DiveController
  1. Something old and grey, I hope Looks very good even without the final touches, John @Mayner Definitely a gap filled
  2. I'd say that is a trick of the light or they're in undercoat on a trial as they were turned out in '64 If you look at this B&W and put a sheet of paper over the lower part of the tanks you can convince yourself they're in ivory too Sorry Noel, I started to watch the video , then posted, then read your post later but yes we're thinking along the same lines about the turntable here (if someone can verify, please)
  3. OMG! The turntable at Amiens street was vacuum operated? The vacuum line of the engine is hooked up to what seems to be the turntable and no sign of any manual labor happening that I can see. Did I get that right?
  4. Felt like it, really with no real health issues, this was very unexpected. Thanks! Thanks, Mark! In a way I'm surprised about 121 selling out so quickly unless fewer models were produced
  5. Oh well that's a shame. There's no real stock warning on preorders, I suppose. 124 & 134 are not really my era but would have liked to get one of each. Maybe Marks. Haven't been on here in a couple of weeks. I'm just happy to be alive after a recent health issue so I'll live with it in the literal sense
  6. They just look so much better on the correct gauge track! Some lovely layouts there
  7. All the same, it apparently did about 300,000 miles on the CVR and was still going strong when the line closed in 1941/2
  8. Jayzus, that cannot be cheap! Thank Christ he is and good luck. EDIT: So I guess he is James Deegan per the GoFundMe site. I decided to give up one IRM wagon set and rounded that up to a donation plus a little for GFM. Less than 5,000 Euro (68 donations) raised though from the 300,000 goal after several months. Wondering if this is just another railway preservation doomed to failure due to lack of public support.
  9. I haven't seen/noticed this before but then I may not have seen early close-ups of the cabsides. Maybe this was a requirement for US manufactured locomotives that had to be on the loco prior to export? Did it run with this in the grey & yellow livery , at least until the filler pipes fell off? Actually it won't technically go with anything but modern DMUs etc and other preserved liveries such as MM 0141A. I'm presuming for a start that it will retain the modern LED marker light clusters. Will it have any RPSI markings? 2 Foot rule, yes you could run them together but then they rarely if ever ran in consist in this livery, nor in BnT I'm not knocking the model, I've ordered one.
  10. Ah! That's why it's not in the News section. I'm sure there must have been similar excitement to yours in CIE about 1955. But it won't be long now for the model As, I'm sure. Looking forward to some silver, grey and black myself!
  11. That's amazing. Great to see things progressing so rapidly. How is all of this being funded? Well done!
  12. I believe they were still referred to as No1 & No. 2 (no jokes please), not sure if forward etc make that much sense in a double cabbed loco, although I often have problems remembering which is which tbh
  13. I think the Kibri stuff is HO but its hard to appreciate the proper size of trackside machinery so they usually fit in pretty well
  14. I believe the buffers at at 3'6" so looks to be 3'
  15. Looking very well, John!
  16. Quite correct, by comparison the Mk3s with their corrugated roofs can withstand 300T compression forces. I remember this accident as a child. And yes, Cherryville happened again before the wooden bodied stock was finally withdrawn. The wooden bodied stock was fine for its day but not designed for high speed mainline travel like the MK3s
  17. Repainted 141 surely Preserved 141 in consist with 142, modern LED light clusters (4) B141 at Fermoy 1963, original lights (3) and a preserved steam loco (90)
  18. Haha! the first response completed my thought process
  19. https://www.rte.ie/archives/2015/0730/718273-buttevant-train-crash/ About 12:45 the 10:00 am Dublin (Heuston)to Cork (Kent station) express train entered Buttevant Railway Station carrying some 230 bank holiday passengers. The train was diverted off the main down line across a set of 1:8 temporary facing points into a siding. Although the locomotive remained upright in the siding, the older wooden framed carriages immediately behind the engine and generator van jack-knifed across the lines, with the two coaches and the dining car disintegrating under the enormous compression forces of the 60 mph crash. Two coaches and the dining car were totally demolished by the impact. Most of the Cravens coaches remained intact at the rear. Eighteen Irish, British, Austrian and American passengers died and more than 70 people were injured.
  20. Beauparc, 2018 Tara Ore Rake with the 2 converts
  21. New A class A33 at Salford Docks in Manchester about be shipped to CIE and looking somewhat odd with its temporary undersize standard gauge bogies
  22. A unique coach insofar as 11 first/third composites were built by the GS&WR c.1906 initially designed to be a brake tri-composite. You can see the that the first two compartment were designed as firsts with 6/compartment and the two following designed as seconds, but I don't believe they ran that they ran that way with the GSWR abolishing 2nd class c. 1906. It definitely ran as a 2F 5T Brake. Only 861, 862, 863 were clerestory brakes and ran on 6 wheel bogies. The 11 coaches would make a lovely model series actually, since 861/4848A is also in preservation with the RPSI
  23. They're really beginning to look good now, John! I'm in for a pair maybe more when a price point is available. Will they be decorated or just printed? Same question re conversion to 21mm? Thanks, K
