Mol_PMB Posted June 29 Posted June 29 Although it is partially dismantled, the wooden-framed tank container is fascinating. It appears to be resting on the underframe of a more conventional tank wagon. I found a few more photos of similar things, including the other side of the same one with different lettering: https://www.flickr.com/photos/irishrailwayarchive/54252949956/ https://www.flickr.com/photos/irishrailwayarchive/54252053167/ https://www.flickr.com/photos/irishrailwayarchive/53511272051/ https://www.flickr.com/photos/irishrailwayarchive/53511702435/ I wonder what else these were carried on? Standard gauge wagons or road vehicles? 1
Andy Cundick Posted June 29 Posted June 29 343 was a Shell tank wagon purchased from the Swilly in 1954 as a chassis The tank being owned by Shell as is usual didn't form part of the deal.The same setup is shown in"County Donegal Remembered" p130,in much better condition supposedly Sept 1960 though i have my doubts.oddly A2103 is lettered up as Shell I wonder if that is all to do with the joint trading agreement between Shell and BP at the time and as the tank wasn,t big enough to have both companies on each side they each had their own side.Food for thought.Andy 1 1
jhb171achill Posted June 29 Posted June 29 (edited) 10 hours ago, Irishswissernie said: CBSC 1958-06-04 Baltimore C232 train from Drimoleague. PFF073. That Baltimore view is classic. A smoky old Crossley, an ex-MGWR six wheel third a LONG way from home (at that time, there were quite a few of these based in Cork, both at Albert Quayand glanmire), another six-wheel third of indeterminate parentage but probably also Midland, a brand new tin van (essential on ALL diesel trains if they wanted heat or light!) and a 1920s-era GSWR main line composite.... Edited June 29 by jhb171achill 4
airfixfan Posted June 30 Posted June 30 Some of the CDR tank wagons used for water for locos on the lifting train 1
jhb171achill Posted July 1 Posted July 1 On 10/6/2025 at 10:38 AM, Galteemore said: Lovely pic of Ballintogher Ernie, but I think it’s printed back to front…. Maybe it was just going in the other direction.................................
Mayner Posted July 2 Posted July 2 On 30/6/2025 at 4:52 AM, jhb171achill said: That Baltimore view is classic. A smoky old Crossley, an ex-MGWR six wheel third a LONG way from home (at that time, there were quite a few of these based in Cork, both at Albert Quayand glanmire), another six-wheel third of indeterminate parentage but probably also Midland, a brand new tin van (essential on ALL diesel trains if they wanted heat or light!) and a 1920s-era GSWR main line composite.... No heating on this particular train the brand new Tin Van is actually a Luggage Van no boiler for steam heating and notoriously rough riding that guard would seldom ride in if anything else was available. CIE converted a number of 20s era GSR Comp coaches into "Self Heating Coaches" (electric heating powered by an underfloor generator) for C Class haulage on Clonakilty & Skibereen/Baltimore branches. 3 3
mfjoc Posted July 3 Posted July 3 10 hours ago, Mayner said: CIE converted a number of 20s era GSR Comp coaches into "Self Heating Coaches" (electric heating powered by an underfloor generator) for C Class haulage on Clonakilty & Skibereen/Baltimore branches. Wow This is a new one on me. Never heard this before. Were they used anywhere else? You would need a decent sized genset to heat a carriage. I always thought that the first electrically heated coaches were the mk2s, apart from the Laminates fitted with storage heaters for the Loughrea branch. In the 1970's the bogie steam heating vans, the 3200 brake standards and the push pull railcar conversions were all fitted with either a lister or italian genset but only for trainlighting. Heating was always by steam from oil fired boilers. The Italian ones fitted to the push pulls had a tendency to self combust and extensive fire proofing was added in the 80's just to keep a few sets running. Also in the 1980s there was a discussion about converting the Cravens to electric heating but it didn't proceed. 1
jhb171achill Posted July 3 Posted July 3 39 minutes ago, mfjoc said: Wow This is a new one on me. Never heard this before. Were they used anywhere else? You would need a decent sized genset to heat a carriage. I always thought that the first electrically heated coaches were the mk2s, apart from the Laminates fitted with storage heaters for the Loughrea branch. In the 1970's the bogie steam heating vans, the 3200 brake standards and the push pull railcar conversions were all fitted with either a lister or italian genset but only for trainlighting. Heating was always by steam from oil fired boilers. The Italian ones fitted to the push pulls had a tendency to self combust and extensive fire proofing was added in the 80's just to keep a few sets running. Also in the 1980s there was a discussion about converting the Cravens to electric heating but it didn't proceed. I hadn’t heard of this either
Mayner Posted July 3 Posted July 3 1 hour ago, mfjoc said: Wow This is a new one on me. Never heard this before. Were they used anywhere else? You would need a decent sized genset to heat a carriage. I always thought that the first electrically heated coaches were the mk2s, apart from the Laminates fitted with storage heaters for the Loughrea branch. In the 1970's the bogie steam heating vans, the 3200 brake standards and the push pull railcar conversions were all fitted with either a lister or italian genset but only for trainlighting. Heating was always by steam from oil fired boilers. The Italian ones fitted to the push pulls had a tendency to self combust and extensive fire proofing was added in the 80's just to keep a few sets running. Also in the 1980s there was a discussion about converting the Cravens to electric heating but it didn't proceed. Info originally appeared in "Irish Railfans News" during the 50s, IRN Archive posted on the RPSI website about 12 years ago, but no longer accessible! As far as I recall the 'self heating' carriages were fitted with an underfloor proprietary petrol-electric genset, apparently the gensets were unreliable in service and a number of C Class fitted with jumper sockets fir electric train heating. There is a 1968 picture in "Irish Metrovick Diesels: of a recently outshopped C203 in Black with yellow warning panel & buffer, with a silver power socket mounted vertically on the buffer beam. Ironic CIEs 1st exprements with electric train heating was with 30 year old coaches hauled by C Class diesels on West Cork branches. IRN article included coach numbers and info on gen-set I downloaded the articles at the time, possibly on some back up drive/archive the computer I used in 2013 gave up the ghost several years ago. 2
Mol_PMB Posted July 3 Posted July 3 (edited) 46 minutes ago, Mayner said: Info originally appeared in "Irish Railfans News" during the 50s, IRN Archive posted on the RPSI website about 12 years ago, but no longer accessible! As far as I recall the 'self heating' carriages were fitted with an underfloor proprietary petrol-electric genset, apparently the gensets were unreliable in service and a number of C Class fitted with jumper sockets fir electric train heating. There is a 1968 picture in "Irish Metrovick Diesels: of a recently outshopped C203 in Black with yellow warning panel & buffer, with a silver power socket mounted vertically on the buffer beam. Ironic CIEs 1st exprements with electric train heating was with 30 year old coaches hauled by C Class diesels on West Cork branches. IRN article included coach numbers and info on gen-set I downloaded the articles at the time, possibly on some back up drive/archive the computer I used in 2013 gave up the ghost several years ago. IRRS Journal No.90 (feb 1983) includes the first of a 2-part article by D Renehan on CIE's Crossley Diesels. He notes: "An interesting development was the fitting of equipment to supply electric train-lighting for use on branch line services; 203, 213, 215, 218, 223 and 231 were among the ten so fitted. A jumper box was provided on the buffer beam, and a cable carried current from the generator to specially-equipped carriages. The experiment was, however, short-lived - the reason for it ceased to exist when the branch lines were closed." A study of photos might identify the other 4 locos fitted, and the dates when the equipment was fitted and removed. An interesting variant for IRM to consider on their (hopefully) forthcoming C class model. Edit: from looking at a few photos it seems they were installed around 1960, and retained until the locos were rebuilt with EMD engines. Their place on the bufferbeam was then taken up by multi-working jumpers. Edited July 3 by Mol_PMB
Mol_PMB Posted July 3 Posted July 3 (edited) Here are photos from Ernie's archive of C203 and C218 (twice) with electric lighting jumpers: Edit: a search on Flickr found the following extra locos with the jumpers: C208: https://www.flickr.com/photos/irishrailwayarchive/54251291146/ C217: https://www.flickr.com/photos/irishswissernie/50995050488/ C226: https://www.flickr.com/photos/holycorner/6749912153/ In addition to D Renehan's six: 203, 213, 215, 218, 223 and 231 all of which can be confirmed from photos. There ought to be one more, for the total of 10. As yet I haven't been able to disprove C228, which was rather camera-shy in the period of interest. Edited July 3 by Mol_PMB Final para and links added. 4
Mayner Posted July 4 Posted July 4 I managed to dig-up some more info. on the "self-heating coaches" 5 ex-GSWR Composite coaches 2089.2094,2096,2097 & 2098 were fitted with "Victor" diesel generators and initially considered 'moderately reliable", but generators removed by Jan 1960. Two were in use on the Clonakilty & Skibereen/Baltimore Branches. Its possible the other "self-heating coaches" may have been used on the Birr and Ballina branches with a C pottering around with a single passenger coach, Valencia passenger appears to have loaded up to 4 coaches behind a C, Galway-Tuam & Cork-Youghal appear to have been heavier A Class workings https://irishrailwaymodeller.com/topic/5693-characteristics-of-cie-metrovick-c-class-locomotives/ While I referred to Jan 56 and Jan 60 Irish Railfans News in the original post, the info on the "self-heating coaches" is likely to have appeared in the Jan 28 IRN or possibly later! While I haven't been able to track down 2089 the remaining "self-heating coaches" /fitted for electric train heating were all withdrawn by 1964. 2094 introduced as a 57' 1st/2nd/3rd in 1915 was withdrawn in 1964, 2096-8 were introduced as 57' 1st/2nd with GSWR later more spartan style of panneling between 1920-21 were withdrawn between 1962-3. There are diagrams of these coaches in the TRA reprint of the GSWR diagram book, but the diagrams are of limited use for modelling purposes as they show only one side of coaches which had different window and panneling arangements on the corridor and compartment sides. 3
jhb171achill Posted July 4 Posted July 4 1 hour ago, Mayner said: I managed to dig-up some more info. on the "self-heating coaches" 5 ex-GSWR Composite coaches 2089.2094,2096,2097 & 2098 were fitted with "Victor" diesel generators and initially considered 'moderately reliable", but generators removed by Jan 1960. Two were in use on the Clonakilty & Skibereen/Baltimore Branches. Its possible the other "self-heating coaches" may have been used on the Birr and Ballina branches with a C pottering around with a single passenger coach, Valencia passenger appears to have loaded up to 4 coaches behind a C, Galway-Tuam & Cork-Youghal appear to have been heavier A Class workings https://irishrailwaymodeller.com/topic/5693-characteristics-of-cie-metrovick-c-class-locomotives/ While I referred to Jan 56 and Jan 60 Irish Railfans News in the original post, the info on the "self-heating coaches" is likely to have appeared in the Jan 28 IRN or possibly later! While I haven't been able to track down 2089 the remaining "self-heating coaches" /fitted for electric train heating were all withdrawn by 1964. 2094 introduced as a 57' 1st/2nd/3rd in 1915 was withdrawn in 1964, 2096-8 were introduced as 57' 1st/2nd with GSWR later more spartan style of panneling between 1920-21 were withdrawn between 1962-3. There are diagrams of these coaches in the TRA reprint of the GSWR diagram book, but the diagrams are of limited use for modelling purposes as they show only one side of coaches which had different window and panneling arangements on the corridor and compartment sides. Superb stuff. If IRM or anyone else ever get around to doing a "C", it would be an interesting appendage to have, not just for detail, but to enable those who like strict accuracy to be able to run a prototypical train. Now all we need is a RTR wooden composite bogie, as used in so many ways in the 50s and on into the black'n'tan era briefly. Single composite bogies of the very type shopwn above were used on the lines Mayner mentions, plus also Kenmare, Loughrea, Baltimore, North Wexford, Ballaghadarreen, and gawd knows where else. 2 1
Irishswissernie Posted July 6 Author Posted July 6 CIE 1963-03-xx Edenderry B173 yj190. CIE 1960-CA Thurles A17 yj102. CIE 1965-1967 Cahir. CIE 1965-1967 Cahir y035. 13
Mol_PMB Posted July 6 Posted July 6 I like the shot at Thurles, reminding us how the last year or two of steam overlapped with the black and tan livery. 1
jhb171achill Posted July 6 Posted July 6 The first one shows an interesting selection of coaches. A late GSWR / early GSR (circa 1925 +/-) high capacity suburban brake, of a type used on lines like Cobh and Youghal, and several Park Royals. Probably a tin van at the en The one at Thurles, apparently with several engines in steam, is almost certainly during the beet season, when steam was used on beet specials in that area, and especially between Thurles, Clonmel and Waterford. 1
Irishswissernie Posted July 10 Author Posted July 10 4 views from the latest acquisitions covering the CDRJC, SLNCR, CBSC & the GNRI at Enniskillen. CDRJC 1957 Donegal Town BR Type A container on bogie wagon. PFF304 CBSC 1957 - + Bantry Town waterside. PFF207. GNRI 1957-09-03 PP 44 & P 73 doublehead Omagh train. PFF233. SLNC 1957-09-03 Enniskillen 'Sir Henry'. PFF265. Note the chap - probably the fireman, perched on a plank between the loco and the wagon which presumably is loaded with coal but of somewhat dubious quality. 14
Mol_PMB Posted July 10 Posted July 10 Nice (partial) view of the lettering on a new corrugated open wagon in that last image, including the snail. Note that this is one of the wagons with 4-shoe handbrakes positioned outboard of the wheels. Also I like the narrow-gauge bogie container flat in the first image! 1
Andy Cundick Posted July 10 Posted July 10 The flat is 336 a Ballymena coach chassis purchased from the NCC in 1947.The problem with the BR containers were that they were slightly wider than the ordinary opens/flats however they got round that by using dropsides and running them with sides down,i was a bit sceptical about that until i found a photo of just that hence Brucklees has one running round on it.Andy 3 1
Irishswissernie Posted July 12 Author Posted July 12 Patrick Davey drew my attention to a wrong caption on the Archive from the late JW Armstrong of Kells on the Valencia Island branch which should have been Glenbeigh; now duly amended. Thanks Patrick! I do have a couple of Casserley negatives of Kells taken 21 years apart so have added them today. GSR 1934-07-11 Kells, 128. HCC Glass 11087 Cas25019. CIE 1955-04-14 Kells 127 RMC83272 Cas25100 7 1
Mol_PMB Posted July 12 Posted July 12 3 hours ago, Irishswissernie said: GSR 1934-07-11 Kells, 128. HCC Glass 11087 Cas25019. Note the covered carriage truck (with end doors and high arc roof) immediately behind the loco. Other nice details in shot include the staff exchange about to occur, and the loading ramp on the right behind the station sign. 2
Irishswissernie Posted July 13 Author Posted July 13 GMK031 CIE 1955-xx Cork Glanmire Road shed 401 L114. GMK050 CIE1955-xx Cork A1. GMK089 CIE 1955-xx Cork, Clerestory Compo & 6whl brake 10m C144. 12
GSR 800 Posted July 13 Posted July 13 (edited) 17 minutes ago, Irishswissernie said: GMK031 CIE 1955-xx Cork Glanmire Road shed 401 L114. GMK050 CIE1955-xx Cork A1. GMK089 CIE 1955-xx Cork, Clerestory Compo & 6whl brake 10m C144. Great photo, looks to be Macha, possibly Tailte. Edited July 13 by GSR 800 1
Irishswissernie Posted July 20 Author Posted July 20 C&M 1934-07-09 Coachford Junction 8K 12.05 Cork - Blarney HCC11058 Cas25143. GSR 1934-07-17 Westport. 651 6.00 to Dublin HCC11198 Cas25165. SLNC 1929-09-19 Manorhamilton 'Lissadell' 1.40 Enniskillen - Sligo. HCC glass 6316 Cas25001. 13
Galteemore Posted July 20 Posted July 20 Gorgeous. SLNC coach is still very new, and has the clerestory windows still - in later life the entire roof was felted. 2
Irishswissernie Posted July 24 Author Posted July 24 GNRI 1965-xx CA Dundalk WT. GNRI 1965-07-19 Belfast 'Shaky Bridge' Antrim-Bangor Exc. 49 JGD651137. GNRI 1964-06-13 Omagh South cabin, 60 ref25j+004 15
jhb171achill Posted July 24 Posted July 24 (edited) 9 hours ago, Irishswissernie said: GNRI 1965-xx CA Dundalk WT. This one has to be 1968 or 69 as the loco has an NIR emblem on it in place of the UTA one. That makes me wonder what it's doing there - almost certainly borrowed for an RPSI operation, as the society did not yet own No. 4. On 20/7/2025 at 8:03 AM, Irishswissernie said: C&M 1934-07-09 Coachford Junction 8K 12.05 Cork - Blarney HCC11058 Cas25143. Last year of operation. Rear goods van still in pre-GSR Muskerry livery. Edited July 24 by jhb171achill 2
jhb171achill Posted July 24 Posted July 24 On 12/7/2025 at 10:58 AM, Mol_PMB said: Note the covered carriage truck (with end doors and high arc roof) immediately behind the loco. Other nice details in shot include the staff exchange about to occur, and the loading ramp on the right behind the station sign. Not just that - with a roof profile like that it's almost certainly ex-DSER, which makes it an exceptionally rare, if not unique beast. Plus, it could hardly be further away from home. The number of ex-DSER vehicles which went to Kells throughout its life could probably be numbered on the fingers of one hand. 3
Irishswissernie Posted July 24 Author Posted July 24 1 hour ago, jhb171achill said: This one has to be 1968 or 69 as the loco has an NIR emblem on it in place of the UTA one. I've amended the date(s) to 1968/9 , there are no dates on the original which is very dark and my eyesight isn't so good. 3
Patrick Davey Posted July 25 Posted July 25 (edited) On 12/7/2025 at 7:55 AM, Irishswissernie said: Classic photo of Kells - one of three Irish stations with that name. I was there recently: And I was particularly fortunate to meet somebody who was working in the building, and he showed me the largely unaltered interior: The problem with visiting places like this is that it gives you ideas Edited July 25 by Patrick Davey 13 1
jhb171achill Posted July 25 Posted July 25 2 hours ago, Patrick Davey said: The problem with visiting places like this is that it gives you ideas I await with great interest a P. Davey west Kerry mini-layout! 2 1
Paul 34F Posted July 26 Posted July 26 Very nice piece of restoration. Also interesting to see a GNRI A class in as built in the photograph. Not seen that one before Paul 1
