richrua Posted March 12, 2017 Author Posted March 12, 2017 The roof vents are just the ones that come with the dapol coach. Trimmed a bit. They're not perfect but ok. Had to make two with sprue as there was not enough.
richrua Posted March 12, 2017 Author Posted March 12, 2017 Oops. I just realised I made a livery error. I also have the generator van sides which I know only came into use in the 70s so if I keep this one green then I can't run them together. .. what gen van was used with the early livery Bredin?
jhb171achill Posted March 19, 2017 Posted March 19, 2017 Gen vans....... "tin vans" were used from end of steam (when they became necessary) to 1970 or so when the Dutch and BRs were in service. Some tin vans were still in use around 1976-7. The last coaches still in green would have been about 1966.
josefstadt Posted March 20, 2017 Posted March 20, 2017 Oops. I just realised I made a livery error. I also have the generator van sides which I know only came into use in the 70s so if I keep this one green then I can't run them together. .. what gen van was used with the early livery Bredin? Rich, early livery Bredins (green) did not operate with gen vans. To supply electricity for lighting each coach was equipped with batteries charged by a dynamo driven by a belt off one of the axles. The coaches were electrically independent from each other. Heating was supplied either from the locomotive (steam and diesels 1100/B113 and 1101/B114) or from a steam heating van (diesel era). Gen vans were not introduced until the early 1970s - well into the Black & Tan era.
jhb171achill Posted March 20, 2017 Posted March 20, 2017 Re-reading my post above it suggests that that tin vans were a variety of genny vans, which they obviously weren't. I should have added the difference between a steam van, a luggage van and a genny! I was merely trying to suggest what was at the back of the train in the "green silver grey" era and the 60s!
Junctionmad Posted March 20, 2017 Posted March 20, 2017 Re-reading my post above it suggests that that tin vans were a variety of genny vans, which they obviously weren't. I should have added the difference between a steam van, a luggage van and a genny! I was merely trying to suggest what was at the back of the train in the "green silver grey" era and the 60s! I remember travelling behind all three versions , but wasn't the 6 wheel version the only van of that " general type" that had both the spanner boiler and generator , due to the combined weight
richrua Posted March 20, 2017 Author Posted March 20, 2017 So my Bredin bgsv needs to be black and tan era. The other bredins can be green but with a little tin Van added. I was going to pull them with my wooly. Suitable ? (Not the bgsv of course - I can use that in a cravens train )
jhb171achill Posted March 20, 2017 Posted March 20, 2017 A "woolly"..... 😀 Visions of an eco-friendly sheep-hauled train! Excellent.... The last Woolies in traffic were 376 (withdrawn 1961) and 388 (1962). Another eight had lasted until 1959 / 60.
DiveController Posted March 20, 2017 Posted March 20, 2017 (edited) So my Bredin bgsv needs to be black and tan era. The other bredins can be green but with a little tinVan added. I was going to pull them with my wooly. Suitable ? (Not the bgsv of course - I can use that in a cravens train ) You won't need a tin (steam heating) van if you used the Sheepy Steam Power but one of these 3101 series babies wold be required if you use an early diesel I remember travelling behind all three versions , but wasn't the 6 wheel version the only van of that " general type" that had both the spanner boiler and generator , due to the combined weight The four 3153- series had both and weighed in a a hefty 30T even though only 30' long, hence needed a third axle. Didn't all gen vans have double generators for redundancy? Edited March 20, 2017 by DiveController
richrua Posted March 20, 2017 Author Posted March 20, 2017 Very nice indeed. I know a "woolie" pulling them is perhaps fanciful, but was it possible time wise ?
DiveController Posted March 20, 2017 Posted March 20, 2017 No, the 1356 series coaches were built about 1953-55 and I'm sure JHB is correct about the final withdrawal dates of the Woolwich locos about 1960. A hooded van would be a nice addition for luggage or a full parcel/brake 2700-2765 Series Hooded Van Luggage Van Mayner Brass Kit Model All these are Mayner built
jhb171achill Posted March 20, 2017 Posted March 20, 2017 Steam hauled passenger trains ran here and there until early 1963. Tin luggage vans were to be seen behind them on many an occasion - often with ancient wooden coaches!
richrua Posted March 25, 2017 Author Posted March 25, 2017 Thanks. Looking for some decals. I wonder does weshty do them lads ?
Noel Posted March 25, 2017 Posted March 25, 2017 (edited) Working on the Bredin Brake. Body looks really fine. Is she going to be B&T or Olive green flying snail livery? PS: Does anybody know the RAL number for flying snail green livery coaches and the RAL number for the light green lining? EDIT - Re-read thread Edited March 25, 2017 by Noel
richrua Posted March 25, 2017 Author Posted March 25, 2017 Hi Noel . It's an overlay from Mayner that fits the really cheap (but good too for the money ) dapol stanier 60ft kits. I really like the overlay. Very fine . Makes up easily enough. Always Enjoyable making up an Irish object through semi-scratchbuilding. They are a nice looking carriage too.
Noel Posted March 25, 2017 Posted March 25, 2017 (edited) Hi Noel . It's an overlay from Mayner that fits the really cheap (but good too for the money ) dapol stanier 60ft kits. I really like the overlay. Very fine . Makes up easily enough. Always Enjoyable making up an Irish object through semi-scratchbuilding. They are a nice looking carriage too. Sounds great. I had a look back at #353, what glue did you use to fix the brass sides to the lower plastic body sides and the coach ends? Do you add a sort of 'spar' along the top of the body sides to replace the strength of the cut away body sides, and help fix to roof, or is the brass strong enough to hold shape and bond directly with plastic roof? Edited March 25, 2017 by Noel
richrua Posted March 25, 2017 Author Posted March 25, 2017 I am experimenting with a simple plastic strip added. I need to complete the interior first though before finalising the roof, as it will need to be glued on more or less permanently.
Noel Posted March 25, 2017 Posted March 25, 2017 I am experimenting with a simple plastic strip added. I need to complete the interior first though before finalising the roof, as it will need to be glued on more or less permanently. Thanks, that makes sense. Looking forward to seeing the end result. What are you planning to use for window glazing?
Mayner Posted March 25, 2017 Posted March 25, 2017 Sounds great. I had a look back at #353, what glue did you use to fix the brass sides to the lower plastic body sides and the coach ends? Do you add a sort of 'spar' along the top of the body sides to replace the strength of the cut away body sides, and help fix to roof, or is the brass strong enough to hold shape and bond directly with plastic roof? Sorry for hi-jacking the tread Rich, I tried building the coaches with a removable roof and with a removable floor and found it easier in the end to build the coaches with a removable underframe and floor. I 1st glue the roof to the sides before cutting out the slots in the sides and floor and fit the interior from below, I leave a ledge of plastic at each end so that I can screw the body to the underframe. I glaze the windows with clear styrene fixed in place with double sided tape
richrua Posted April 14, 2017 Author Posted April 14, 2017 In anticipation of the ballasts I started putting together this ssm ploughvan. Quick question folks regarding the side lamps. The instructions say later versions of this van did not have the side lamps. What date ish would these later vans be ?
PJR Posted April 14, 2017 Posted April 14, 2017 In anticipation of the ballasts I started putting together this ssm ploughvan. Quick question folks regarding the side lamps. The instructions say later versions of this van did not have the side lamps. What date ish would these later vans be ? [ATTACH=CONFIG]27537[/ATTACH] [ATTACH=CONFIG]27538[/ATTACH] [ATTACH=CONFIG]27539[/ATTACH] [ATTACH=CONFIG]27540[/ATTACH] [ATTACH=CONFIG]27541[/ATTACH] Looking good so far
Noel Posted April 15, 2017 Posted April 15, 2017 In anticipation of the ballasts I started putting together this ssm ploughvan. Quick question folks regarding the side lamps. The instructions say later versions of this van did not have the side lamps. What date ish would these later vans be ? Nice job so far. Are you using solder or superglue? Is the Dapol chassis 9ft, 10ft or 11ft? I will probably run the imminent delivery of IRMs as 'dolomite' wagons instead of ballasts, so won't need plough vans. Yellow didn't seem to be around in the B&T 60s and early 70s era.
jhb171achill Posted April 15, 2017 Posted April 15, 2017 Nice job so far. Are you using solder or superglue? Is the Dapol chassis 9ft, 10ft or 11ft? I will probably run the imminent delivery of IRMs as 'dolomite' wagons instead of ballasts, so won't need plough vans. Yellow didn't seem to be around in the B&T 60s and early 70s era. Correct! Yellow only appeared in comparatively recent times. Grey was the rule without exception* in the 50s and 60s and early 70s, when (on CIE) brown (but NOT the current reddish-brown) began to appear. Latterly, yellow. (* This applied equally to GNR, NCC, UTA & CIE). Plough vans were the same colour as ballast wagons, goods brake vans and other general four wheeled bits'n'pieces. And not a black bit of metal strapping or black chassis in sight! :-)
richrua Posted April 21, 2017 Author Posted April 21, 2017 (edited) All in grey. Looks nice mind you. Really enjoyed building this kit. I might do another in grey but this is just an undercoat. As you can see its not perfect (due to my modelling skills) but I am pleased nonetheless. Luckily any I've seen of these in yellow are both well looked after but also a bit beat up too. I am going to give it the good weathering . Try out the humbrol rust powder. Edited April 21, 2017 by richrua
Noel Posted April 21, 2017 Posted April 21, 2017 [ATTACH=CONFIG]27613[/ATTACH] All in grey. Looks nice mind you. Really enjoyed building this kit. I might do another in grey but this is just an undercoat. As you can see its not perfect (due to my modelling skills) but I am pleased nonetheless. Luckily any I've seen of these in yellow are both well looked after but also a bit beat up too. I am going to give it the good weathering . Try out the humbrol rust powder. Nice one Richrua. Looking good. I have never used brass before, but I am due to attempt one of Des's brake vans, so do you mind me asking a few questions? What primer did you use and did you have to prepare the brass to receive it (i.e. sand, etc)? Did you use solder or super glue to build it, and if solder which kind? Is the Dapol chassis a 10, 11 or 12ft?
richrua Posted April 21, 2017 Author Posted April 21, 2017 Hi Noel it's the dapol prestwin chassis , 12ft, which comes with the SSM kit. I used super glue. The primer is plastikote grey primer which seems to work well on brass (it is not acrylic though and is very smelly).
richrua Posted April 22, 2017 Author Posted April 22, 2017 A ploughvan, Just in the nick of time! Now, it's first job is to pick up some ballasts!
Glenderg Posted April 22, 2017 Posted April 22, 2017 That's tidy, but i especially appreciate the lamp irons, no mean feat, but every little detail helps. Whip off one of them monster couplers though, for the tail end charlie R.
