Video Website Updates
Sorry Noel I am not sure of the reason why only 1 container is loaded per flat wagon.
Irish Rail 071 loco 074 + relay train passes Rush & Lusk
Date: 27 February 2015
Service: 13.43 North Wall to Platin
[video=youtube_share;vzsslEs7VuQ]
The track in the video looking after the relay train has passed seems to be severely buckled.
Noel - the wagons can hold either 2x 20ft, 1x 30ft, 1x 40ft or 1x 45ft. The tanktainers are generally 30-35ft long, meaning only one per wagon.
Thanks. That makes sense.
Yes I noticed that too. IE's Lada approach to infrastructure management. Buy lots of shiny new trains, scraping stock still with 15 years shelf life remaining, retiring many 18yo 201s, instead of upgrading the networks track work to better quality and higher speeds.
Just an optical ollusion due to the zoom. Well known effect.
Regards stored 201's - they have non-standard bearings and various other fittings that make them more expensive than even the 071's (spares pool from 30-40 years of use, plus the Baby GM's)
  • 1 month later...
Irish Rail 29000 DMU 29029 operated the M3 Parkway to Clonsilla shuttle services yesterday. Here are 4 videos taken from Dunboyne station.
[video=youtube;x2KFFD-sFU0]
[video=youtube;27-j_iQWlr4]
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
Having watched your clip, I found this on youTube
Look at about 4m15s into the video the 201 runs over opposed check points that are open and forces them closed! Is this normal a normal op?
[video=youtube;-6m-L-X7vDc]
Also at 6mins into clip she runs back through a red signal with a small semaphore square not set at danger!!! Is the semaphore shape a shunting signal that overrides the main light?
Edited by Noel
Also at 6mins into clip she runs back through a red light with a small semaphore square not set at danger!!!
Regarding the catch points, these are sprung and their purpose is to derail a runaway travelling in the opposite direction only. With double line working, trains run along the left-hand track in the direction of travel and so there's a greater danger posed by a runaway travelling in the opposite direction than there is by one travelling 'the right way'.
Edited by Garfield
Thanks. I just had never seen trap/catch points run over on a main line like that before. They must be fairly heavily engineered to have an entire liner train spring them back and forth as each bogie passes over.
The terms are not actually interchangeable by the way
These are catch points. Catch points tend to be exclusive to running lines and are sprung to allow a train in the trailing direction to push the blades over. They used to commonly found at the base of inclines to prevent runaways from re entering a station or junction. They are not under the control of a signal centre.
Trap points are or used to be far more common And are/were used to prevent trains from inadvertently accessing running lines when they were not signalled to do so. They are controlled by point rodding and under the control pf a signalling centre. Typcally the were facing points and diverted the train off the track completely or into a sand drag. ( there one like that at limerick junction )
The use of a semaphore ground signal mounted on a colour light is unusual , must be a transistuon thing or some holdover from the power operated Hueston box maybe , shunt signals are alway passed " at caution" , ie slowly typically 5 mph
Edited by Junctionmad
Two videos taken of the Limerick/Killarney portion of the Steam Dreams 'Emerald Isle Explorer' on Sunday, 21 June 2015:
Newtown Gates between Charleville and Buttevant:
Killarney Junction:
F.
Good Afternoon,
Irish Rail 201 loco 224 + IWT liner passes Hazelhatch & Celbridge
Date: 2 July 2015
Service: 9.35 North Wall to Ballina
Irish Rail EM50 track recording vehicle 700 passes Hazelhatch & Celbridge
Date: 2 July 2015
Irish Rail 071 loco 074 + track materials train passes Hazelhatch & Celbridge
Date: 2 July 2015
Service: Portlaoise to North Wall
Edmund
Edited by COMMUTER29000
  • 2 months later...
Videos of regular passenger services at Island Bridge Junction on 19 September 2015 including 223 light engine.
Irish Rail 22000 DMU 22048 + 22009 & 22000 DMU 22019 & 22000 DMU at Island Bridge Junction
Date:19 September 2015
Service: N/A
Service: 13.25 Dublin Heuston to Galway
Service: Dublin Heuston to Inchicore
Irish Rail 22000 DMU 22020 passes & 22000 DMU 22052 passes Island Bridge Junction
Date: 19 September 2015
Service: 12.20 Portlaoise to Dublin Heuston
Service: Inchicore to Dublin Heuston
Irish Rail 201 loco 223 passes & 22000 DMU 22022 passes Island Bridge Junction
Service: 11.05 Galway to Dublin Heuston
Irish Rail 22000 DMU 22045 passes Island Bridge Junction
Service: 14.00 Dublin Heuston to Cork
Irish Rail 22000 DMU 22053 + 22055 passes Island Bridge Junction
Service: 13.20 Dublin Heuston to Portlaoise
Enjoy,
Edmund
  • 1 month later...
  • 3 weeks later...
Footage from inside Inchicore Works including 071 and 201 type locomotives, DART unit 8127, Mark 4 carriages and Tara Mines ore wagons.
Footage taken during an official tour with the Dublin Institute of Technology and uploaded with permission from Irish Rail.
  • 4 weeks later...
  • 3 weeks later...
When was the rail connection to the docks lost via the side of the point depot , it looks like it was operational till quite recently
Thursday 22nd December 2005, locomotive 155 hauled 4 new MK4s across the connection and down the side of the Point Depot, that was the last day of use, the day before Wednesday 21st December 2005 locomotive 168 hauled a 29000 railcar. All new rolling stock deliveries after the 31st December 2005 arrived at the Ocean Pier, access via Alexandra Road.
Regards
hg
[video=youtube;oVvMProyF-s]
If you pause the video at 1:50, anyone know anything about that wagon. I've never seen anything like it on the network before.
