murrayec Posted December 1, 2015 Posted December 1, 2015 Hi David I know what you mean- while cutting some plastic recently, doing the stupid thing of pulling the knife towards me- I said 'what are you doing!' then promptly stabbed myself in the leg!! Parkside Spares, Instructions & Consumables;- JM this is for you;- http://www.kompernass.com/index.php?route=common/home Eoin Quote
Broithe Posted December 1, 2015 Posted December 1, 2015 The instructions for McCulloch chainsaws used to contain the warning - Chainsaw accidents are rarely trivial. Quote
Broithe Posted December 5, 2015 Posted December 5, 2015 [ATTACH=CONFIG]21447[/ATTACH] I picked up the last one in my local Lidl a couple of days ago - civilised enough for light domestic use. I might be tempted to make a flip cover for the spindle-lock button on the top. Quote
Glenderg Posted December 6, 2015 Posted December 6, 2015 I picked up the last one in my local Lidl a couple of days ago - civilised enough for light domestic use. I might be tempted to make a flip cover for the spindle-lock button on the top. [ATTACH=CONFIG]21586[/ATTACH] Finally proof that at least a physical workbench exists, and what looks like a high end bottle opener attached. Perfect setup... Quote
Broithe Posted December 6, 2015 Posted December 6, 2015 Finally proof that at least a physical workbench exists, and what looks like a high end bottle opener attached. Perfect setup... Quote
WRENNEIRE Posted December 6, 2015 Posted December 6, 2015 I actually thought the heading here was useless tools and I was going to post some pics of the mods on here........... But back to reality Some handy bits down in the MRSI Quote
murrayec Posted December 7, 2015 Posted December 7, 2015 [ATTACH=CONFIG]21586[/ATTACH] Hi Broithe Mods already, I'm impressed... Eoin Quote
Junctionmad Posted December 7, 2015 Posted December 7, 2015 I picked up the last one in my local Lidl a couple of days ago - civilised enough for light domestic use. I might be tempted to make a flip cover for the spindle-lock button on the top. [ATTACH=CONFIG]21586[/ATTACH] looks like a ww3 " start " button cover to me, you could have it marked " self destruct" on a control panel!!!! Quote
murrayec Posted February 24, 2016 Posted February 24, 2016 (edited) Hi All Here are a few shots of a sanding jig for the belt sander, made from mdf with fence plate to slide n guide the work into the sanding belt. The plate is removable so different types can be installed..... ....and in operation on a bit of DART stuff Eoin Edited February 24, 2016 by murrayec Quote
Mike 84C Posted February 25, 2016 Posted February 25, 2016 Get friendly with your dentist, those little burrs he attacks your teeth with are very useful. I like the serrated ball shaped ones and the ones that are like milling cutters. They should fit your Dremel and a hand full have lasted me for years. Quote
Broithe Posted February 25, 2016 Posted February 25, 2016 Get friendly with your dentist, those little burrs he attacks your teeth with are very useful. I like the serrated ball shaped ones and the ones that are like milling cutters. They should fit your Dremel and a hand full have lasted me for years. Still on a dental theme, the vibratory toothbrushes can be quite handy for cleaning your intricate parts. The handles that take AA cells are much better than the rechargeable handles, I find - and, of course, you can use rechargeable cells in them anyway. Quote
jhb171achill Posted February 25, 2016 Posted February 25, 2016 Still on a dental theme, the vibratory toothbrushes can be quite handy for cleaning your intricate parts. [ATTACH=CONFIG]22940[/ATTACH] Sounds painful. Really painful..... Quote
jhb171achill Posted February 25, 2016 Posted February 25, 2016 I actually thought the heading here was useless tools and I was going to postsome pics of the mods on here........... =))=)) Quote
Broithe Posted February 25, 2016 Posted February 25, 2016 Sounds painful. Really painful..... Enough to set your teeth on edge...... Quote
Broithe Posted March 5, 2016 Posted March 5, 2016 For a good while, I've been meaning to get a small cutting mat for the travelling toolbox. Today I saw this for £5 and decided to bite the bullet - the knife is actually surprisingly good, too, with ten spare resharpenable blades, also. The fitted blade is spring-retractable by means of a "squeeze-clip" and there's a guard to prevent accidental activation. The cutting mat is a good bit thicker than the usual variety - 200 x 130 mm. Useful, if you're on the move - or pushed for space. Quote
murrayec Posted March 10, 2016 Posted March 10, 2016 (edited) Hey Broithe Here is a simple mod for your small cutting mat;- The mat is mounted on a off-cut of MDF leaving an edge all round, a steel ruler is stuck down on the top edge of the mat, flush with the top edge of the mat to give a straight edge. Engineers square runs along the ruler straight edge to give a 90deg cut. This is a clamping arrangement for an end stop for cutting several items to the exact same length. End stop set-up for use in cutting steel bar to length. There is a grove cut in the mat to hold the bar in place while the end is filed square. Set-up for angle cutting, the protractor runs along the ruler straight edge. I use this for cutting all materials- metal n plastic, and some times use it as a guide to set-up model parts to hold and glue- using the square and other bits of metal to hold. One of the most used items in the workshop Eoin Edited March 10, 2016 by murrayec Quote
The Derry Road Posted March 10, 2016 Posted March 10, 2016 Eoin, a question if you don't mind. What have you used as anchors for the thumb screw, inserted into the MDF. TDR Quote
murrayec Posted March 11, 2016 Posted March 11, 2016 Hi TDR It's a M4 threaded insert- drill a hole bigger than the insert and screw it in with a hex key.... M6 and M8 are easy to get here but the smaller ones I get from modelfixings Eoin 1 Quote
The Derry Road Posted March 11, 2016 Posted March 11, 2016 Hi TDR It's a M4 threaded insert- drill a hole bigger than the insert and screw it in with a hex key.... [ATTACH=CONFIG]23205[/ATTACH] M6 and M8 are easy to get here but the smaller ones I get from modelfixings Eoin Many thanks for the answer Eoin. Quote
murrayec Posted March 25, 2016 Posted March 25, 2016 (edited) Another useful tool I've been sticking together for a while and finally got to test it on a bit of 'Scot Stuff' see sample in my Workbench. The airbrush blast gun is from Expo Tools, it works quite well but the grit reservoir needs to be twice the size. The cabinet is a medical display case from a friend and Woodies best chemical gloves from the gardening section. I gave my white metal 121 parts a blast and it worked an absolute treat, far easier than trying to do it in the full size blast cabinet with a nozzle for blasting an ocean liner! the little air brush still uses 60psi but the blast is tiny. The lid of the cabinet still needs to be finished, it needs to be set at an angle as the glare from the workshop lights reflected off the lid make it hard to see in. Eoin Edited March 25, 2016 by murrayec Quote
Junctionmad Posted March 27, 2016 Posted March 27, 2016 nice unit. I have the same grit blaster and need to make a sand blast cabinet . I was thinking of MDF and a perspex top ? Quote
Broithe Posted March 27, 2016 Posted March 27, 2016 The lid of the cabinet still needs to be finished, it needs to be set at an angle as the glare from the workshop lights reflected off the lid make it hard to see in. Could you avoid that issue with LED strips around the lid, shining down into the cabinet? Quote
murrayec Posted March 29, 2016 Posted March 29, 2016 Yes Broithe .....that's the plan- to install lights after I raise the back of the lid a bit, headroom is a bit tight with the reservoir on the gun banging into it, when the back of the lid is raised this should not happen. Eoin Quote
murrayec Posted April 12, 2016 Posted April 12, 2016 A little project for Sunday afternoon, getting ready to grass the Greystones layout- Static Grass Applicator a la 'Boulder Creek' Youtube video. Cost about €40.00 in bits and some items I already had;- Very simple to put together, all parts easily available Eoin Quote
murrayec Posted July 5, 2016 Posted July 5, 2016 Hi Here is a very useful tool if doing a lot of fine gluing using a syringe. Standard syringes can be very hurtful on the hands if a viscus glue is being used and after applying the glue to a DART body print with a standard syringe I can do nothing else for several hours! This unit is really comfortable to use, one can place the glue accurately with one hand and no strain. The unit comes with 30 clear barrels, pistons, end caps (if using different glues the barrel end can be sealed), and a range of tips. Its from adhesivedispensers.co.uk and cost £67.00 including postage. If doing a lot of fine gluing you got to get one Eoin Quote
burnthebox Posted July 5, 2016 Posted July 5, 2016 " if a viscus glue is being used and after applying the glue to a DART body print with a standard syringe I can do nothing else for several hours!" Eoin, your not supposed to lick it. !!!!!! Quote
Broithe Posted July 5, 2016 Posted July 5, 2016 That does look like an exhibit from the trial of a serial killer. Quote
murrayec Posted July 5, 2016 Posted July 5, 2016 (edited) I thought of a Sci-Fi film prop- 'Model 7698-B Master Blaster' or do you remember the RTE adds long ago - 'Stamp out sarcoptic-mange-mites and Liver Fluke'!!!! Thanks btb- I was wondering what I was doing wrong when my tongue was turning DART green! Eoin Edited July 5, 2016 by murrayec For Broithe and my mind Quote
Broithe Posted July 5, 2016 Posted July 5, 2016 I thought of a SF film prop- 'Model 7698-B Master Blaster' or do you remember the RTE adds long ago - 'Stamp out sarcoptic-mange-mites and Liver Fluke'!!!! Thanks btb- I was wondering what I was doing wrong when my tongue was turning DART green! Eoin I prefer the term Sci-Fi, I thought you could be straying into political territory there... Quote
Weshty Posted July 5, 2016 Posted July 5, 2016 There's really no other word for it but "fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu........." Super piece of gear. Ergonomics at its most practical. Quote
murrayec Posted July 5, 2016 Posted July 5, 2016 Hi Glenderg I'm using Stixall clear by Everbuild and I get it in Wurths in Ballymount- it's like Tek7 but stronger and cleans off the DART glazing far easier than Tek7 Eoin Quote
DiveController Posted July 5, 2016 Posted July 5, 2016 or do you remember the RTE adds long ago - 'Stamp out sarcoptic-mange-mites and Liver Fluke'!!!! =))=))Oh Lord! It just came flooding back!! Personally I thought it looked like the plastic gun from "In the Line of Fire" but those poor cattle, either way lmao:ROFL: Quote
