David Holman
  1. Been a while, but worth the wait!
  2. The latest newsletter from Lightmoor Press is advertising what is apparently the first ever proper history of this legendary railway. Written by Michael Whitehouse, son of the great railway photographer Patrick, it is going to be over 350 pages (!), covering the social history of the area as well as the railway and will include lots of photos, maps and drawings too. Due out in February/March next year. Definitely one to look forward to.
  3. Freelance 0n16.5 Following comments on J-mo's thread other day, managed to dig a few old photos of my early narrow gauge work. Did it on two separate projects, based on fictional Colonel Stephens type lines in Kent. 'Hawkhurst, High Weald' was scrapped, but 'Cranbrook Town' was sold on, along with the stock, so may still exist somewhere. Being 'photos of photos' the quality of the images is not all it could be. The first picture is 2-6-0T I built around a Lima 08 diesel shunter chassis. The large side tanks were inspired by Clogher Valley Railway 0-4-2Ts and helped hide the large 'pancake' motor. The body is all plasticard, with a 22mm water pipe for the boiler. The chimney was a casting for a 4mm scale GWR King, sawn in half and separated by a piece of brass tube to make it longer. The front pony truck was from a Lima GWR 2-6-2T. Note the outside frames given by the 08 shunter chassis. Picture 2 was built in similar fashion, but this time on an old Hornby 0-6-0 chassis, with CVR style side skirts to hide it. Picture 3 was an 0-6-2T using the rest of the Lima 2-6-2T chassis - again with CVR style side tanks. The fourth, colour picture also shows this loco, but on Cranbrook Town, alongside white metal kit of a Baldwin 4-6-0T The 5th picture was my take on one of the early twin railcar units. The righthand unit is etched brass from an old MTK 'El Crappo' [yes, really] kit. The lefthand unit was built around a Corgi Lipton's Tea van. This was unpowered, but retained the cab unit of the tea van, with a plastic open truck body. The final picture shows my cut & shut version of the Hornby 08 shunter. The bonnet was chopped into three and rearranged either side of a home made cab on a new, wider footplate. It ran beautifully. Hopefully, this shows what can be done if you are happy to go 'freelance' as convincing models can be made very cheaply with a little imagination & patience. You may also spot a transporter wagon in the second picture, carrying a standard gauge open, as per the Leek & Manifold Railway and the end balcony coach, made of plasticard and strip, running on a standard 00 wagon chassis. Taught me a lot working in 0N16.5 and had a lot of fun along the way too.
  4. Ye Gods! Thirty years ago, but still a book I regularly refer to. He also used Westport Quay as the basis for a plan in his Light Railways book - another gem.
  5. Persistence certainly paying off. There are some fine looking models emerging here.
  6. Has more than a bit of Quarry Hunslet about it, though with its Robert McAlpine plates was clearly used in the construction industry - anything from railways to dams. He wasn't known as Concrete Bob for nothing! For me, freelance 7mm narrow gauge got me started on scratchbuilding, back at the end of the last century (winced at this thought). Plastic sheet for footplate and cab, plastic water pipe for the boiler and whatever was handy for fittings. It's amazing what can be done with brass tube, washers and some filler. These days would think freelancing is a good route to practice 3D printing, while a hybrid model as suggested should also work. That said, a more robust cab could mean printing the whole thing and avoid needing too much detail inside - though that is half the fun some might say.I 4mm scale chassis scale up very well in terms of performance, with slow running enhanced in the larger scale. My favourite was the 08 shunter, because of its outside frames. The early Lima version had the rods held on with small screws, which meant you could add outside cylinders and connecting rods quite easily. However, the large pancake motor meant big side tanks were necessary to hide it, but with freelancing anything goes! The later version by Hornby was even better. Remember buying one of the first and then sawing up the body and adding a new, wider footplate, to make a neat little diesel shunter which ran superbly. There's an article in RM somewhere, but will need to go through my photos as all this was in the pre-digital age. Sigh... Great sounding project and will certainly look forward to seeing progress.
  7. Now that is rather splendid. Thank you kind sir!
  8. Approximated dimensions from the photo, Ken. Around 14' long in old money, assuming 3' diameter wheels, which seems to match the basic size of many of these early 'short' vans.
  9. GSWR Open Cattle Wagon After three months getting Belmullet exhibition ready, have finally got back to making something this week. Open topped cattle wagons were a regular feature on Irish railways prior to WW1, though eventually the Board of Trade decreed they shouldn't be used anymore. However, for my early 1900s period, one or two are very much appropriate - running to/from the off stage harbour. The model is fairly conventional, being a plasticard shell, embellished with micro strip of various sections for strapping and iron work. The only reason the doors are black by the way is because this is the only 60thou sheet I have at the moment! Whitemetal castings for buffers, brake gear, axle boxes and so on complete the picture. Unlike the prototype in the picture, the model will be finished in GSWR dark grey. A far from unusual prototype, though not one I've seen modelled that often, probably because unlike other wagon types, they didn't survive into CIE days. Cue Ken to 3D print some???
  10. This is the sort of thing I've been looking at. Managed to find the drawing below on the internet, which seems to be a fairly standard design across a range of manufacturers across the world. Some appeared to have no protection whatsoever for the crew, while others had varieties of cover, including what look like locally made. The one at Donaghadee was like this, while the second picture shows the sort of thing we have at Chatham Historic Dockyard. For me, this has considerable merit, because much of the mechanism and boiler is nicely hidden away! Backwoods Miniatures did a really nice etched kit of one of the 'open' cranes, which was designed to sit on a narrow gauge 0-4-0 chassis. Unfortunately, they have ceased trading [though the website remains live]. Meanwhile there also exists a 1:48 kit from Eastern Europe, which might be useful, though I'm aiming to scratch build a model & have made a simple line drawing, as seen in the third picture. Why? Well ever since Iain Rice's 'Cameo Layouts' book came out, I've been fascinated by one of his plans, as shown in the last picture. A [very] simple harbour scene, which I've been slowly developing into a 7mm scale, 5'3" gauge idea - more of this eventually! For now though, you can see why I've got the interest in the crane - Iain's drawing shows a separate track for a self propelled crane, running along the quayside and while I have not intention at the moment of making the crane actually work, making it so it can trundle up and down the quay shouldn't be too difficult, hopefully...
  11. Fantastic, well done Mike. Any plans for making it work?
  12. Have turned up some interesting stuff on the web, including a nice example at Donaghadee quay. From what I can see, steam cranes followed a fairly standard design and often sported locally made bodywork/cabins, so looks like there's a project here!
  13. Just a thought, but with the poor availability and eye watering costs, have you considered trying automotive rattle cans or even artist's acrylic paints?
  14. Continues to amaze me what you folk out there can contribute. Lovely stuff!
  15. Some sound advice here, which certainly highlights the complexities of 3D printing. All power to you folk who are doing this pioneering work!
  16. Thanks Ken. The crane I'm thinking of is a self propelled one, running on its own length of quayside track, to help unload said coasters. We have a couple outside the Chatham Club room - vertical boiler on a simple four wheel chassis, with a basic bombshell around the mechanisms. A bit like 'Pat', with a jib.
  17. Just remembered I asked about Puffers a while ago, but any other craft, including West coast fishing boats would be of interest.
  18. Been pondering on the above as a possible project for a while, so thought it time to try tapping into the immense resource of this website - note flattery! Seem to remember Fenit pier had several rail mounted cranes, but were there any other places? Also wondering if a smaller, wagon mounted crane, pushed/pulled by something like 'Pat' from the elevated track in Cork might be appropriate. Any pointers welcome. Likewise any info on small coastal ships that might have plied the west coast. Around the size of a Clyde Puffer, which works out at about 50cm x 15cm. Anyone would think I'm looking into creating a small harbour scene...
  19. Didn't notice, but see what you mean and thank goodness for Archer's rivet transfers! The photos also show the considerable 'presence' Enniskillen emits - a combination of both model making and that paint job, which just looks so right.
  20. Nice one!
  21. Thanks folks, it was great to meet you all at Uckfield, though anyone who went on Sunday got a far better deal than Saturday... Got to Uckfield for opening time on the Friday evening & spent the next two and a half hours carefully setting everything up. Far too long, but I was on my own, so would hope to halve this, now I know more about what I'm doing, especially as needed another hour setting out stock and doing basic running tests on Saturday morning. It was all going well at this point, but it seemed as soon as the public came in, problems began. Running became increasingly erratic. At first we thought it was something to do with the single slip and indeed later discovered a stray strand of wire was creating an intermittent short on the power feed to one of the Megapoint panels. However, the real elephant in the room turned out to be my Gaugemaster hand held controller, which eventually just packed up completely. My spare is another Gaugemaster, but a more basic model which doesn't even out power delivery as well as the other, so operators were still struggling to drive the trains smoothly. At this point, I was looking round the traders to see if anyone had any controllers for sale. Coastal DCC was right next door, but my stuff is analogue... Suddenly there was a moment of inspiration from regular operator John - have you checked the lead to the controller plug? And there it was, a loose wire in the five pin din plug. Two minutes with the soldering iron and all was [mostly] well, apart from my nervous system that is! By now, it was lunchtime, so decided to swap the 1950s stock for the 1900s stuff. A bit of a faff, to say the least, but finally got everything changed over & ran this for the rest of Saturday and all day Sunday. At last, things started to settle down & the only major problem after that was the failure of 0-4-2T 'Lark', which I've since found out has both a slipping main gear wheel and a broken slide bar set on one side. Substituted the J26 - wrong period, but better than the Deutz diesel! The highlight of Saturday was having Galteemore and his son helping to operate, while the icing on the cake was having Enniskillen and the 2-2-2T on the layout as well. Have included a few photos below, to go with theirs, along with an overall view of the layout itself, once set up. There are certainly things I would do differently. For starters, it is not practical to change periods part way through the day. Far better to give a whole day to one period & if it was a one day show, then it would have to be one or the other. Indeed, Friday evening setting up looks like it would be essential, while packing everything up takes time too - it was 75 minutes before I got away on Sunday. Compare that to Fintonagh, which can be set up in 45 minutes and back in the car in 15 after a show. It certainly makes you wonder. The next appearance certainly won't be for a while. Fintonagh has several outstanding bookings to fulfil from 2020, including Allypally, Tonbridge and Nailsea. Southampton, Tonbridge and Epsom have expressed interest in Belmullet, but not until at least 2022/3. Right now, I'm looking forward to doing some modelling for a change as I haven't made anything since before the summer and have several projects I want to do. Once again, many thanks for all the kind comments and especially the operators, because I could not have done it without you.
  22. Report to follow, but it was great to have a fellow Sligo fan operating for the day, as well as providing lots of new info. Enniskillen every bit as good as it looks in the photos while the little single was a treat. Electrical problems (eventually traced to the controller plug/socket plagued much of the morning, but things settled down pm. All to do again today!
  23. Spring into summer down under, just as we in the North head towards winter. Enjoy!
  24. Certainly agree there! Once again, impressive work Ken.
  25. Thanks Paul. Hope the marathon goes well. Good training for a weekend of exhbiting!
