burnthebox Posted November 11, 2014 Posted November 11, 2014 Hi all, anyone got any ideas as to what length of track is necessary for a gradient up to the next level, that loco's, steam & diesel can climb with ease ! thanks in advance.
0 Broithe Posted November 11, 2014 Posted November 11, 2014 Bit of chat recently - here - http://irishrailwaymodeller.com/showthread.php/2843-gradients?highlight=gradient ...
0 burnthebox Posted November 11, 2014 Author Posted November 11, 2014 Hi Broithe & thanks, to be more specific, would a straight 8ft length of track be enough to facilitate an 0-4-0 steam, or diesel up that gradient,
0 BosKonay Posted November 11, 2014 Posted November 11, 2014 In practice not unless you were planning 2 or 3 coaches only. From testing I did a few years back only heavy modern diesels could manage 4% gradients. Go with 2% if you want most things to manage it will decent length trains. 2% means that you will climb 2 inches every 100 inches or eight feet will clear about a two inch climb. So you'd need a 16 foot climb to get 4 inches off the baseboard.
0 Dave Posted November 11, 2014 Posted November 11, 2014 An 0-4-0 steam would struggle to pull itself up an incline, as Bosko says 2% as a maximum. If the climb is higher you would need a helix.
0 DiveController Posted November 11, 2014 Posted November 11, 2014 In practice not unless you were planning 2 or 3 coaches only. From testing I did a few years back only heavy modern diesels could manage 4% gradients. Go with 2% if you want most things to manage it will decent length trains. 2% means that you will climb 2 inches every 100 inches or eight feet will clear about a two inch climb. So you'd need a 16 foot climb to get 4 inches off the baseboard. Yup. Dave got in there before me. If you have space for a loop in the layout or a helix, that will keep your gradient lower. Alternatively, If you can drop the thing you wish to climb over, you can effectively half the gradient/length you need to climb (one climbs 2 inches, one drops two inches= 4 inches clearance)
0 Broithe Posted November 11, 2014 Posted November 11, 2014 A straight gradient can be a small touch steeper than a curved one - it's a matter of making the best use of the space you have in terms of the relationships of straight to curved sections. I got away with lifting two and a half inches on an eight-foot long straight gradient with a double-bend entry to it. Trains would noticeably pick up a bit as the last wagons/carriages came off the (flat) bend and onto the slope.
0 burnthebox Posted November 11, 2014 Author Posted November 11, 2014 What exactly do's this do, is it connected to track, or loco's http://www.gaugemaster.com/item_details.asp?code=DCDCX-PBVP
0 Dave Posted November 11, 2014 Posted November 11, 2014 What exactly do's this do, is it connected to track, or loco's http://www.gaugemaster.com/item_details.asp?code=DCDCX-PBVP That's the Powerbase system from DCC Concepts, its a series of metal plates you fit under the track, magnets are then fitted into the locos. The magnets give much better traction for the loco to climb. They work very well. Here's a video on them
0 Dave Posted November 11, 2014 Posted November 11, 2014 How to fit the system[video=youtube;Sxiip-QdEE0]
0 Broithe Posted November 11, 2014 Posted November 11, 2014 What exactly do's this do, is it connected to track, or loco's http://www.gaugemaster.com/item_details.asp?code=DCDCX-PBVP Basically, it increases the downforce from the loco to the track, without increasing its weight. Wheel-slip is the main mode of failure on a slope, rather than lack of power and this will raise the point at which slip occurs - allowing a steeper slope and/or longer trains... Back in the old days of steel track, there was the Magnaforce system, which had a similar, though much less significant, effect.
0 burnthebox Posted November 11, 2014 Author Posted November 11, 2014 Would adding weight to loco's not do the trick,
0 Broithe Posted November 11, 2014 Posted November 11, 2014 Would adding weight to loco's not do the trick, It can help, up to a point - but extra weight is weight that you also have to drag up the slope - the beauty of the magnetic system is that you get extra download without the extra mass in the train as well..
0 Liverbird81 Posted November 12, 2014 Posted November 12, 2014 So what % would a gradient be if you were wanting to incorporate York rd climb to Yorkgate station ???
0 burnthebox Posted November 12, 2014 Author Posted November 12, 2014 Thanks guys, that DCC Concepts look's the business, having said that I was looking at Marks Models display in Raheny & they had a loco, think a 141 going up a short gradient with not too no much of a problem,
0 BosKonay Posted November 12, 2014 Posted November 12, 2014 The 141 is one of the best pullers out there, ironically much better able that the newer 201s!
0 Broithe Posted November 12, 2014 Posted November 12, 2014 The 141 is one of the best pullers out there, ironically much better able that the newer 201s! Of course, a 181 would have slightly more tractive effort available.......
0 BosKonay Posted November 12, 2014 Posted November 12, 2014 Of course, a 181 would have slightly more tractive effort available.......
0 burnthebox Posted November 12, 2014 Author Posted November 12, 2014 So, it's the Tractive Power, not the Pulling Power !! & 141's have it in spades !!!
0 Mike 84C Posted November 12, 2014 Posted November 12, 2014 I have the magnetic system from DCC Concepts and it seems to work well on my steam locos. No diesels on my railway yet!
0 Broithe Posted November 12, 2014 Posted November 12, 2014 I've just been round to where I made some ramps from a single sheet of hardboard - so, they are exactly eight feet long - and the rise is actually three and a quarter inches - more than I remembered. They were made to lift the track to go over a Hornby suspension bridge. We had no real problems with things going up there - certainly not with Murphy traction.
0 burnthebox Posted December 3, 2014 Author Posted December 3, 2014 I've just been round to where I made some ramps from a single sheet of hardboard - so, they are exactly eight feet long - and the rise is actually three and a quarter inches - more than I remembered. They were made to lift the track to go over a Hornby suspension bridge. We had no real problems with things going up there - certainly not with Murphy traction. Hi Broithe, only seeming your post now, anyway have you tried a steam loco go up that 8ft length & what type of loco, 0-4-0, 0-6-0 or something else, & was it pulling anything,
0 Broithe Posted December 3, 2014 Posted December 3, 2014 Hi Broithe, only seeming your post now, anyway have you tried a steam loco go up that 8ft length & what type of loco, 0-4-0, 0-6-0 or something else, & was it pulling anything, We mostly ran all-wheel-drive diesels - mostly my Murphy's - but, we also ran a tender-drive Flying Scotsman, with four coaches, including a post-office pick-up-and-drop coach - no trouble. The only thing that gave any real trouble was a seven car Pendelino, and that seemed to struggle mostly because of the double bend before the slope started - if it was all on the slope , it seemed to just manage. It tend to derail, actually, as the traction tyres were only on one side. It's a simple enough issue to do some testing with a few planks before you commit yourself. Better safe than sorry Do beware of tight bends an or near the slope, though. They do add to the rolling resistance. We did run various old engine drive steamers, mostly six-coupled, never had any real issues with them, often pulling quite fair trains. Do have the lowest slope you can get away with and try it experimentally first - that's the best advice I can give. Some of the older engines required a small power increase to get up, and a bit of a turn-down after they had 'summitted', to avoid them 'running away' - Murphies and other more 'modern' types didn't really have much of an issue of that sort. All being run through Gaugemaster DC controllers. You can see the journey over the ramps with a 141 pulling three coaches here - longer trains weren't much of an issue. The ramps are at the back, immediately after the start - either side of the suspension bridge.
0 burnthebox Posted December 3, 2014 Author Posted December 3, 2014 Absolutely gobsmacking, I got lost just watching trains run on that totally mega layout of yours, but yes I did see the murphys go up the gradient with we, I for one didn't see any problems with it, I'll have about 9/10 ft of a run (when I get my layout) to use for the gradiient, which I feel should be enough, many thanks,
0 Noel Posted January 27, 2015 Posted January 27, 2015 (edited) We mostly ran all-wheel-drive diesels - mostly my Murphy's - but, we also ran a tender-drive Flying Scotsman, with four coaches, including a post-office pick-up-and-drop coach - no trouble. The only thing that gave any real trouble was a seven car Pendelino, and that seemed to struggle mostly because of the double bend before the slope started - if it was all on the slope , it seemed to just manage. It tend to derail, actually, as the traction tyres were only on one side. It's a simple enough issue to do some testing with a few planks before you commit yourself. Better safe than sorry Do beware of tight bends an or near the slope, though. They do add to the rolling resistance. We did run various old engine drive steamers, mostly six-coupled, never had any real issues with them, often pulling quite fair trains. Do have the lowest slope you can get away with and try it experimentally first - that's the best advice I can give. Some of the older engines required a small power increase to get up, and a bit of a turn-down after they had 'summitted', to avoid them 'running away' - Murphies and other more 'modern' types didn't really have much of an issue of that sort. All being run through Gaugemaster DC controllers. You can see the journey over the ramps with a 141 pulling three coaches here - longer trains weren't much of an issue. The ramps are at the back, immediately after the start - either side of the suspension bridge. Wow how did I miss this. Only just spotted this layout video now after reading of Kirleys gradient wheel slip. Another wonderful layout that looks incredible fun to operate. I like the long runs and industrial feel. An amazing layout. The connection to the other room is really clever. Looks like you could almost operate as two separate layouts or one long one as per the video. Edited January 27, 2015 by Noel
0 Broithe Posted January 27, 2015 Posted January 27, 2015 Wow how did I miss this. Only just spotted this layout video now after reading of Kirleys gradient wheel slip. Another wonderful layout that looks incredible fun to operate. I like the long runs and industrial feel. An amazing layout. The connection to the other room is really clever. Looks like you could almost operate as two separate layouts or one long one as per the video. The point-work around the crossover in the door did allow separation of the two main ovals - and there were three places where the controllers could be plugged in to allow for this.
0 Noel Posted February 9, 2016 Posted February 9, 2016 Interesting gradient. It almost looks like a model layout.
0 DiveController Posted February 9, 2016 Posted February 9, 2016 Interesting gradient. It almost looks like a model layout. Hehe, slow and steady………….. waiting to see something going up that slope though:dig:
0 Mayner Posted February 9, 2016 Posted February 9, 2016 (edited) What happens when traction control fails on 1000ton Milk Train on a 1:35 gradient Power required to haul a 30 wagon coal train through a 8.5Km Tunnel on a 1:33 grade (1:24-2:45) Edited February 9, 2016 by Mayner
0 josefstadt Posted February 9, 2016 Posted February 9, 2016 Great videos John. Pity about the soundtrack in the second one though, it would be much nicer if one could hear the 'music' from the locomotives instead.
0 jhb171achill Posted February 9, 2016 Posted February 9, 2016 Would it be fair to say that a 009 gauge loco would need a shallower climb, due to smaller size and smaller weight?
0 josefstadt Posted February 9, 2016 Posted February 9, 2016 Would it be fair to say that a 009 gauge loco would need a shallower climb, due to smaller size and smaller weight? On the other hand the load would be less also, so it might balance out.
0 Broithe Posted February 9, 2016 Posted February 9, 2016 On the other hand the load would be less also, so it might balance out. Or, if it doesn't, you can always try the magnetic path and increase the downforce onto the track without increasing (much) the weight to be raised. http://www.dccconcepts.com/resources/PDFs/030-Reviews/040-Hornby/HM-I95-05-Gradients-and-Powerbase-2015.pdf
0 jhb171achill Posted February 9, 2016 Posted February 9, 2016 Interesting solution, Broithe.... I ask because I'm in planning stage for a thing based on 1975-85 narrow gauge Austria....
0 DiveController Posted February 10, 2016 Posted February 10, 2016 (edited) Interesting solution, Broithe.... I ask because I'm in planning stage for a thing based on 1975-85 narrow gauge Austria.... Just in from work and just happened across this now. Well Done, Dave for posting this and Jim for the PDF. JB, I think this would be a great solution for any layout with gradients, especially a smaller layout where space may not be readily available to allow a long enough gradient even to get one track to climb over another even though this only requires a few inches. Great if this is done at the planning stage as you'd have to tear up sections of gradient to cure wheel slip otherwise. Tedious additional step to do this on a larger layout though if your were to do it, certainly would allow smaller engines to shunt longer trains Edited February 10, 2016 by DiveController
0 Mayner Posted February 10, 2016 Posted February 10, 2016 Great videos John. Pity about the soundtrack in the second one though, it would be much nicer if one could hear the 'music' from the locomotives instead.
burnthebox
37 answers to this question
