Darius’ Workbench
On 27/10/2021 at 6:38 PM, Darius43 said:
…and painted.  It’s a green “Brown Van”.
Painted UTA green - not sure if this is prototypically correct but it makes a change from brown “Brown Vans”.
it will get browner after a spot of weathering.
Cheers
Darius
Darius, as Galteemore says, your output is remark - not just quantity, but QUALITY! Apologies for not commenting earlier.
Loved the green Brown Van, as Jim says a rarely photographed van - the one photo of one I have in my "background" files belongs to someone else, so I can't reproduce it here. I'll look in other files.
You can one "in the flesh" at the Whitehead Museum in the maroon form.
Still got a good supply of the kits upstairs!
Darius - I may have missed them, but how did you get on with your rake of Spoil Wagons?
Hi Leslie,
I have built two of them so far.  I came across the box with the spoil wagon kits when I found the two MIR fertiliser wagon kits.  I had better get back to finishing them - plus an unfinished Watford DC EMU - plus an unfinished LMS Clerestory Coach - plus another Brown Van in NIR maroon - plus…
Cheers
Darius
  • Funny 1
Received this morning - Niu Models LNER Ammunition Wagon kit.  3D printed and a joy to build.
Built to accompany Oxford Rail’s Gladiator rail gun.
Cheers
Darius
On 26/10/2021 at 12:30 PM, Darius43 said:
I have had this Irish Freight Models anhydrous ammonia tanker on the shelf for quite a few years after obtaining it in completed condition from the Bay of e.
Over time the decals started to peel and it looked in a very sorry state.
Today I decided to improve things so the remaining decals were scrubbed off and extra undergibbon parts were added using brass rod and plasticard.
The tank and chassis have now been repainted.
The original handwheels have been removed and will be replaced with etched examples.
The lines on the tank were drawn on using a 2H pencil and a guide made from three layers of Tamiya masking tape.
A new decal sheet has been obtained from MIR - still available on eBay.
Cheers
Darius
Wow.
Just wow.
What extra underbody detailing did you add, and on what bogies does it sit?
Hi DJ,
The bogies are the original IFM resin bogies supplied with the model.
I added brass rods and actuator arms to the vacuum brake cylinders that were already moulded as part of the wagon chassis.
Cheers
Darius
54 minutes ago, Galteemore said:
Is it an Eastern Region brake tender ? V nice work
It is indeed.  Inspired by an article in the latest Hornby mag.  The article used 3D printed body but I thought it’s flat-sidedness would make it relatively easy to make from plasticard.
Cheers
Darius
Thought it was - the small hole in the side to access the sandbox filler is the give away - or, like a Midland Jinty, is it really where the key to the clockwork motor goes? 😁😁😁
Nice bit of scratchbuilding too!
Edited by David Holman
Found in the same old shoebox as the 1973 tube driving coach.  Scratch built body on a metal Triang wagon chassis.
I think a friend and I bought a few of these chassis for peanuts at Beatties in Bristol Broadmead in 1985.
Cheers
Darius
Edited by Darius43
Cheers
Darius
Possibly an ERG (Bournemouth) wagon. Clear Plastic (acetate?) body on die-cast chassis  https://www.binnsroad.co.uk/railways/erg/index.html
ERG was a component an kit supplier/manufacturer,  introducing plastic Rex kits in the 50s/60s,  the owner appears to have retired/gone out of business in the early 1970s, may have sold the stock to Beatties and other retailers.
The model shop in Monk Place Phibsboro stocked the kits, I remember looking at an open wagon with a clear plastic body and a metal chassis but it was beyond my budget at the time.
Actually I know that the body is scratch built as I scratch built it myself from plasticard sheet with paper and cardboard bracing and stiffeners when at University in Bristol.
Interesting to know about ERG.
Cheers
Darius
Buffers fitted and decals applied to the brake tender.
The Fox Decals carrier film is applied around each “word” in each decal set rather than as a block, which makes them prone to distorting and “folding under” on application.
Fortunately the film is quite strong so the errant decals can be recovered and re-applied with care.  I have since sprayed the decal sheet with a coat of acrylic varnish to avoid a repeat of these issues on future brake tenders.
Weathering will be next after I have built another brake tender.
Cheers
Darius
Edited by Darius43
24 minutes ago, jhb171achill said:
Love those London Underground models! Hand-built?
In the case of the 1973 Piccadilly Line driving car, yes, back in 1987 - in a one room bedsit from plasticard and balsa wood.  I remember I had a couple of needle files and a Stanley knife as a toolset.  No decals - the LU roundels were hand painted.
The red 1938 tube train is more recent - RTR from EFE Rail.
Cheers
Darius
Edited by Darius43
