link Buses 2 Rail', overrode my comments 2 posts ago, and RV517 and RV520 were loaded into my cart . OK, but that's definitely the last time for now ....
No, you're right the track centers would be the same but the distance travelled to traverse a turnout would indeed be longer and the tightest curves would have to be second, maybe third, radius although I'm thinking of using flexitrack so that I can have smoother transitions at entrance and exit to curves so that the rolling stock is not thrown suddenly from straight to full on curve which is not prototypical in the least
A lot of pennies will have to be saved, David, that's for sure. So far I only have the RPSI B134. The running is very impressive the only thing lacking is not the model itself but the track it is running in on. I'll have to wait a month or two as i made the mistake of ordering different liveries together but I'm happy just running B134 for now. I have been contemplating a new layout for some time and luckily have some room to do it in. I have been procrastinating about 21mm for sometime but with some space but a relative lack of time (and skill) I don't want to spend my entire time just building the track alone (prefer some additional buildings etc) so unlike you I prefer rtr if possible. Kinda like models being 21mm compatible I'm now contemplating designing the trackbed in 21mm and laying Peco 75 on top on the off chance that a 21mm rtr track ever becomes available or I entirely lose my mind and try to build improved track. The track centers wouldn't change and curves would need to be 21mm compatible. I have a few bits of older stock but nothing pre 2000s, and a steam loco or two already gauged to 21mm to start me off. Luckily converting the newer models should be a little easier than in previous decades
Are they actually brown on the inside? They seem very uniformly weathered!
Incidentally, why did the fertilizer come undecorated in the end. I though there was a CAD design with NET on it iirc?
There are several different tank wagons in this tread. Which Dublo tanks are you referring to? is there a link photo? The weed spray train provide you with a 42 flat triple pack and 5 tanks that need a chassis, maybe a Dapol which they could be mounted on but depends what you're trying to model
I think this highlights the need for a few extra lugs to become available at some point although we don't have 10' containers yet. The third container belongs to Ceimicà Teoranta a semi-state company involved in production of natural sweeteners e.g. Glucose bottom of the signage, like Comhlucht Siúicre Éireann Teoranta. Obviously beet and sugar had a much larger market share. I'd wager the last container is a reefer or insulated as alluded to above. Some seen here in this thread few 2013, maybe at Cork Yard but not 100% on that
Just to add that I did not realize that the Shale wagons also started life in blue. I saw a photo somewhere (maybe IRRS site) so no point in posting a link really. So that's Taras, containers and shales, not to mention the dropside and curtain side cements
I actually put 2 packs in my basket, then rethought it, and exchanged one for a weed spray set. No need to bother renumbering, I can display it occasionally if the flats have no other use than to be in the display, or repurpose the tanks and container unless we see some on a short chassis, Just a thought
Even though my preferred modeling era for Irish outline is 50-80s, I have always had an interest in modern high volume (civilian) aircraft and high speed train transport. Sadly that is never going to existing in Ireland even between centre with doubled line. Watched the episode on the Shinkansen 700S and began to wonder if I should have one of these to go with my APT-E...... oh, the temptation. Really enjoyed that. Thanks @skinner75and @snapperfor the link
Surprised that someone is fed up of it already It's a model store in Manchester that has an online eBay store. You'd have to be buying these as trade rather than retail to turn a profit by the time you're done on eBay
To be fair, other than a few discussion posts all of the DCC, CV tuning, lighting, sound, operational aspects etc is all very relevant unless it need to go on a separate thread in the DCC section (with a link here so that relevant content can be linked back to the 121)
With the announcement that Project 42 has now completed does this mean that the original blue Taras has been shelved? I didn't get any of the later ones and still have that original promo code from the ballasts to use.
Are you talking about B134? The modern LEDS on the 121s and 141 etc would have used diodes above 3000K color, maybe a lot more. The older 121s (121, 135 and many more) should have the yellower hue 2700Kelvin like an incandescent (as that's what they were I believe)
Haven't seen a 10' in blue/grey? before still with CIEU owner markings. Must be matching the odd blue color being used by CIE on many stations during the 80s or the Blue Taras!
SO when I stick in a MM DCC non-sound chip (just to simplify things). I cannot use the standard F functions on my ESU to control marker lights and headlights Like I do on a 071 for example? The solution is that I have to do some remapping of functions, I presume. So, can I do that using my ESU DCC control unit alone? Do I need to have an Lokprogrammer in addition to my control unit or that just makes it simpler to do?
So the marker lights/headlights are not independent with the MM standard DCC or DCC sound chip without a Lokprogrammer?
Yes, a 30' would look odd on a 42' flat. Nothing wrong with that. Variety is the spice. I don't know if the lugs on an IRM 42' flat would be appropriately placed to accept a 30' container centred to minimize the axle loading (some of them may be removable and might be repositioned, I'd have to look at mine)
Never liked the bombardiers per se (especially in green) but this is a lovely model in the CIE tours livery.
OOOOh! Class! (E) Love it! These were classics. If it ever comes rtr, YES (many of them)
IRM and Factory Weathering / Weathered Stock
DiveController replied to DJ Dangerous's topic in Irish Models
Many thanks for that link, Fran. I like your last idea best of all insofar as I feel that someone who models Irish outline might do the best job. Would it create some export problems for IRM sending to a EU address prior to definitive export? Maybe I'll chat or email you guys -
It's not just a matter of choosing someone to weather for the members who live overseas in continental Europe, USA, etc. There are the additional difficulties of 're-importing' the model even though it's for 're-export' later plus 2 sets of postage and there's always the risk of damage/loss in transit. As well packed as B134 is it still arrive missing all the side rails. Easy enough to fit everything back with a tweezers. I got ten of the 20' CIE accessory containers and had to reassemble 7 as the packaging had slid apart (again easy to do) I'm kinda nervous about sending models through the variety of carriers that seem to seem to treat the contents as Lotto balls that need a good shakeup so it's anyones guess what will come out! -
Well Murphy Models is the commonest search bait term on eBay for many years now. Rumor was that that PM wished to retire after the 121s but if he's considering rolling stock to go with the 121s I won't complain though
