Robert Shrives Posted June 27, 2022 Posted June 27, 2022 Snap George ! I have one as a 111 pending the urge to finish. I found fitting the bonnet side hand rails a real PITA yours much better in Video any chance of a still so I can learn a better better way - and then blatantly copy. Thanks Robert
Georgeconna Posted June 27, 2022 Author Posted June 27, 2022 Hi Robert, As I painted a number of MM's 071 into grey without the front Grab Rails I kept those and used them on this one. just popped them into the drill holes! (presume you mean those?) I used Class 31 buffers as the white metal ones are a bit chunky. Replaced the brake hoses with finer white metal ones and I will have brass horns on it too. 2
Georgeconna Posted June 27, 2022 Author Posted June 27, 2022 Next in line is this one, Pretty complex livery TBH 1
Georgeconna Posted June 30, 2022 Author Posted June 30, 2022 Bit of Weathering on it. Runs quite nicely. 20220629_232128.mp4 390054864_20220629_230735(1).mp4 4 1
DJ Dangerous Posted June 30, 2022 Posted June 30, 2022 Looks lovely. What the Hell is a Porto 2000 chassis?
skinner75 Posted June 30, 2022 Posted June 30, 2022 (edited) 20 minutes ago, DJ Dangerous said: Looks lovely. What the Hell is a Porto 2000 chassis? I think it should read Proto 2000 chassis - probably of the EMD BL2 Edited June 30, 2022 by skinner75 1
DJ Dangerous Posted June 30, 2022 Posted June 30, 2022 1 minute ago, skinner75 said: I think it should read Proto 2000 chassis - probably of the EMD BL2 Found it. Life-Like Trains Proto 2000 BL2 chassis: https://en.wikipedia.org/wiki/Proto_2000_BL2 1
Georgeconna Posted June 30, 2022 Author Posted June 30, 2022 1 hour ago, DJ Dangerous said: Looks lovely. What the Hell is a Porto 2000 chassis? Portuguese Variant! (corrected) 2
Georgeconna Posted July 2, 2022 Author Posted July 2, 2022 Lashing away on the KE, Very complicated to mask, Need to close the white lining 8 1
murphaph Posted July 2, 2022 Posted July 2, 2022 My oh my that looks like a tricky masking job George. How are you doing it with the variable width swooshes, cutting them out by hand? 1
Georgeconna Posted July 6, 2022 Author Posted July 6, 2022 Getting there. Small Warp in the chassis but easy nuff to sort out. 11 1
Georgeconna Posted November 6, 2022 Author Posted November 6, 2022 There was a Mimimum space challenge on a previous form and this was being built for it before the forum went away. It languished on a shelf for the past 7 years+ I'd say so I thought I might try to finish the bugger afte I rest a soldering Iron on it. Might re look at this challenge again. I think it was 4 ft x2ft r summit and do a little Irish Layout. In the mean time Lunch tomorrow with the missus to offset the shed load of boxes due tomorrow from Marks and IRM!! 10
Georgeconna Posted May 24, 2023 Author Posted May 24, 2023 Decided to treat myself to a few things this week after flogging off a good bit of stuff I will never use. 2 sound decoders for a 141 / 181 from roads and rails. Speaker fits in without any surgery. Also a dapol signal controller an SR Signal. The signals do add an extra dimension. I suspect the GWR ones with a replaced arm would do for irish. So easy to install although the Dynamis programming did not work so the Z21 came to the rescue here and so easy 20230522_224836.mp4 20230523_225747.mp4 20230523_213831.mp4 10
Georgeconna Posted May 21, 2024 Author Posted May 21, 2024 Workbench is nearly back!! The office section of the shed has been panelled. Flooring next in June, then skirting. War office has decreed no airbrushing allowed in office section.... 8
Gabhal Luimnigh Posted May 21, 2024 Posted May 21, 2024 Great progress George, negotiations are always better than conflict according to the UN anyway 1
DJ Dangerous Posted May 21, 2024 Posted May 21, 2024 Lovely stuff, @Georgeconna. When do commercial operations recommence? 1
Georgeconna Posted May 21, 2024 Author Posted May 21, 2024 26 minutes ago, DJ Dangerous said: Lovely stuff, @Georgeconna. When do commercial operations recommence? 2nd week in June when the flooring goes in! Need another desk, ply on the walls to get up the work space area.
Georgeconna Posted June 17, 2024 Author Posted June 17, 2024 Floor in today. Now the big sort out from loft to shed. Still a bit to do. 12 2
Georgeconna Posted October 2, 2024 Author Posted October 2, 2024 Ops area of the shed nearly done. Last coat of paint tonight...hopefully back modelling next week after a years break. 11
Georgeconna Posted October 4, 2024 Author Posted October 4, 2024 (edited) wrong section Edited October 4, 2024 by Georgeconna
