British locos and stock that can be disguised as Irish
Westcorkrailway
3 minutes ago, Westcorkrailway said:
I’ll start with the obvious ones
SECR N class- MGWR K class
LMS jinty- NCC Jinty
LMS compound- V class
Adams radial-BCDR tanks
jubilee class-GSR 800 class
my example of GSR 479 made from an Adams radial
In fact once you remove the cylinder, this loco could become many Irish prototypes
Fowler 2-6-4t - NCC WT class
Dean goods- J15
  • Like 5
2 hours ago, jhb171achill said:
BR Mk. 1 full parcels brake = CIE “BR” genny van
Plus of course, numerous Mk 2 & Mk 3 carriages….
MK3 and MK4 coach -Irish mark iv coach (DVT had no realistic option)
hattons genisis coaches have similarities to designs over here, I’m sure @jhb171achill can elaborate on which ones
obviously a lot of early CIE wagons have parallels to BR wagons
GSR/CIE Pullman cars perhaps
SR schools class - GNR VS class
Edited by Westcorkrailway
The GSR Pullman cars were a bit like De Dietrichs, 800 or the Fintona tram in that they were specific in their use and location. There were just four, and only one per train. One each was on the up and down day mails between Dublin and Cork, and Dublin & Galway. So you’re going to need Bredins and GSWR wooden stock to run with them, with a “Maedb” or a 400 or possibly a Woolwich up front.
But yes, in theory, 2-foot rule, just repaint green. Also they had different window spacing, different ends, and matchboard lower panelling.
Ive an idea they had different bogies too, though I’d need to check that.
The NER/LNER J72 0-6-0T “Joem “ are very close dimensionally to the MGWR E / GSR J26 “Bat”, which lasted long, and got out into odd corners.
If you cut a foot off the back of a GWR 2251 0-6-0, the chassis is a good match for the MGWR L / GSR J18/19, although the superstructure will need a lot of work.
  • Informative 2
There are a number of British 0.6.0s which with little more than perhaps replacing the cab with something "Inchicore-looking" could pass off as a "generic" Irish loco.
Bear in mind, if modelling is based on a "three foot rule", that the best locos for a scenario like this will almost certainly be tender 0.6.0s. yes, the LNER J72 can indeed look very MGWR "E" class - just drop it into a pot of grey paint!
Many 4.4.0s also will look "half-Irish" if painted blue for GNR or grey for GSR / CIE. I have seen posts here and there of some very nice conversions of 2.6.0s or 4.6.0s into Irish versions.
Disguised J26 (J72)
2E7DF63E-4F7E-4EB6-AB26-1AFC6698CE4C.jpeg.d2b9a33631bbb1680996b183eebd754f.jpegMore accurate model of J26
these were a very universal machine making it to small lines like Courtmacsherry, Tramore and fenit. So if you wanted to make a shunting layout of a terminus on a small branch, these would be the job. SSM also make a kit for these locos
While not to the taste of all (what livery is?), a "generic" repaint of a British loco as an Irish one will look more convincing if it is in the grey - as black can simply look like unlined BR! If BR had painted their engines grey instead of black and put big pale yellow numbers on them, it would be the other way round.....
In this particular case, the modeller  is not a fan of GSR/CIE grey…hence why black was chosen. He still has not come round to putting transfers on!
Lima BSK = CIE BR Mk1 GSV with some kit bashing
Hornby BR Mk3 = IR/IE Mk3 (sort of)
Bachmann GWR Ventilated Vans = CIE exGSWR Vans
Dapol GWR Vent Vans = CIE Vans
Hornby/Tri-Ang GWR Toad Brake van = exGSWR brake van (some poetic license)
Edited by Noel
  • Like 10
2 hours ago, DoctorPan said:
Hornby LMS Railroad coaches look Bredin esque to cover the 2ft rule.
I've two of these in LMS livery.
They are indeed a good "2-ft rule" approximation for Bredins or CIE 1951-3 series, or even some sort of broadly generic "laminate", but by simply repainting the silver roof dark grey and deleting the letters "LMS" from the sides, you've actually exact GSR livery they had as new, correct lining and all; at that time the GSR, LMS and NCC used the same maroon and even had identical lining (NCC latterly less or no lining).
So I'm holding the two I have for eventual use as weathered "Bredins" still in GSR livery, once I've enough six wheelers in the older green to surround them with, for a late 1940s or early-1950s version of operating. (Need more ancient-design wagons and two more steam locos as well).
So there is a chance we will see very rare GSR era snaps of Dugort harbour someday?!
I’m waiting for hattons genesis coaches come out, and if there as good as they look, I’ll paint them in post 1955 CIE green
Yeah, they look good in GSR guise as well
The DSER had some LNWR-built 2-4-2Ts, I think of Webb design. Curiously at least one of them was subsequently regauged to 4'8.5 and ended up in a colliery in GB.
I don't know if there's a kit (doubt RTR?) for that type but someone will know I'm sure.
Edited by Niles
Aye, the DSER bought 6 of them in 1902, London Road Models make a kit of them (as well as, incidentally, the 'Special Tanks' of the same design as used on the Dundalk Newry and Greenore Rly)
CRAMLINGTON COAL CO. - 14 - Webb LNWR Class 71 2-4-2T - built 1883 by Crewe Works as L:NWR No.2496 - 1902 withdrawn, regauged & sold to Dublin & South Eastern Railway as No.61 EARL OF WICKLOW - 1917 sold to Cramlington Coal Co., regauged, as No.14 - 1929 scrapped.
The 6 ex-LNWR 4'6" 2-4-2Ts did not last too long in their original condition on the DSER one No64 was re-built with a new boiler and cylinders in 1914, the remaining 5 were returned to the UK during WW1 mainly for industrial use.
Apart from the small driving wheels and side tanks the re-built No64/427 resembled a DSER rather than a Webb loco with a high pitched boiler, DSER cab, boiler fittings.
Ironically Robinson's pair of WLWR 2-4-2T 13 & 14 look similar to the LNWR 5'6" 2-4-2T, both 13 & 14 survived into the mid 1930s with relatively minor modification as 267 and 491. The GSWR sold  13 (GSWR 266) to the Cork Macroom Direct in the early 1900s, following the amalgamation the loco grouped with CMDR rather than the  GSWR locos and received a different class designation (F5) to 266 Inchacore apparently forgetting that the two locos were nearly identical.
Class F5 - 491 - Cork and Macroom Direct Railway 2-4-2T - built 1891 by Vulcan Foundry, Works No.1315. as WLWR No.13 DERRY CASTLE - 1901 to GSWR as No.266 - 1914 sold to CMDR as No.6 - 1925 to GSR as Class F5 No.491 - 1934 withdrawn.
GEM produced whitemetal kits of both the Webb 4'6" and 5'6" 2-4-2T the 5'6" would be a reasonable choice for a rtr model potentially available in LNWR, LMS and British Railways schemes
  • Like 5
  • 1 month later...
On 31/1/2022 at 9:04 PM, Westcorkrailway said:
So there is a chance we will see very rare GSR era snaps of Dugort …..
Once I get everything 1955-65 up’n’running, the next stage is a world of grey steam engines (in somewhat cleaner state than CIE had them!) and a mix of maroon and darker green carriages to depict 1945-49.
Hence my continual whinging about six-wheelers!
I have high hopes for the Genesis coaches from Hattons….
We now have the excellent KMCE Models producing the sort of ancient goods stock in common use in GSR days (and later). Provincial Leslie does the GSWR guards van, so we’re sorted!
Once someone does a RTR 6w chassis, turf wagons can be made up out of just about any oul junk in the spare bits box….
if anyone feels like bodging a few 6 wheelers be my guest!
I more then likely will be getting genesis coaches of some description, and many of us will. I don’t think many will be trying to make one of these Emergency era……wagons?
  • Like 5
@jhb171achillwould still prefer travelling in one of those to an ICR….
  • Funny 4
