scahalane Posted December 8, 2012 Posted December 8, 2012 Stage 1 complete and looking good, now on to the fun part...... painting!!!!!!!
Kirley Posted December 8, 2012 Author Posted December 8, 2012 Stage 1 complete and looking good, now on to the fun part...... painting!!!!!!! If only I had the paint!
Kirley Posted December 8, 2012 Author Posted December 8, 2012 The class 80 is the bis is it scratch or kit built I don't know what it is but I have a thing for railcars It built from a MIR kit which sadly is no longer in production.
Kirley Posted December 22, 2012 Author Posted December 22, 2012 Currently working on a Supertrain rake to go with my A Class and 071 when ever it arrives. First time using Hornby Mk 3’s, on the previous rake I used Lima and you didn’t have the problem in having to masking all the windows. I’m also using Weshty’s EGV kit for the first time. Nice to have the roof detail rather than making your own and little things like the sunken steps below the middle doors and the fuel filler caps. Des supplies thick wire for the door stoppers but I found difficulty in cutting them. The majority disappeared across the room never to be found during the making of the model. I ended up using Evergreen tubing, a lot easier to cut and retain.
Robert Davies Posted December 22, 2012 Posted December 22, 2012 Can I please request that you go into as much detail about the build as you are able to muster, I'm trying to work out if I'm capable of doing something similar in final IE state. Can I just add.... Excellent work so far, the camera is a cruel mistress that highlights even the tiniest faults - so far, so very good! Regards, -Rob
Guest hidden-agenda Posted December 22, 2012 Posted December 22, 2012 Yep wire likes to fly all coming together nicely K and i like them brass steps they certainly catch the eye.
Kirley Posted December 22, 2012 Author Posted December 22, 2012 Can I please request that you go into as much detail about the build as you are able to muster, I'm trying to work out if I'm capable of doing something similar in final IE state. Can I just add.... Excellent work so far, the camera is a cruel mistress that highlights even the tiniest faults - so far, so very good! Regards, -Rob Hi Rob, There are others on this site that are more experienced and competent than I but will give you my thoughts: Using etched sides is the easiest area to start modelling outside RTR. Having the correct tools makes the task more straight forward, so an assortment of drills, files, cutting knifes + a plentiful supply of blades, razor saw, epoxy glue, fillers are the main ones you will need. I think it is essential to have good pictures of the real thing, it make it so much easier to have something to check with. Great pictures on this site of the Mk3 EGV I put the etched side against the stripped down doner coach and mark with felt pen the new windows. Then it is a matter of cutting them out, sticking the etched sides to the coach and follow the instructions on drilling holes for hand rails etc. On the EGV the roof details is good on the SSM kit and it’s a matter of drilling and cutting holes in the roof and cutting the roof ridges to fit on the lifting panel etches. I started on etched kits and each one you do is better than the last so the only way is to have a go. Any mistakes can be covered by fillers and when it is painted and decals added only you will notice where they are. So have a go, the hardest thing for me was cutting into a good coach, after that it was straight forward. PM me if you come across any difficulty.
Robert Davies Posted December 23, 2012 Posted December 23, 2012 Thanks for taking the time to give out a few hints, tips and thoughts. The effort is sincerely appreciated. -Rob
kevrail Posted December 23, 2012 Posted December 23, 2012 (edited) If only I had the paint! Kirley Now that you are at the paint stage where do you get your paint RAL 2000? is it locally and if so where? Edited December 23, 2012 by kevrail
jhb171achill Posted December 23, 2012 Posted December 23, 2012 Absolutely brilliant stuff - love the Enterprise and Hunslets - well done... and the model of the Cork line Mk 4 must have been an awkward one to make too.
Kirley Posted December 23, 2012 Author Posted December 23, 2012 KirleyNow that you are at the paint stage where do you get your paint RAL 2000? is it locally and if so where? I am using CIE Golden Brown, see here for Irish Rail paints http://www.phoenix-paints.co.uk/precision-paints/railway-colours/irish-railway-colours-1.html
BosKonay Posted December 23, 2012 Posted December 23, 2012 Just click the little 'Insert Image' Icon when replying or posting.
kevrail Posted December 23, 2012 Posted December 23, 2012 I am using CIE Golden Brown, see here for Irish Rail paintshttp://www.phoenix-paints.co.uk/precision-paints/railway-colours/irish-railway-colours-1.html Are you using a spray gun or can the paint be got in aerosol can form.
Kirley Posted December 23, 2012 Author Posted December 23, 2012 Kevin I use an Airbrush, if you want to use aerosols go to a good Motor Factor and they should be able to mix any colour and give it to you in a spray can.
kevrail Posted December 23, 2012 Posted December 23, 2012 Kevin I use an Airbrush, if you want to use aerosols go to a good Motor Factor and they should be able to mix any colour and give it to you in a spray can. Anywhere in bangor you can recommend?
Kirley Posted December 23, 2012 Author Posted December 23, 2012 If you phone round a few they should tell you if they don't do it who in the area does
Kirley Posted December 28, 2012 Author Posted December 28, 2012 Finally got round to putting lights onto my A Class. I used Micro LEDs from Express Models for the Marker Lights. The LEDs are connected by very thin wire with a plastic coating and have a mind of their own. The Headlights are white 3 mm LED’s. Because of so many LED’s I used a piece of plastic card to mount all 8 resistors. When I first tested the lights with a 9v battery only the white lights worked so I tried it on AC and all lit up like a Christmas tree, (the red must need more power). You can see all the gaps where the lights meet the Loco body so I need to cover them and paint the covering silver to stop leakage as suggested by Killucan2. Next is the routing all the wires out of the way of the chassis and motor. But I’m pleased to get this far with everything working.
kevrail Posted December 28, 2012 Posted December 28, 2012 (edited) Finally got round to putting lights onto my A Class. I used Micro LEDs from Express Models for the Marker Lights. The LEDs are connected by very thin wire with a plastic coating and have a mind of their own. The Headlights are white 3 mm LED’s. Because of so many LED’s I used a piece of plastic card to mount all 8 resistors. When I first tested the lights with a 9v battery only the white lights worked so I tried it on AC and all lit up like a Christmas tree, (the red must need more power). You can see all the gaps where the lights meet the Loco body so I need to cover them and paint the covering silver to stop leakage as suggested by Killucan2. Next is the routing all the wires out of the way of the chassis and motor. But I’m pleased to get this far with everything working. Looking Good. I am looking forward to seeing the finished product. That looks really fiddley> Edited December 31, 2012 by kevrail
scahalane Posted December 30, 2012 Posted December 30, 2012 Well done, looks complicated! I'm going to start mine any day now!
Kirley Posted December 31, 2012 Author Posted December 31, 2012 Well done, looks complicated! I'm going to start mine any day now! It’s not really complicated, it’s just fiddly work, having ten resistors and a total of 20 wires running to them and the blue, yellow and white leads from the decoder. Patience they say is the ability to endure, amongst other things, provocation without becoming annoyed or upset, or to persevere calmly when faced with difficulties ---but I'm sure you have plenty of it. Good luck with your A Class.
Kirley Posted January 3, 2013 Author Posted January 3, 2013 Cattle Dock for Kirley Junction I used a Ratio Cattle Dock kit + a part completed one from ebay which meant I had to make up the missing bits. I also used a Wills sheet of cobble stones which I bought from the Model Shop in Cork about 3 years ago. It just goes to show everything will come in useful someday in the modeller’s world. Now I have to merge it into the Kirley junction layout and I’ll put up more pictures once I have that section completed.
Garfield Posted January 3, 2013 Posted January 3, 2013 Looking good, Kirley... always good to see someone modelling that era.
Guest hidden-agenda Posted January 3, 2013 Posted January 3, 2013 Nice job K the pens turned out well and a time consuming job that paid off, i take it your getting a few more cattle wagons to cope with the traffic.
Glenderg Posted January 3, 2013 Posted January 3, 2013 lovely work indeed. You're rate of progress is astonishig Richie
Kirley Posted January 3, 2013 Author Posted January 3, 2013 Nice job K the pens turned out well and a time consuming job that paid off, i take it your getting a few more cattle wagons to cope with the traffic. I have them, they are sitting in the "to do box" for about 8 months.
Flying Scotsman 4472 Posted January 3, 2013 Posted January 3, 2013 Looking great K can't wait to see it in situ on the layout
Kirley Posted January 4, 2013 Author Posted January 4, 2013 kirley, any update on the A class? As you can see in the pictures the current stage of the A Class. Now I have the Cattle Dock out of the way I'm working to complete it
heirflick Posted January 4, 2013 Posted January 4, 2013 looking forward to seeing her with her lights working!
Kirley Posted January 13, 2013 Author Posted January 13, 2013 A short video showing amongst others, A 23 in Supertrain livery running with lights.
