flange lubricator
Everything posted by flange lubricator
  1. If you fancy re numbering an A class here's a great tutorial on how to re number a loco ,
  2. Get a sound chip and you can have all the music you need
  3. Like buses you wait ages and they all come along at once
  4. Most of those small scanners are not great , I have a reasonablle scanner for 35mm slides , however you should perhaps talk to Eiretrains as he is an expert at scanning older slides etc and might be able to help you or point you in the best direction .
  5. The coach behind 021 is 32xx BGSV converted from 1950's built stock
  6. After waiting this long I think we can wait a few more days.
  7. B5 primary light blue , secondary white.
  8. While not a Park Royal this is a build of a worsley kit by Eoin Murray which is very similar
  9. The palvans were introduced in about 1964 .
  10. The spoils are suitable and are still available https://irishrailwaymodels.com/collections/ie-spoil-wagons/products/cie-ir-42-flat-spoil-wagons-bundle
  11. Sublime as always
  12. Before the men in white coats get you !
  13. Great pictures
  14. Here's one of 4105 ex British Rail FO 6401 /SO 3157
  15. Well if one was offered it would be bad manners to turn them down .
  16. I would imagine it would , I do wonder if IRM would be making available the 5'3" version of the B4 & B5 as an accessory which I think would be a huge seller allowing us to convert existing stock like Mk1 GSV's , Cravens etc
  17. They probably didn’t want to be accused of teasing us especially if the IRM Mk2 is photographed coupled to a Murphy Bachmann Mk2a !! If they want a sample of a Murphy Bachmann MK2a I’m sure we could rustle one up to IRM towers for research purposes.
  18. I think as they were building the coaches they were morphing from Mk2b into Mk 2c 4112 also has two roof hatches? , The vents are what were called 'GM vents' I belive very similar to what were on the cravens , most Mk2c had Roe Vac vents . Whatever chances we have of seeing some MK2b's and Mk2c's in IE/IR livery I doubt 4112 would be one of them as it a total oddball .
  19. Here are a couple that I posted before of one of the MK2b FK buffet cars , interestingly enough 4106 Mk2c FO is still in existance at Kilmeadan and 4402 ex Mk2b FK at Moyasta.
  20. Perhaps this might wet the apatite 202 at Portarlington with the Athlone ex Heuston summer 2003 the Coach behind the loco is 4112, the second coach is a Mk2c (Ex FO) the third coach is a MK2b ex(FK),
  21. no unfortunately not im afraid
  22. 5106 Full First
  23. Converting these coaches was simply a matter of changing seats and other internal fixings curtains etc no structural changes were necessary.
  24. perhaps this should be in a different thread not to take away or confuse it from the new Nir Mk2 thread ex BR mk2's - Questions & Answers - Irish Railway Modeller
  25. Wow missed that so the three pack of Irish rail 410x series at some point in IE/IR livery ???
