DiveController
  1. Looking forward to it, Noel!
  2. I have a number of these coaches from the Bachmann set and coaches sold separately including a number of duplicate running numbers (one of which was in the wrong box when purchased). I'd like to renumber them and was wondering if anybobody knows where I can get transfers to renumber them (green numbers on the eau de nil band) Thanks in advance
  3. Always interested in cheaper when you get a chance to post:tumbsup:
  4. Yup. Dave got in there before me. If you have space for a loop in the layout or a helix, that will keep your gradient lower. Alternatively, If you can drop the thing you wish to climb over, you can effectively half the gradient/length you need to climb (one climbs 2 inches, one drops two inches= 4 inches clearance)
  5. Just remember you need to pay postage from the US plus import duty when it arrives. The transformer is probably 110V. The others on eBay are ridiculously priced however which is why they haven't sold. They've been up there for months. EDIT: Just had a chance to read this. If any of you want to bid on this, the quoted post if for US GROUND. You will need Intl. AIRMAIL which is more expensive FROM the USA then in the reverse direction. This is an outsize item, so to avoid coronary occlusion you should get a shipping qoute from the seller BEFORE you bid, not after as suggested by the seller!!
  6. I guess I was thinking of the preformed foam that fits between the sleepers, so do you use just a sheet of foam that is cut to width and do you taper off the edges eventually wide of the ballast? and how do you taper that edge, and what foam would you recommend? Questions, questions.....
  7. this is an interesting topic that has come up before,. My vested interest is that I am trying to design a layout and will inevitably have to ballast it. Foam insulates well against sound but I think that someone stated (probably on a previous thread) that this sound-proofing effect is lost once the PVA glue on the ballast dries and establishes a rigid layer that transmits the sound back to the baseboard (now, I don't know if anyone has stuck an audiometer on there and measured the noise in decibels so it probably worse to some extent but maybe not as good as before ballasting)
  8. Interesting thread, Glenderg. I knew there were TPO's but have never really seen many pictures of them. Not sure that the model on eBay looks much like this, sprayed green with the flying snail stuck instead of a P&T. Seems like the catchers were not a big feature on the Irish TPOs. I wonder if they stop took most of the main stations to let passengers on and off and collected that way instead of by catcher on an express, even though I know would've been all sorted en route. I wonder if anyone on the site has modeled some more authentic versions of the Irish TPOs?
  9. Did this ever actually run in Ireland or even up north?:confused:I thought this was a UK only coach?
  10. Cosmetic defect will not affect the chassis you need on this one http://www.ebay.ie/itm/Bachmann-32-525A-Class-55-Deltic-The-Kings-Own-Yorkshire-Light-Infantry-/390965704761?pt=UK_Trains_Railway_Models&hash=item5b075f3839
  11. I doubt they'd maintain the line for just one train…… there reason it's shut is they don't want to run anything else on it, if you se my point. :SORRY:Shattered dream, I know
  12. That's a shame. The 'French method' seems better
  13. Too small scale, methinks. If you wanted to do that on a railway, the tonnage/speed of the train would be weaponized in a critical area to create more havoc and loss of adjacent trains, buildings, infrastructure. We've already seen attacks of the Spanish and Japanese rail networks. Individuals have routinely thrown bricks and other objects at trains from elevated positions such as the Glanmire tunnel approaching Kent station and even tied a poor donkey to the rails at one point. Incapacitating the driver of a train approaching a station could have profound consequences although I presume the locomotive still has some form of 'dead man's handle' (pardon the expression)
  14. If you do a conversion on the chassis could you post some pics of the steps, please?
  15. Great series of photos, John. Lovely station building. Great to see these for modeling and even to select preassembled 'look-alikes' for the rest of us!
  16. Think Noel is not into 201s but that's good to know as I also have a rake of 141/181s that will need to be done and I intend to do some consists:)
  17. Probably why it failed, John. Difficult to be competitive without the infrastructure. Wonder how much it would cost now, 23m punts then, billions now. It would be interesting to see if that had been implemented how the network would look now and whether the railways would be in greater usage for both passenger and freight, like European counterparts, not to mention the huge socioeconomic benefits.
  18. Neanderthals!……….. pity they weren't still driving it on there, a swift buffer up the a*** is what is required there!
  19. Errr,….. just for those who didn't actually read the thread, that toxic metal dust is not advised:puke:
  20. Great clip Dave!
  21. Really? Can you explain why this item is so valuable or it's just a nice little nostalgic piece?
  22. You will have to pick it up in person, because apparently it doesn't post!
  23. Like the spoils, Kirley. Very authentic to the photos. Nice job!
