A customers layout
An update on the layout,
Viaduct scenery started, more layers to go on.
Track weathering finished
Scenery around the port is almost finished
  • Replies 139
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
shows you what can be done with PECO track work in the right hands , The station crossover is particularly well executed. The additional of trackside accessories always lifts track wok and is an area that many modellers overlook, Real track beds, were festooned with all sorts of gubbins
given thats PECO, Id love to see what your handiwork would look like with finer track work like c&L etc
well done
Dave
Thanks lads :tumbsup:
Bos, I'll get some more pics of it. Still have to finish the scenery on it.
Junctionmad, there are more details to go on such as rely boxes they should really look well. Peco track can be made to look really well once painted and weathered, but I will be building a layout for a client later this year using C&L track and I will be making the points so hopefully that should look the business!
That will be very interesting, indeed, Ill be following that with interest as thats right up what I and trying to ( in 00-SF)
  • 3 weeks later...
A bit more progress, layout is back together. The TMD is next up for scenery and the viaduct is in place almost finished. The concrete area in the TMD is 3mm MDF bonded to 1mm card which brings it up to the height of the rails then scribed painted and weathered. The inserts in the track are plasticard, I'm not a fan of using filler as it is very difficult to get it to look right and as this layout comes apart I would have had to have the join in the filler and that would have been a nightmare!
Looking really good Dave. This looks like it is going to be very special when its finished.
Is the track work in the photos permenantly fixed or is it temporarily fixed pending further work such as ballasting, wiring, etc?
Cheers
Noel
Thanks lads, Noel the track is now fixed in place. I'll be putting the concrete trunking down next with ground shunt signals yard lighting relay boxes then ballast.
I'll take some close up pics later Bos :tumbsup:
Excellent looking layout so far. I especially like the track work. Really goes to show what can be done with Peco track. Is is code 75 or 100 and what ballast and weathering paint did you use?
The track is Peco code 75. Airbrushed with sleeper grime. I paint the track first then ballast, then I lightly weather the ballast. The ballast is Polak TT gauge a product that I sell. I like the TT gauge as I find most OO gauge ballast is over scale.
Wills sheet - you sado masochist!!! Superb work Dave :)
It's Slaters embossed, but the curved stones and capping stones are done by hand. You need to be a bit sado for this kinda stuff!
Thanks lads, still a lot of tidying up to be done but it's getting there. Detailing the TMD now, I'll get some pics up when I get a bit more done.
