  • 1
CIE locomotive livery variations 1960-1990
PART 1 (of 2)
We're all well aware of the changeover from green to black'n'tan in the early '60s. But it wasn't a case of everything being green one day, and repainted uniformly the following Monday morning! In these days of carefully managed corporate images, there is greater uniformity - and to companies who value a strong corporate branding, this is a good thing. But for an enthusiast and modeller, the 1955-75 period was one of variety, albeit beneath the blanket of the black'n'tan!
I will dig out details as I get the chance of variations in different locos, for example there was at least one 121 which received a red buffer beam during the short-lived greay and yellow era for these engines. The grey and yellow was largely gone within six years or so of delivery, with the class all receiving the standard black'n'tan.
G and E class locos carried both black with white bands at the top, and same with tan at the bottom. Generally, a black loco had CIE roundels on the sides, while a b'n't loco did not. On E class locos, the orange was "full height", i.e. matching the levels up to below-window-level on carriages, or thereabouts. On G class locos the tan was a strip about a foot high from platform level. Both "full height" and "lower strip" tan bands were to be seen on A and C class locos at various times; you will know what I mean if I refer to these variations as "high" and "low" tan sides.
Newly delivered 141s did not have a CIE roundel below the number on the sides, though these were added with later repaints, whereas 181s had them from the outset.
Some C class locos, while black, had yellow ends; on these the loco number was in black. I do not have the details of which locos had which variations and when, but I may be able to dig this out in which case I will post it.
A class locomotives had a tale to be told. This was the subject of an article in the August 1969 Irish Railfan's News, the following being a summary which would be invaluable for those modelling these locomotives in a 1960s setting.
There were sixty of these engines - the largest class of any Irish locomotive bar the GSWR 101s - built in 1955. They were delivered in all over silver, bogies and all, with "flying snails" and numerals in light green, and red buffer beams. This livery had extremely poor durability - probably worse than any other finish any rail vehicle has ever been in! A realistic approach to modelling this would be to look at photos of locos in this livery in traffic - they were a filthy grey in use, and the story got worse by degrees! Not surprisingly, CIE did not perpetuate this more than 5 years or so, with the lighter green as seen on the Dublin RPSI coaches taking over shortly, though not before A46 appeared in the older dark green, with light green line along the middle (as on DCDR's coach 3223 at present) in May 1958.
From here, the story became complicated.
Following A46's debut in dark green, A36 appeared in the then new lighter green, but without the lighter waistband. However, despite the lighter green being the new "post-silver" livery, the following emerged over the next few months in the dark green with waistband: A10, 11, 15, 24, 25, 34, 45, 51, 54, 57, 59 & 60. So by late 1959, one lloco is in light green, 13 in dark green, and the rest in varying stages of the fifty million shades of silvery grey!
From 1960 the lighter version began to appear on all locomotives on a wide scale. A46 itself received this late in the year. No other loco started in dark green and was repainted light green - others went from silver to one form of green, then to black'n'tan or black. By the end of 1961 and locomotives still in silver were really in a deplorable state, in many cases the numerals being barely legible as they seemed to have tendency to wear off.
In September 1961 A6 appeared in an experimental livery described at the time as "black, golden brown and white". The IRN and the IRRS journals of the day doggedly stuck to this description of the light tan, which was in reality a browny-tinted orange. The loco had "high" tan sides. During 1962/3 this livery spread, though after the first few locos were thus treated the white strip above window level became narrower - the more familiar width perpetuated right through to the 1990s on Cravens.
However, in 1962 A16 appeared in traffic in newly painted silver!
By 1963/4, the story was:
Black'n'tan: 1-3, 5-8, 12, 14, 15, 17, 20, 22-4, 27, 31, 36, 37, 39, 40, 47, 48, 50, 52, 56 & 58. The tan was "high" level - same as on carriages. Trains thus formed had a very uniform look.
Dark Green with waist level lighter green line: 10, 11, 25, 34, 45, 51, 54, 57, 59 & 60.
Plain Light Green, no line; OR silver (a few; not sure which): 4, 9, 13, 16*, 18, 19, 21, 26, 28-30, 32, 33, 35, 38, 41-44, 46, 49, 53, 55. (* 1962 painted silver)
As if that wasn't complicated enough, A30 appeared in plain black in early 1964, as seen nowadays on Downpatrick's A39, but with orange buffer beams. Livery detail for modellers here: apart from a few rare one-offs, the general rule is that if there is tan at all, the upper white line continues right round the body sides, whereas if the loco is otherwise all black, the white bits are ONLY on the ends. An exception was the G class: white all round the top of the cab (though black roof, of course) irrespective of whether the loco had tan or not. Also, tan locos had no "broken wheel" on the sides, whereas black ones did in later days, but (as on DCDR's A39 now, and A30 as described above) did. A49 and A55 followed suit, but no other locos were thus treated. The orange buffer beams did not last long, soon being repainted red; otherwise the black livery remained the same.
By 1968 most of the class were repainted in this black livery, though the central side numeral gave way to numerals in the more familiar position on each end of the lower body side, with a "broken wheel" where the number had previously been. But A54 was still a dishevelled dark green (and temporarily out of use) and 1, 15, 22, 37, and 52 were black and "high" tan. A16 had a unique variation; having been b'n't, her sides had been painted black for her appearance in a film "Darling Lili", but her ends were b'n't... for a while!
In June 1968, A52 received the rectangular yellow patch on the front that was to become a short-lived feature on a few locos on the A and C classes, and the B113/4 pair. The loco number was painted on this in black, but the livery was otherwise unchanged. However, A15 was repainted after it, in the standard all-black.
By late 1969, A22, 37, 58R* and 59R* were black'n'tan. All others were black and white, with the following having received yellow ends: A4, 12, 13, 20, 24, 31, 34, 50, 52 & 55.
* The "R" following the number indicated that the loco had had its original Crossley engine replaced by a GM one during the re-engining or "transplant" process. Externally no changes were evident, but on re-engined locos the tan changed to the "low" version. This involved the ends remaining the same, but the formerly mid-height tan band on the sides dropping behind the cabside doors to a band (from memory) about 1 foot or 18 inches high... photos indicate this.
By the time the re-engining process was complete, in parallel with a similar process on the C class (whose livery history had been more or less an exact parallel of the above), the new "Supertrain" livery was coming into being.
Below window level, it was the same, but the changes were above this. Carriages had formerly had a white line above the windows, then more black right over the roof, but now the new "a/c" (Mk 2) stock had the same tan as below windows right over the roof and no white line, giving an impression of an all-tan coach with a black band covering window level only. Numerals were on the ends instead of the sides, giving a smooth and streamlined appearance.
The first locomotives to be treated with this new livery were A's, as they were now being used in a new lease of life on main expresses all over the country. Unlike coaches, locos had a number at each end of the bodyside, low down, and one on the ends, above a CIE roundel; loco ends were the only places where the CIE logo was to be seen on the "Supertrain" livery. "A"'s received tan sides, tan roofs and tan ends, with just the mid-bodyside black band, which dipped at the ends, for relief. The white lines were gone - for the time being! Initially the white numerals on the ends had orange shading if on a black background (A class) and later on with a black background when on tan, as seen on 141s once they started being repainted. I don't remember ever seeing shaded numerals on a 121; I think they were plain white from the start, as the shaded ones became with their first repaint.
Numerals on the sides of locos retained their shading.
(ctd)
  • Thanks 2
  • Informative 3
I meant to do this a long time ago.
Occasionally, black is seen as an alternative colour for CIE steam locomotives, and most will be aware that indeed, a few did carry green and black in the later times. So, for clarity:
1. Everything was all grey from GSR Day 1 until 1947, except for Albert Quay's ex-Bandon distillery 299, which was never repainted from its original green, and the three 800 class. The all-grey even existed long before GSR days; on the GSWR it had been introduced as early as 1915. jhb171Senior recalled that this was most probably due to economy, but as well as that, during the Great War it was not possible to get ready supplies of any colour of paint you wanted. And with Inchicore working full out, luxuries such as allocating men to do lining and so on would have been harder than before.
2. After 1947, MOST remained all grey right until the end of steam. But there exceptions to every rule, thus:
3. From 1947 to about 1953, the following engines were painted lined green, as currently carried by 800 (461's is not the correct shade):
(a) All 4.6.0 - the 400, 500 & 800 classes. Though 802 carried a lighter shade as an experiment for about 18 months from 1952 - this was like a dark apple green.
(b) The "Woolwich" 2.6.0's.
© Dublin suburban tank engines. This explains why one "Bandon Tank" received green, but the others didn't; one was then allocated to DSER suburban services.
Four other locos, each a single example in their class, received it: D14 (or "60" class) No. 61 - must have been a sight for sore eyes!!!, D4 No. 336, D12 No. 305 and B4 No. 467.
In all cases, lining was black and white. "Snails" were gold-lined light green (or "eau-de-nil"); this was a very pale green with a slight yellowish tint, but NOT yellow! Numerals were the same colour, always painted except for the 800 class. These retained the blue background to number and name plates initially, and 800 did until the end - however, 801 and 802 had their name and numberplates changed to a red background about 1951-ish.
4. The Black livery.
This one's a bit like the "modeller's disease" of common misconception that if Hornby make model wagons of all types in all liveries, but always, always, have black chassis, so must it be in real life. Carriages always had black chassis, but wagons almost always had body-colour chassis. Similarly, with locomotives; if it has a smokebox, this must be black. Usually, yes, but not with GSR and CIE grey livery, where it's ALL grey! This is not without precedent. In pre-first world war France and Prussia, there were numerous types of locomotives with smokeboxes the same as body colour...
So to CIE black. Again, the dark grey shown in photos is often assumed to be black, especially if weathered or when the lighting was poor when the photo was taken. When dirty it could look like faded black. In fact, very few CIE locos were ever painted black at all, but some were, as follows; all being thus treated post-1953, before which there was no black at all.
(a) "K1" class "Woolwich" No. 384 was painted glossy black about 1955 for working the "Rosslare Express". Uniquely, it had red lining too - an Inchicore throwback of GSWR influence. Despite being applied to a Midland locomotive! The red lining was accompanied by the standard "eau-de-nil" snail on the tender, and painted cabside numerals in this colour too, as opposed to the light yellow used on grey locos, but similar to the "eau" used on green locos - if all that makes any sense.
(b) Locos of several other classes were painted black, usually as individual examples. J30 No. 90 was repainted as late as about 1957 in what colour slides suggest was black, for example. Both of these were done in Cork, where other variations occurred as described later. A few Midland locos received black - at least one G2 2.4.0 is believed to have appeared thus.
© Three locos - Cork variations as alluded to above - appeared in a unique and quite attractive livery at the very end of steam, only being repainted thus about 1960. This consisted of the standard all-over grey, but with black smokeboxes and chimneys; therefore only appropriate to a Cork-area layout. These were J15 No. 193, ex-Midland J18 No. 593, and "Bandon Tank" B4 No. 464.
An important detail here, which should be of interest to anyone modelling steam in the 26 counties at any time post 1925. Under the GSR, no logos or lettering was carried on loco sides or tenders, with the exception of one Cavan and Leitrim tank, which carried small white "G S" on tank sides for a very short time! Numberplates were either completely painted over grey, or had the rims and lettering picked out in cream, retaining grey backgrounds. Occasionally, the rims and letters were polished, like 186, but this was unusual. Once into CIE times, this pattern remained initially, but before long tenders (never tank sides) received "flying snails" in eau-de-nil, never yellow as often seen now. It's an understandable error, as cabside numerals were yellow! But the "snails" were always eau-de-nil - they were standard transfers, as also used on carriages, and were thus also lined in gold. CIE began to remove numberplates from most locos, though, for example J26 No. 560 retained its plates until 1963. Once removed, unlined pale yellow cabside numerals were painted on.
So - for a GSR era layout - very easy! Unless ther's an 800 on it, everything's grey, no logos.
For CIE, green locos as 800 in Cultra (without the incorrect "G S" added by Cultra! - but with a lined "snail" instead). The rest, all over grey, with lined eau-de-nil snails on tenders, and pale yellow cabside numerals.
I hope all that makes some sort of sense!
JHB, I doff my hat sir. A super collation of info, particularly on the black / grey conundrum. This mornings posting will be printed and treasured.
Thanks, Weshty!
Indeed, Minister (I almost said "Yes Minister"!), there were variations like that. In all cases where one livery supercedes another, such will be the case. Black'n'tan locos persisted into the early 80s, eight years after any were thus painted. In the late 40s, many GSR maroon coaches were to be seen among gleaming new CIE paint. For a few years after 1925 there would have been a few - albeit a rapidly decreasing few - ex-MGWR locos in green, DSER in lined black, and CBSCR in olive green. One C & L 4.4.0T (No. 1) still wore badly faded green in 1932. One MGWR goods 0.6.0 ("Luna") was still green in 1930, having been the last thus painted in Broadstone about 1924.
There was a very antique former passenger brake van still kicking about in Inchicore into the late 50s still in very badly faded and weathered GSWR deep purple lake. There are even colour pictures of it.
jhbSenior recalled coaches in his daily commute in the 1920s on the Harcourt street line. Most were GSR maroon, but often one in then-lighter DSER maroon would show up.
As a mere stripling, I recall nagging at my aunt to take me into town on a green bus instead of a navy and cream one.... green and flying snails were still about, but CIE navy and cream had become the norm. Just a few years later, the same in the north - green UTA buses were still about, but new Ulsterbus blue and cream was now the main show in town.
Edited by jhb171achill
Quick questionay ? When the IE plug socket logo came out ' date=' was there a while when IE and IR logo trains ran together or was the change quick ?[/quote']
Yes-it was quite a while before the full change over took place.
I'm sure many are aware - though some may not be - of the superb range of loco numb and nameplates offered by Narrow Planet.
They do GSR / Inchicore / CIE plates too, and very accurate they look. Though - for some reason they offer them with red or black backgrounds - both are entirely inaccurate as grey only is correct. By the time CIE painted a very few locos black after 1955/6, plates had been replaced on all example by painted pale yellow numbers and light green gold-lined "snails" (not yellow!!) on tenders.
Locos in green never had plates - always painted numbers, except the 800 class. While 461 never ran in anything but grey afte 1925, had she done so she wouldn't have had a red numberplate. She and 462 lost theirs years at and got painted numbers.
GSR numberplates had letters and numbers and rims picked out in either pale yellow, or just polished bare metal. Since this was whitemetal rather than brass, polished metal gave a silvery colour. Thus, leaving a model one without paint gives a yellow touch, so better to do what both GSR and CIE did with many locos - just paint over the lot and leave it at that!
On 1/6/2013 at 12:01 AM, jhb171achill said:
071 Class
Delivered from GM in a factory painted version of CIE livery. The "tan" was not CIE's standard shade, being significantly darker and more brownish. The CIE roundel on the ends was all white, instead of the normal style of tan surround and white letters, and it was not quite the standard shape of logo. It looked slightly larger than normal. At first repaint all received standard "Supertrain" livery.
These locos did not carry standard orange with white logo. White logo, brown paint; normal logo with normal orange / tan.
In the case of all of the above, "tippex" white lines were of course added post-'87, along with a change of logo.
Any idea which of the two CIE liveries in the photos attached ran from when until when?
The top one looks a better colour match for MM's ST Mk2D's, but has a black wheel instead of red, and a white roundel instead of orange.
The second one has an "SA" affix, red wheel and the correct roundels, but is a much bloodier shade of orange than the ST coaches.
18 minutes ago, murphaph said:
Isn't the one beside the Imp the delivery colour where EMD used an off shade?
Top is as delivered, one by the IMP is repainted by CIE in SuperTrain.
Technically, the top one (088) is incorrect in details.
First, as on the "heritage" 071 at the moment, the CIE roundel, while all-white, wasn't the standard CIE transfer on the factory-delivered 071s. When delivered, the all-white CIE logo was not the correct design, with a larger diameter perimeter and non-standard lettering. The design of the logo on the model of 088, and the "heritage" (I nearly said "preserved"!) 071 is the standard one, though they've got the non-standard "all-white" bit correct.
Secondly, I am not sure if the running plate was orange - I stand to be corrected on this, but I think it was black.
As implied above, the red brake handle came later.
The BIG thing, though, was the colour. General Motors appear to have simply got this wrong, and by some margin. The orange on the model is right for what OTHER locos (and carriages) had at the time. The slightly brighter shade would appear during the 1980s.
On first repaint, all 071s got the then-standard orange as above, along with CIE badges of the standard style, and with orange "broken wheels".
Hope this helps!
As far as I recall, I have yet to see in model form the "correct, "incorrect" shade" that they were delivered in. It was distinctly brownish, and much more worthy of the description of "golden brown" than the original shade was in 1962.
3 minutes ago, flange lubricator said:
Perfect - you can see the non-standard CIE logo well in that. Also, the brake wheel was black as the Murphy model replicates.
I can't recall exactly when these started being red, but I guess late 1980s - someone else might be able to confirm this?
The photo actually makes the orange look more "normal" in that; in reality it was more brownish than the pic implies, and really showed up very starkly against a clean set of Mk 2s!
9 minutes ago, DJ Dangerous said:
Thank you!
So, would it be fair to say that the shade on the two locos should be swapped, with the details remaining as they are, to better reflect the progression of the liveries?
I'll try to dig out a photo.
Wow!
Even looking at the headlights, it looks as if the shade on each of the two models should be swapped around.
If the top model of the two maintained its details but had the bloodier shade, it would look just like flange's photo.
Best I could find - certainly none are great photos, but it gives an idea.
I have ciné of them departing Heuston which shows the brownish shade up WAY more starkly.
Some models seem to have the orange / tan / golden brown* going part way down on the central driver's steps. This is wrong - they were black to the top.
(*  ...or whatever ye're havin' yerself.....)
You can see the colour difference very clearly against the AC stock in the third photo.
Still a glorious sight thundering along at 75 though in spite of the Americans getting their paint mix slightly out! ;)
Very much so!
So, the 071's were delivered in the wrong livery, more or less.
When repainted, were they in a different shade to the SuperTrain coaches?
To my eye, the "wrong" livery looks closer to the ST coaches than the ST livery?
Don't confuse the model liveries with the real things. When the 071's were delivered, they were in a different shade to the Mk.2's, but when they were repainted at Inchicore, they then matched the current CIE liveried coaches and locos at that time.
There has been much debate on here about the orange shade used on the MM Mk.2's being incorrect. The MM Mk.2's should match the livery shade on 086, but are more akin to the orange shade used on carriages and locos in IR and IE period.
Edited by iarnrod
1 minute ago, iarnrod said:
Don't confuse the model liveries with the real things. When the 071's were delivered, they were in a different shade to the Mk.2's, but when they were repainted at Inchicore, they then matched the current CIE liveried coaches and locos.
Thank you, I have been confusing the models and real life.
That makes complete sense what you say about the Mk2D colour.
The livery on the MM 088 loco is probably far too light a shade of colour as the real 071's, when delivered, had a more brownish tint to their paint colour than the CIE tan used on everything else that was black and tan at that time.
Edited by iarnrod
That makes sense, thank you!
Going back to 071 liveries, when were the following changes?
IR to IE?
IE small logo to IE large logo?
IE to silver and black?
I'm sure that I saw a video of an IE 071 several years after the rest had been painted into silver and black, but cannot find it.
SIlver and black to grey was 2016, and happened pretty quickly?
Which were the first and last members of each class to be repainted for each change?
17 minutes ago, K801 said:
Has a C class ever been observed/documented hauling Mk2 a/c stock, even a transfer move of stock?
Not in service that I'm aware of but ECS definitely, give me a tick and I'll find you a photo...
IR to IE?
CIE to IR "tippex" livery ("set of points" logo) 1987 onwards
IR to IE logo change on "tippex" livery not sure - late 1990s?
Modern liveries ar not my area of expertise date wise, but the change for 071s to silver, black and yellow was about 2005, I think? It was in hogue for about a decade, so 2016 for the all-grey fits.
According to Irish Metrovick Diesels B201s for a short while B201s worked Dublin-Cork Trains of 6-7 MK 2D coaches in the 1972 timetable. The 13:30 ex Heuston & 17:30 ex Cork were regular B201 hauled Supertrain workings.
Following re-building B201s regularly hauled long distance passenger trains in the late 60s early 70s including Heuston-Cork, Limerick and Tralee trains, Connolly Galway and Sligo workings plus some main line freight workings including Dublin-Drogheda bulk and bagged cement (H wagons) trains.
Its possible the operating people preferred the B201s to the Yanks and Bo Bos for main line passenger working as they may have been steadier at speed with their Commonwealth bogies than the GMs.
After the 1973 "Oil Crisis" CIE dropped its policy of operating light fast frequent trains, CIE returned to its earlier policy of running less frequent heavier trains using 001 Class or pairs of small GMs, though the B201s continued to Drogheda-North Wall cement trains into the late 70s in addition to Dublin inner and outer Suburban duties.
I spent a Saturday afternoon  watching a procession of B201 hauled bagged and bulk cement trains passing Howth Junction  while surveying a site on the then new Baldoyle Industrial Estate in 1978.
Hopefully a B201 is on the IRM to do list.
Edited by Mayner
  • Informative 3
I suppose once re-engined, a B201 was more of a "puller" than most of the GMs. Even with the same nominal engine output as a B181, the MV electrical equipment gives them 842hp at the rail compared to 810hp for a B181.
I would agree the bogies were smoother riding, that also seems to have been one of the few redeeming features of the original 'A's.
Though it doesn't always help, BR Class 47s have Commonwealths and they had a reputation for rolling like a ship in a Force 12 at 95mph!
Must try flickr again for a photo, now knowing they did have a booked working I can narrow my search. That photo above was one I was already aware of.
8 hours ago, Mayner said:Its possible the operating people preferred the B201s to the Yanks and Bo Bos for main line passenger working as they may have been steadier at speed with their Commonwealth bogies than the GMs.
Having had many a mainline run in the cabs of 141s, I can confirm that they were most uncomfortable at speed. Even on good track they were bouncy. Nowhere were they smooth and steady.
In the 1970s track wasn’t as uniform as today - some sections were very much better or worse than others. The Kerry and Sligo roads I remember as much rougher, and the Ballina branch was like a rough sea. I did all in 141s.
Even at 30 mph and in a carriage (not the engine), the Loughrea branch was, I think, the roughest track I ever covered anywhere in the world!
And if anyone here did Indonesia in the 1980s or Myanmar in more recent times, you’ll know that really is saying something!
Answer this question...
