closetmodeller Posted March 26, 2016 Author Posted March 26, 2016 Eoin's modelling skills are very impressive, but his patience with me is outstanding. I find the concrete very convincing. Quote
richrua Posted March 26, 2016 Posted March 26, 2016 i love the concrete . i need an area like that . how is it done ? Quote
jhb171achill Posted March 26, 2016 Posted March 26, 2016 That is a really nice little layout. The scenery is top class. Quote
JasonB Posted March 26, 2016 Posted March 26, 2016 That area is fantastic,the concrete is so realistic looking,love it. Quote
murrayec Posted March 26, 2016 Posted March 26, 2016 i love the concrete . i need an area like that . how is it done ? Hi richrua Its done like this;- Stick down art cardboard and grey undercoat it, then with a watery mix of Baseboard Dave's Polka powder 5101, paint on and keep the brush lines going in one direction, I then did a second coat even waterier all over and then added a bit of black water-base paint to the mix for around the tracks. I dashed on water in places to get a ware and pooling effect to the concrete surface around the tracks. note;- I used polyfiller to fill in the track where the card didn't! use another filler the polyfiller bloated with the water in the concrete mix when painting it on- I had to clean out the track twice so wheels could run!! Then mark out the concrete joins with straight edge and a sharp HB pencil or softer, then cut into the marked lines with a craft knife to give depth, then stick the pencil in the cut and draw it again freehand filling the cut with pencil lead. Take some pencil lead dust and smudge it around with fingers and paint brush- use a piece of paper to mask the edges of the concrete slabs to get variations. In the end the whole thing will be sprayed with a matt varnish before green stuff and wood-chip is laid down, there is more to go on it yet- keep watching Eoin Quote
richrua Posted March 26, 2016 Posted March 26, 2016 thank you for the excellent description . mighty work done indeed. i am hoping to put in a service yard area . Quote
murrayec Posted April 1, 2016 Posted April 1, 2016 Hi All Was by the Greystones layout dropping off the now illuminated commuter train, DCC directional and coach lights added, it looks great but needs a few holes filled here and there...... CM took a few photos;- I reckon another resistor is required on the coach lights Eoin Quote
murrayec Posted April 9, 2016 Posted April 9, 2016 Hi All And now for a little track weathering... Just used Humbrol 70 matt and matt black, this is not really the time to do this but the paint on the ballast tones the colour down and I reckon it looks better- The ballast train has neglected to service this area! First shots are the first coat;- Next the second coat and a third with matt black added at points and track centre only;- We'll give the rail tops a scarp in a few days, I'd say the points blades will need it to Eoin Quote
murrayec Posted April 9, 2016 Posted April 9, 2016 Cool, thanks Dave When one compares the photos in the previous Commuter post there is an incredible difference- no shiny bits, and the weathered track has a better scale, it looks real... well almost... well! Eoin Quote
rebelred Posted April 10, 2016 Posted April 10, 2016 I agree, It's very realistic , excellent work there! Quote
closetmodeller Posted April 14, 2016 Author Posted April 14, 2016 Cleaning the "rust" from the top of the rails was quite a job, too. Quote
Dave Posted April 15, 2016 Posted April 15, 2016 A trick to making it easier is to use a block of MDF and just after airbrushing rub the cut end of the MDF along the rails and it lifts all the paint off and leaves the tops of the rails clean. Quote
murrayec Posted April 22, 2016 Posted April 22, 2016 Hi All Track is now cleaned up, new Multimause DCC controller installed, and a bit of programming done, we then set about test erecting the back scenes to see where the joins will be so we can work out masking them- it all worked perfectly the duplicate features in the back scenes line up with the bridges of the model with one requiring a large tree. We then ran trains and took a few photos;- Eoin & CM Quote
closetmodeller Posted April 22, 2016 Author Posted April 22, 2016 We even managed to do a quick repair for the station roof, absent from the photos. ECM is doing a great job. The water effect is very satisfactory, too. Quote
BosKonay Posted April 23, 2016 Posted April 23, 2016 Looking absolutly stunning Eoin, the finish on the beach is just perfect, this is already turning into a great layout! Quote
murrayec Posted April 30, 2016 Posted April 30, 2016 Hi CM sent me a few photos of the layout- moody light n all, but looks great even though a lot more needs doing;- The back scene works very well, when the ground line disappears with some planting and scrub- it's going to work very well.... Eoin & CM Quote
murrayec Posted June 11, 2016 Posted June 11, 2016 Hi Here a a few shots of the back-scene, its three sheets mounted on card;- After a disastrous start trying to stick the scenes straight to the wall, we changed tack and stuck the scenes onto card and now they will be stuck to the wall - much easier. Luckily we started at the end that we had a spare scene- as we are using 1 and a half the same scenes for the length of the layout. A few little blemishes on the first attempt- I think we can fix them, the other two worked wonderfully after reading the instructions again!! Eoin Quote
BosKonay Posted June 12, 2016 Posted June 12, 2016 Has a great feel to it. Very much Greystones! Quote
murrayec Posted June 17, 2016 Posted June 17, 2016 Hi The back scenes went up on the wall today and DART 8101 was sent out to test the scenes and the new stone cladding added to the road bridges;- The Dublin road bridge.... ...and at the other end- the road bridge to the timber yard- love the mountains through the arch! Eoin & CM Quote
jhb171achill Posted June 17, 2016 Posted June 17, 2016 That's really turning into a first class layout. Well done. Quote
murrayec Posted June 17, 2016 Posted June 17, 2016 Hi Dave It's flush inkjet print on mat paper card- a photo of stone wall Photoshopped and made fit the CAD template for the bridge foam structure cutting- as seen in previous posts above. There is a little bit of shading added here and there with grey Magic Marker and white pencil 'Highlights'- it works well giving a 3d appearance... Quote
murrayec Posted July 2, 2016 Posted July 2, 2016 (edited) Some test prints of a fuel tank;- Two versions of the fuel tank. The blue is in 00 scale and the grey in H0. They were both produced by uploading a free library design and the printing on my 3D printer. The design is in H0 scale, which I then reprinted by scaling up to 00. Both lower photos illustrate the coarseness of the printing process using my XYZ da Vinci 1.0 printer. Will Brexit mean that we will now have to change from 00 to H0? CM Edited July 2, 2016 by murrayec Quote
murrayec Posted July 19, 2016 Posted July 19, 2016 Hi All Following a suggestion from Dave Lindfield, we decided to install bar couplers in place of the traditional flat magnetic couplers. The bars are 3 mm dia. By 13 mm long and are inserted into vertical holes drilled between the sleepers. Six bar magnets, in two rows of three opposite each other, were used. A first attempt, using weaker magnets, was not successful, so we upgraded to N42 Neodymium magnets. These work but seem to require sensitive adjustment to the Kadee coupler “hooks”. Further adjustment will need to be done, but the overall effect is very neat and unobtrusive. ...and here is a photo of my 3d printed buffer stops, glued, fettled and painted CM Quote
murrayec Posted August 21, 2016 Posted August 21, 2016 Yellow to the frontBrown to the rear Don't know about yours, but our guys keep things very neat... Eoin Quote
murrayec Posted September 9, 2016 Posted September 9, 2016 (edited) Hi All Here are some photos of the first layers of scenic going down;- Dyed sawdust with PVA was spread out over the grass areas, this covered that loud flock we used previously around the timber yard and Southern Track, it looks a lot better now. A layer of 2 types of contrasting fine flock was added for highlights and variation in the base layer- more will be added as the sawdust dries. Up close shows the sawdust works really well, you can also see the fine contrasting flock throughout. Next in this area is the brambles and static grass in scrub n overgrown fashion. This area is the pond/swamp thing, harking to the Murrough and the Reed Beds on down towards Wicklow Town, so it will be some reeds n brown water for this area. We've only got the bridge up and the council is already digging a hole in it! And the Greystones Permanent Way Inspector out closing the gate! Eoin & CM Edited September 9, 2016 by murrayec Quote
closetmodeller Posted September 9, 2016 Author Posted September 9, 2016 The Master does the real work, I just look on in awe. I did get to paint some of the figures, though. Quote
Dave Posted September 9, 2016 Posted September 9, 2016 It's really taking shape, great work on the scenery Eoin. Quote
