7 hours ago, DJ Dangerous said:
They look the business!!!
They sure are DJ…..they really capture the look of the interior-just as I remember them in service.
  • Agree 1
Friday night on Tara junction,Cravens coach 1523 bring back memories of nights seeing the real thing on the Ballina branch,here we see passengers enjoying the comfort of the coach as the steam heat oozes from the pipes between coaches….
  • Like 7
Dem were the days...Can't clear the section signal, the Ballina boys are running late' "Hmm, must have been delayed😉.… again..."
  • Funny 2
2 hours ago, ttc0169 said:
An early morning start at the Lakeview MPD as 121/141/181 locomotives are prepared for liner train duty on Tara junction.
Wow! That depot itself is a masterpiece in its own right! The fact that its creator is a lifetime professional railwayman shows through in bucketloads…..
Edited by jhb171achill
  • Agree 4
Thank you Jonathan-much appreciated. 👍👍
A rare sight was seen passing through Tara junction station this morning when locomotive 133 operated bonnet first while working a Guinness transfer liner to the Lakeview freight yard,
The train consisted of four MX two axle wagons.
(MX wagons please if possible IRM)👍
Edited by ttc0169
  • Like 14
Friday night operating session on Tara junction we see;
CIE liveried locomotive 086 work a Tralee-Dublin Heuston Cravens service,
Fresh from the paint shop sporting IR white stripe livery is locomotive 080 hauling the Dublin Heuston-Ballina FO Cravens set.
Locomotive 220 hauling the refurbished Mk2 set working a Galway-Dublin Heuston service.
161+132 have been a late substitute for a failed 084 hauling the Mk3 set from Waterford-Dublin Heuston.
  • Like 7
The track level and platform level shots are sublime, TTC!
Just out of curiosity, after watching 161 and 132, is there (and was there back then) redundancy built into the rail network?
Is there a spare loco on standby, or does launching a rescue mission require cancelling something else?
If there is redundancy, where would the spare tend to be lurking?
There is a Class 201 on standby duty  in Cork
Back in the day-locomotives would be taken off freight or permanent way trains for failure situations-as locomotives were more numerous around the network then,
Rescue locomotives nowadays would come from Inchicore,Cork,Limerick,Portlaoise or Drogheda.
  • Informative 2
A nighttime permanent way possession of Tara junction has now been implemented in order to facilitate the operation of the track cleaning coach around the hard to reach areas of the layout.
The crew of locomotive 201 prepare to start the cleaning process which forms an essential part of any model railway operations.
  • Like 12
4 hours ago, DJ Dangerous said:
Love it, TTC, have always wondered about track cleaning on such a large and spectacular layout.
Thanks DJ- I also used a gauge master track rubber for the east to reach areas of the layout.
2 hours ago, WRENNEIRE said:
If Carlsberg did rail cleaners
Probably the best rail cleaner around
Uses a chemical to clean so no scratching with rubbers etc
Thanks for the heads up, David. Every time I've looked at it it appears to be out of stock everywhere.
On 1/10/2023 at 6:25 PM, David Holman said:
Over 800,000 views! Remarkable, well done.
It's the most-viewed on the forum by quite a stretch!
Edited by DJ Dangerous
  • Agree 1
